Author Topic: Lube Kit (OG x GH)  (Read 22595 times)
Offline sherryton
  • Kībōdo
    • Originative
Lube Kit (OG x GH)
« on: Tue, 19 November 2013, 20:14:43 »
Available through our Originative web-store.
http://www.originativeco.com/products/lube-kit
Please be nice about the picture :)
Offline bueller
  • MX baller
  • Church of the Ergo Clear
Re: Lube Kit (OG x GH)
« Reply #1 on: Tue, 19 November 2013, 20:15:48 »
Sweet :)
You're really becoming a one stop shop now!
« Reply #2 on: Tue, 19 November 2013, 20:17:21 »
Hey sherry, You should also say that you can mix the two lubes.
Offline Dubsgalore
« Reply #3 on: Tue, 19 November 2013, 20:18:31 »
Cool, I'll be needing more lube in the future.. :cool:
Offline sherryton
  • Kībōdo
    • Originative
« Reply #4 on: Tue, 19 November 2013, 20:18:40 »
Sweet :)
I have been wanting to get these.  I wanted everything you need to build a keyboard including keycaps as we do sell cusotm keyboards.
We are just missing a few more things like Cherry and Costar stabilizers!
The lubes are already pre-mixed.
Offline Pacifist
  • on hiatus
« Reply #5 on: Tue, 19 November 2013, 20:20:50 »
FIANLLY!!!!
« Reply #6 on: Tue, 19 November 2013, 20:22:22 »
That works haha
« Reply #7 on: Tue, 19 November 2013, 20:24:24 »
So how do these compare to what mkawa was selling?
Offline Dubsgalore
« Reply #8 on: Tue, 19 November 2013, 20:25:11 »
I can buy one and compare for you haha.. :p
« Reply #9 on: Tue, 19 November 2013, 20:26:17 »
Well I was meaning more like contents, etc. Is it the same lube?
Offline sherryton
  • Kībōdo
    • Originative
« Reply #10 on: Tue, 19 November 2013, 20:31:45 »
Basically, the previous package was 2 separate items: oil and lubrication.  Now, mkawa came up with a recipe to mix them.   It feels like youre typing on a cloud of clouds.
It works real well on blacks, clears, and reds.  (Thick for clears and thin for blacks and reds)
Also previously, mkawa suggested people to mix the oil and lubrication, and people can mix according to how they like it.  It's all premixed now which makes it a lot easier.
We are just trying to be your one-stop shop for a BYOKBD store.  The shipping was inefficient previously, but it should be a lot better now for people who are looking to buy switches, stickers, or springs.
« Last Edit: Tue, 19 November 2013, 20:35:04 by sherryton »
« Reply #11 on: Tue, 19 November 2013, 20:39:07 »
Cool! Thanks for the info!
Offline stancato9
« Reply #12 on: Tue, 19 November 2013, 20:43:36 »
Is it possible to get an idea of how much stock you have so I know how fast I need to purchase these kits before they sell out? :)
Poker 2 - MX Red
Offline HPE1000
  • Keycap Paparazzo
« Reply #13 on: Sun, 24 November 2013, 12:45:02 »
So I would be buying this for mx clears and I was wondering, I would need the thick lube obviously. But as far as what I should lube with this, can I do the sliders and springs both, or should this (thick) not be used on springs? Thanks :)
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #14 on: Sun, 24 November 2013, 14:57:29 »
Might be a dumb question, how do we lube the switches ? Is there instructions to do so ?
I'm planning to get some to lube my switches.
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
« Reply #15 on: Sun, 24 November 2013, 15:01:00 »
Credit to Whitefiredragon for these informative vids!
Very busy with studies atm.
    • Gray Designs
« Reply #16 on: Sun, 24 November 2013, 15:17:40 »
Is this a good mix for topre sliders?
Offline sherryton
  • Kībōdo
    • Originative
« Reply #17 on: Tue, 26 November 2013, 14:19:25 »
I think we might need ming's answer.  I will ask him.  I think he lubed his realforce.
« Reply #18 on: Tue, 26 November 2013, 14:21:14 »
This thread might also be helpful as well as this guide.
    • Gray Designs
« Reply #19 on: Tue, 26 November 2013, 17:21:32 »
« Reply #20 on: Tue, 26 November 2013, 17:25:26 »
I used thick on my hhkb today.
Offline sherryton
  • Kībōdo
    • Originative
« Reply #21 on: Tue, 26 November 2013, 20:09:21 »
How did it go?  Did you change the weight on it?
« Reply #22 on: Tue, 26 November 2013, 23:45:21 »
Well along with lube, I also added dental bands and 55g domes, overall I like it.
    • Gray Designs
« Reply #23 on: Tue, 26 November 2013, 23:56:26 »
sweet dude ;p the 55 feels better?
« Reply #24 on: Wed, 27 November 2013, 00:03:05 »
It's really hard to say since I did the other mods but overall I like it. Will be able to tell more next week when I get back to work.
But do recommend the lube kits to anyone interested in lube, very well packaged and comes with multiple sizes of syringe tips etc.
Offline Pacifist
  • on hiatus
« Reply #25 on: Wed, 27 November 2013, 12:31:34 »
Finally opened my lube kit, and I spilled it all over the board  :p
cleaned it up tho, and its really nice.
the tools are nice, but do you have anything to get inside of the stem where it meets the spring?
Offline MKULTRA
  • telling it how it is
« Reply #26 on: Wed, 27 November 2013, 13:02:00 »
A small paintbrush
Offline Pacifist
  • on hiatus
« Reply #27 on: Wed, 27 November 2013, 13:16:32 »
A small paintbrush
I'll try that, the one that came with it was a little unweildy
« Reply #28 on: Wed, 27 November 2013, 13:24:08 »
A small paintbrush
You might try a q-tip
Offline Pacifist
  • on hiatus
« Reply #29 on: Wed, 27 November 2013, 13:26:06 »
A small paintbrush
Q tip's nice to lube the springs, but for:
on the inside its hell
Offline HPE1000
  • Keycap Paparazzo
« Reply #30 on: Wed, 27 November 2013, 13:33:44 »
Can either of these lubes be used on the springs?
« Reply #31 on: Wed, 27 November 2013, 17:45:03 »
Just curious how in the world did you spill the lube all over your keyboard?
Offline Pacifist
  • on hiatus
« Reply #32 on: Wed, 27 November 2013, 18:06:29 »
First time I spilled it, I losened the cap, forgot it was only loosened, tried to squirt some out, applied force, and the tip and a lot of lube spilled onto the board.
Second time, I got the head on, but when I went to squeeze, I couldnt see when it came out so a bunch spilled
« Reply #33 on: Wed, 27 November 2013, 18:11:46 »
Were you using thick or thin?
Offline Pacifist
  • on hiatus
« Reply #34 on: Wed, 27 November 2013, 18:14:51 »
thick
« Reply #35 on: Wed, 27 November 2013, 18:20:41 »
thick
So did you end up using it all?
Offline Pacifist
  • on hiatus
« Reply #36 on: Wed, 27 November 2013, 18:23:27 »
thick
not yet. Opened it up to lube just the springs and some stabs. Got through a set of stabs and 2 switches. My binder clip switch opener decided to not work after a couple switches on my pcb mounted g80 so I didn't get to lube anything except for the spacebar.
Offline sherryton
  • Kībōdo
    • Originative
« Reply #37 on: Thu, 28 November 2013, 01:10:06 »
These are meant for springs.  We have not really tried these on stabilizers yet.
thick
Pacifist, was the spillage due to the packaging?  It does not seem like it, right?
Offline HPE1000
  • Keycap Paparazzo
« Reply #38 on: Thu, 28 November 2013, 01:15:25 »
So I could get the thick lube and lube the springs and sliders on mx clears and be good? Thanks for the help :)
Offline sherryton
  • Kībōdo
    • Originative
« Reply #39 on: Thu, 28 November 2013, 01:18:22 »
You will be extremely satisfied.
I lied, your fingers will be extremely satisfied.
Offline Pacifist
  • on hiatus
« Reply #40 on: Thu, 28 November 2013, 01:26:54 »
thick
its because im clumsy af
Offline HPE1000
  • Keycap Paparazzo
« Reply #41 on: Tue, 03 December 2013, 15:14:24 »
Oops, I was a bit slow  :-X When will more thick lube be in stock?
Offline sherryton
  • Kībōdo
    • Originative
« Reply #42 on: Tue, 03 December 2013, 19:54:17 »
We just requested more.  They should be on their way.
Offline HPE1000
  • Keycap Paparazzo
« Reply #43 on: Tue, 03 December 2013, 21:36:49 »
Yay! :D
    • Gray Designs
« Reply #44 on: Tue, 03 December 2013, 22:37:50 »
I'm a noob I thought thin was for sliders and thick was for stabilizers? Thanks
Offline jonathanyu
« Reply #45 on: Wed, 04 December 2013, 00:33:07 »
Thick lube is made for tactile switches where as thin lube is made for linear switches.
    • Gray Designs
« Reply #46 on: Wed, 04 December 2013, 00:34:50 »
So either would work w topre then?
Offline sherryton
  • Kībōdo
    • Originative
« Reply #47 on: Wed, 04 December 2013, 01:23:07 »
Yeah, either works.  Mkawa please chime in!  He tested them.  I'll send him a message.
    • Gray Designs
« Reply #48 on: Wed, 04 December 2013, 01:50:51 »
Thank you! I think I read in another post he recommended thick.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #49 on: Wed, 04 December 2013, 02:05:12 »
FOR MX SWITCHES:
i would not lube where the spring touches the cap of the stem. there is no wear there. the spring also does not touch the stem in a typical actuation, i wouldn't bother with that either. in fact, the only place i recommend lub is the either the slider or the housing side of the points at which the slider touches the housing. for linear switches, i recommend lubricating the front of the slider as well, the tendrils that actuate the gold crosspoints (they are lubed from the factory but with a silicone lube that just does not last long enough or provide the lubridicity for really smooth actuation), and the arc-face of a linear switch. i do not recommend lube anywhere else in an MX switch.
FOR TOPRE SWITCHES:
for a topre spring, you want to lube in a circle around the slider. use a very thick lube (the thick formula works reasonably well). the idea is to attempt to fill the gaps between the slider faces. this will _increase_ the resistance of the slider, but decrease the noise in that resistance w/rt to displacement. it will feel stiffer but smoother.
there is one more place to lube a topre switch, but it must be done BEFORE the previous step. using a very thin lube and a small gauge needle, insert several drops into the slider. the goal is to get the lube to migrate to the PCB and elastomers. the reason to do this is to increase the seal between the elastomer bottom faces and the PCB. in my testing i've seen a slight difference between the elastomer membrane of a 55g topre switch and an unlubricated elastomer. it's very slight, but the tactile bump gets a little bit of a boost from the improved seal between the elastomer edges and the pcb.
the sliders make the most dramatic difference in a topre switch. for those, only thick formula makes any difference at all, and again, it increases the force required to actuate the switch but makes that force curve smoother. if you don't want that, don't lube your topre switches. i haven't found any other way to affect the action of a topre switch with lubricant.
