Author Topic: Lube Kit (OG x GH)  (Read 22354 times)
Re: Lube Kit (OG x GH)
« Reply #50 on: Wed, 04 December 2013, 07:00:06 »
FOR TOPRE SWITCHES:
for a topre spring, you want to lube in a circle around the slider. use a very thick lube (the thick formula works reasonably well). the idea is to attempt to fill the gaps between the slider faces. this will _increase_ the resistance of the slider, but decrease the noise in that resistance w/rt to displacement. it will feel stiffer but smoother.
Could someone illustrate this point??
    • Gray Designs
« Reply #51 on: Wed, 04 December 2013, 11:25:28 »
FOR MX SWITCHES:
i would not lube where the spring touches the cap of the stem. there is no wear there. the spring also does not touch the stem in a typical actuation, i wouldn't bother with that either. in fact, the only place i recommend lub is the either the slider or the housing side of the points at which the slider touches the housing. for linear switches, i recommend lubricating the front of the slider as well, the tendrils that actuate the gold crosspoints (they are lubed from the factory but with a silicone lube that just does not last long enough or provide the lubridicity for really smooth actuation), and the arc-face of a linear switch. i do not recommend lube anywhere else in an MX switch.
FOR TOPRE SWITCHES:
there is one more place to lube a topre switch, but it must be done BEFORE the previous step. using a very thin lube and a small gauge needle, insert several drops into the slider. the goal is to get the lube to migrate to the PCB and elastomers. the reason to do this is to increase the seal between the elastomer bottom faces and the PCB. in my testing i've seen a slight difference between the elastomer membrane of a 55g topre switch and an unlubricated elastomer. it's very slight, but the tactile bump gets a little bit of a boost from the improved seal between the elastomer edges and the pcb.
the sliders make the most dramatic difference in a topre switch. for those, only thick formula makes any difference at all, and again, it increases the force required to actuate the switch but makes that force curve smoother. if you don't want that, don't lube your topre switches. i haven't found any other way to affect the action of a topre switch with lubricant.
Thank you for the informative post!
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #52 on: Wed, 04 December 2013, 14:55:20 »
FOR TOPRE SWITCHES:
« Reply #53 on: Wed, 04 December 2013, 15:03:21 »
FOR TOPRE SWITCHES:
:facepalm:
I meant this part
Offline frvrngn
« Reply #54 on: Wed, 04 December 2013, 15:12:50 »
Found this with photos for Topre - http://geekhack.org/index.php?topic=49741.0
Currently using: Cherry G80-1800 Ergo Clears, HHKB Pro 2, RF 87U Silent
« Reply #55 on: Wed, 04 December 2013, 15:14:19 »
Is that what mkawa means?? That's showing just lubing the sides, which is what I did, but with thick lube because that's what was recommended at the time but now it seems like maybe thing is?? I'm so confused.
Offline keymaster
  • Topre Revolution Theorist
« Reply #56 on: Wed, 04 December 2013, 15:14:28 »
^This is the only place I lubed. I'm also confused about this lubing a circle around the slider.
Offline frvrngn
« Reply #57 on: Wed, 04 December 2013, 15:15:53 »
Lets wait for him, that was the only guide I could find and it does sound like mkawa lubes more than just that area.  I cant imagine a smoother Topre but I may have to try this out!
Offline mkawa
« Reply #58 on: Wed, 04 December 2013, 15:16:46 »
oooh! that's simpler. sec.
« Last Edit: Wed, 04 December 2013, 15:22:11 by mkawa »
    • Gray Designs
« Reply #59 on: Wed, 04 December 2013, 16:06:10 »
Hmm mkawas way I wouldn't have to take the keyboard . Tough choice
« Reply #60 on: Wed, 04 December 2013, 16:10:00 »
GEEKHACK IS ABOUT UNDERSTANDING SCIENCE DAMNIT.
I would like to know how scientific a measurement "a scosh" is Ming :P. Glad you're sharing the secrets of Topre lubing hehe.
« Reply #61 on: Wed, 04 December 2013, 16:15:28 »
Ok so your basically saying the lube needs to go between the round shaft and the switch housing right?
I believe realforce may come lubed like that on some keys...make sense now.
Offline keymaster
« Reply #62 on: Wed, 04 December 2013, 16:24:32 »
That's only one part of his lubing process. Apparently, it's supposed to be done after this step:
Offline Dubsgalore
« Reply #63 on: Wed, 04 December 2013, 20:33:01 »
I think i'll be getting a kit when i order some more springs, I like how it's premixed already
let's just hope the packing is a little less sloppy as well, my beta package wasn't the cleanest one :P
« Reply #64 on: Wed, 04 December 2013, 23:36:13 »
I need to get some thick to lube my alphameric. I think the mineral oil I used a while ago has probably worn off.
« Reply #65 on: Thu, 05 December 2013, 06:27:20 »
let's just hope the packing is a little less sloppy as well, my beta package wasn't the cleanest one :p
These baby's are vacuum sealed!
^^ That is what he is illustrating....I thought.... ???
Offline jefferai
« Reply #66 on: Sun, 08 December 2013, 13:01:40 »
Any idea when the thick kit will be back in stock?
(And the 62g limited springs?  :)
Offline HPE1000
  • Keycap Paparazzo
« Reply #67 on: Sun, 08 December 2013, 13:08:44 »
Hopefully soon, I have a board I am putting together soon that is going to need the thick lube and 67g springs(which are still in stock but I am scared they might sell out by the time thick is back in stock)  :blank:
Offline jefferai
« Reply #68 on: Sun, 08 December 2013, 13:26:49 »
Yeah, I was stupid and didn't place my order, and by the time I went back both the 62g limited and thick lube were our of stock.
Offline mkawa
« Reply #69 on: Sun, 08 December 2013, 13:28:49 »
originative will have thick kits in stock late monday. they were shipped saturday :)
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
« Reply #70 on: Sun, 08 December 2013, 13:32:32 »
Ty for the update! :)
Very busy with studies atm.
Offline Pacifist
  • on hiatus
« Reply #71 on: Sun, 08 December 2013, 13:36:20 »
I may have to buy more lube, I think I'm overdoing it. Perfect opportunity
« Reply #72 on: Sun, 08 December 2013, 13:59:30 »
Will have to pick up some thick sometime, so I can lube my alphameric.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #73 on: Sun, 08 December 2013, 14:19:31 »
What bout 62g limited springs ? Sorry if this is out of topic.
I'd like to bundle together with the thick lube.
Offline mkawa
« Reply #74 on: Sun, 08 December 2013, 16:12:04 »
no, i think there's something misunderstanding here. i would generally do a one step lubing on a 55g topre switch. i would just lube the slider as illustrated and then stop. if you have lighter switches, you FIRST want to get a bit of THIN lube onto the elastomer under the slider. it's a huge pita and i don't think there's really enough tactile difference to make it worth it, but it does feel a bit better for what it's worth. THEN you lube the slider as it was lubed from the factory (circle around the slider). always do that last.
http://www.urbandictionary.com/define.php?term=skosh&defid=568284
a skosh is to be taken as less than measurement tolerance.
« Last Edit: Sun, 08 December 2013, 16:18:00 by mkawa »
Offline jefferai
« Reply #75 on: Sun, 08 December 2013, 16:19:41 »
I want that exact set too :-)
    • Gray Designs
« Reply #76 on: Sun, 08 December 2013, 21:29:28 »
I hope you get more thick soon!  :thumb:
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #77 on: Sun, 08 December 2013, 22:00:05 »
+1. I've bought some 205 in the meantime, but I'm rather just buy from Originative :).
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #78 on: Mon, 09 December 2013, 21:56:33 »
@Sherry. Any updates on this ?
Offline sherryton
  • Kībōdo
    • Originative
« Reply #79 on: Tue, 10 December 2013, 13:26:39 »
62g Limited is OOS.
Subscribers got an e-mail last night, but we restocked on the thick stuff  :thumb:
« Reply #80 on: Tue, 10 December 2013, 13:37:46 »
62g Limited is OOS.
I'm subscribed but got no email :(
Offline sherryton
  • Kībōdo
    • Originative
« Reply #81 on: Tue, 10 December 2013, 14:04:19 »
62g Limited is OOS.
Odd... I'll go see what is wrong.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #82 on: Tue, 10 December 2013, 14:25:04 »
62g Limited is OOS.
Any ETA for 62g limited spring ?
Offline Jrwestcoast
« Reply #83 on: Tue, 10 December 2013, 14:27:34 »
I'm subscribed also but got no email :(
Offline Signature
  • master of puppers
  • snoozing
« Reply #84 on: Tue, 10 December 2013, 14:36:42 »
62g Limited is OOS.
He told me via Pm that they will not restock them :(
Offline Pacifist
  • on hiatus
« Reply #85 on: Tue, 10 December 2013, 16:17:50 »
never ever? 65 g better not sell out, I'm thinking of shifting to something heavier in the far future
« Reply #86 on: Tue, 10 December 2013, 16:23:15 »
better get em while they are hot
Offline Pacifist
  • on hiatus
« Reply #87 on: Tue, 10 December 2013, 16:24:22 »
well I do need more lube...and I forgot to get a GH key last time...........
descicions descisions desccisons
« Reply #88 on: Tue, 10 December 2013, 16:27:55 »
I've put the note about  the geekhack key a few different orders now and nothing... :(
Offline Pacifist
  • on hiatus
« Reply #89 on: Tue, 10 December 2013, 16:32:13 »
the one time I bought stuff from sherry(lube, springs, puller) I forgot to put the GH key note but I did get a hand written thank you note....
« Reply #90 on: Tue, 10 December 2013, 16:34:23 »
what the crap.....I've bought all sorts of stuff I never got a note!! and I've put comments in the comment box every time
Offline HPE1000
  • Keycap Paparazzo
« Reply #91 on: Tue, 10 December 2013, 16:49:10 »
What GH Key???
Offline Pacifist
  • on hiatus
« Reply #92 on: Tue, 10 December 2013, 16:52:12 »
It might have been because I spammed sherry about lube for 2 weeks before the lube was released, or sherry was feeling merry. Anyways I still have the note  :-*
Offline Grendel
« Reply #93 on: Tue, 10 December 2013, 23:41:35 »
62g Limited is OOS.
Ditto.
- I'm game !
Offline pasph
« Reply #94 on: Wed, 11 December 2013, 05:07:05 »
62g Limited is OOS.
Ditto.
this
    • Gray Designs
« Reply #95 on: Mon, 13 January 2014, 13:34:47 »
Will you be getting thick soon? :) Thanks!
« Reply #96 on: Mon, 13 January 2014, 13:36:20 »
That's rude. It's not polite to imply that Sherry is getting fat. :P
    • Gray Designs
« Reply #97 on: Mon, 13 January 2014, 13:37:52 »
 :p
    • Gray Designs
« Reply #98 on: Sat, 25 January 2014, 12:07:00 »
When will more thick be in stock pleasssse?  :cool:
Offline mkawa
« Reply #99 on: Sat, 25 January 2014, 12:10:07 »
i am packing them up today and will run them by originative most likely on monday.
i am very aware of how long people have been waiting and have a special (DOMOOOOO) present for everyone that i will include in the kits :)
