Author Topic: Ultimate Profile  (Read 14124 times)
Offline rknize
    • metaruss
Ultimate Profile
« on: Fri, 12 July 2013, 10:59:18 »
You may have noticed some changes to your user profile page.  I've integrated some nice enhancements that you can configure via "Ultimate Profile" in your profile settings.  Once enabled, you can share a description of yourself, your keyboards, your projects, pictures, etc.  You can also add buddies and other users can leave comments on your profile.
Enjoy!
Russ
Offline esoomenona
  • Gnillort?
Re: Ultimate Profile
« Reply #1 on: Fri, 12 July 2013, 11:06:35 »
Could you possibly link to or explain how to get there? I've spent much time in the settings, but I can't seem to find that option...
« Reply #2 on: Fri, 12 July 2013, 11:07:16 »
Me also..
Offline rknize
    • metaruss
« Reply #3 on: Fri, 12 July 2013, 11:11:42 »
Might take a moment for the permissions to take effect.  Here is the direct link:
http://geekhack.org/index.php?action=profile;area=customized
Russ
Offline i3oilermaker
  • techkeys.us
    • TechKeys
« Reply #4 on: Fri, 12 July 2013, 11:13:22 »
I don't see how to add buddies
« Reply #5 on: Fri, 12 July 2013, 11:14:34 »
I can see it now. Looking good. Thanks rknize :D
What's planned for the 'position' bit? Everyone is 'senior' at the moment.
« Reply #6 on: Fri, 12 July 2013, 11:18:43 »
Do you just modify profile and edit buddies?
Offline rknize
    • metaruss
« Reply #7 on: Fri, 12 July 2013, 11:19:28 »
Oh, that is what is used to limit classifieds posting.  I removed it from the old profile and I'll probably do the same here.
Not sure about the buddies thing.  I'll take a look.
Keep reporting bugs and I'll sort them out soon.  The package is a little long-in-the-tooth, but is the best I could find for SMF.  I fixed all of the obvious problems, but I guess I didn't try everything.
Russ
« Reply #8 on: Fri, 12 July 2013, 11:27:19 »
Ok so can comments be deleted because I've already 'double posted' on someone's profile! :P
Leave it me to do that.....
Offline esoomenona
  • Gnillort?
« Reply #9 on: Fri, 12 July 2013, 11:33:20 »
They can be, and that double post is already deleted.
LOL, that was my exact thought as well! :D
rknize, is there a way that the notifications for comments can be separate from PMs?
Offline rknize
    • metaruss
« Reply #10 on: Fri, 12 July 2013, 11:37:45 »
OK, so to add a buddy you are supposed to go to that person's profile and click "Add to Buddy List" under "Contact Me".
Russ
Offline rknize
    • metaruss
« Reply #11 on: Fri, 12 July 2013, 11:41:39 »
It would not appear so, but you can disable them with "Disable new comments notification".
Russ
Offline Tym
« Reply #12 on: Fri, 12 July 2013, 12:32:26 »
Can we have something which shows you which button to press to accept a buddy request? Its kinda hard to work out which one it is, without hovering over each of the options?
Cheers!
« Reply #13 on: Fri, 12 July 2013, 12:35:04 »
It would be really cool if the 'reply' in the comments quoted the first comment otherwise it makes no sense.....
Offline rknize
    • metaruss
« Reply #14 on: Fri, 12 July 2013, 13:28:31 »
I just noticed this...some sort of template problem in the table makes it impossible to read.
Russ
Offline rknize
    • metaruss
« Reply #15 on: Fri, 12 July 2013, 13:30:21 »
I think the intent is to do it more like a blog post, but a "reply with quote" option would be nice.
Russ
Offline Photoelectric
« Reply #16 on: Fri, 12 July 2013, 13:45:52 »
Enjoy!
Is there any way to add Overclock.net-style rig-builder-like function to be able to be more descriptive about our keyboard projects?  For example, I'd like to write a blurb for each of my keyboards with photos--like a "build log", and it'd be best to have a dedicated section rather than link a thread from elsewhere.
« Reply #17 on: Fri, 12 July 2013, 13:47:35 »
There's an entire section called "Interests". Couldn't you just put it there? Or under "Media" where it even supports HTML/CSS?
« Reply #18 on: Fri, 12 July 2013, 13:50:20 »
I saw that, but the edit window is small (thought could be increased), so it looked like it's for something concise.  If it's okay to put longer stuff there, that's cool then!
Offline rknize
    • metaruss
« Reply #19 on: Fri, 12 July 2013, 14:07:26 »
The size limit is 65,535 characters, so you should be good.  I tested really long posts there and they worked fine.  The only issue was that the section displays in its entirety without scroll bars.  That is something I could add if they get too unwieldy.
« Last Edit: Fri, 12 July 2013, 14:09:01 by rknize »
Russ
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #20 on: Fri, 12 July 2013, 14:23:15 »
 :-X
(Krog begins a new post.)
"Well, prince, Genoa and Lucca are now no more than private estates of the Bonaparte family."
Quote from: Samuel Adams
Offline The_Ed
  • Asperger's... SQUIRREL! I'm Anal Retentive *****!
« Reply #21 on: Fri, 12 July 2013, 17:43:02 »
My buddy list has been wiped, and the text box to add them back in is missing...
Reaper "frelled" me... Twice... Did he "frell" you too?... *brohug*
I'm camping for a week, and moving twice in a month. I'll get back to you when I can (If I don't then just send me another PM).
R.I.P.ster
« Reply #22 on: Fri, 12 July 2013, 19:28:09 »
there is too much open space in these new profiles. it looks sloppy IMO
« Reply #23 on: Fri, 12 July 2013, 20:05:47 »
rkinze, can you explain how the "Media" Box works. I just spent 20 minutes trying to get a picture to work in there. HTML and BBcode apparently dont work.
Offline esoomenona
  • Gnillort?
« Reply #24 on: Fri, 12 July 2013, 20:36:14 »
Do you know if this is supposed to work on all themes at the moment? I switched from Austere to Thoriated and no more profile stuff...
« Reply #25 on: Fri, 12 July 2013, 20:38:32 »
You have to go enable it now in the aforementioned place
Offline esoomenona
  • Gnillort?
« Reply #26 on: Fri, 12 July 2013, 21:00:31 »
Ah, thanks. May the MY switches bless your fingers.
Offline rknize
    • metaruss
« Reply #27 on: Fri, 12 July 2013, 22:21:13 »
OK, I've reimplemented the "Add Buddies" feature to the buddies list and fixed some UI issues in there.  The way old buddies were stored is wildly different that the new ones, so unfortunately anyone using that feature will need to re-add those people.  Sorry about that.
Russ
Offline rknize
    • metaruss
« Reply #28 on: Fri, 12 July 2013, 22:28:42 »
Really?  I just pasted some HTML in there and it seems to work.  Anyone else having this issue?
Russ
Offline esoomenona
  • Gnillort?
« Reply #29 on: Fri, 12 July 2013, 22:36:28 »
I don't think CPTNoobAss knows how to HTML. Seems to work just fine for me.
« Reply #30 on: Fri, 12 July 2013, 22:36:56 »
He's so new.
Offline esoomenona
  • Gnillort?
« Reply #31 on: Fri, 12 July 2013, 22:37:40 »
Remember that time when he didn't know what APL was?
« Reply #32 on: Fri, 12 July 2013, 22:39:22 »
Associated Press Language?  American Psychiatric Licensing?  A Pretentious Loser?
« Reply #33 on: Fri, 12 July 2013, 22:40:51 »
no it's a programming language
« Reply #34 on: Fri, 12 July 2013, 22:41:45 »
Yeah, but which one?
Offline esoomenona
  • Gnillort?
« Reply #35 on: Fri, 12 July 2013, 22:41:51 »
It's okay, noobbinator. Everyone is new at some point...
« Reply #36 on: Fri, 12 July 2013, 22:42:46 »
Offline esoomenona
  • Gnillort?
« Reply #37 on: Fri, 12 July 2013, 22:43:52 »
Hey, Sifo. Remember that time that noobbinator didn't know what APL was either, and tried to make it seem like he was just joking?
« Reply #38 on: Fri, 12 July 2013, 22:44:57 »
So many memories
« Reply #39 on: Fri, 12 July 2013, 22:50:04 »
* CPTBadAss shrugs
I guess I'm bad at HTML and if I can't figure it out in 30 minutes, I don't care. Maybe add some bbcode? Because it was frustrating. Sorry I'm bad at computers.
Offline esoomenona
  • Gnillort?
« Reply #40 on: Fri, 12 July 2013, 22:56:32 »
Try this for images: <img src=URL>
Offline rknize
    • metaruss
« Reply #41 on: Fri, 12 July 2013, 22:58:03 »
It should support BBcode, though I haven't tried it.
To put an image in there with HTML, you would:
Code: [Select]
<img src="http://somehere.net/myimage.jpg">
Russ
« Reply #42 on: Fri, 12 July 2013, 23:00:08 »
bbcode was the first thing I tried. It just displays the code. For example, if I wanted to link an image, it will say
Code: [Select]
[img]http://yourimg.jpg[/img] instead of a picture.
Offline Rayne
  • For Science!
« Reply #43 on: Sat, 13 July 2013, 02:17:06 »
awesome feature to add, it looks really nice!
so.. who wants to be my buddy? :D
« Reply #44 on: Sat, 13 July 2013, 03:09:22 »
Aww, super awesome ultimate profile looks like it's back to normal profile.
« Reply #45 on: Sat, 13 July 2013, 06:23:20 »
Just go to profile > Modify Profile > Ultimate Profile and check the box to turn it on. I believe it was on by default at first.
Offline esoomenona
  • Gnillort?
« Reply #46 on: Sat, 13 July 2013, 08:41:50 »
It should be on by default with the option to turn it off.
« Reply #47 on: Sat, 13 July 2013, 08:45:15 »
I agree as it's awesome...but
Probably rustled too many jimmies....
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #48 on: Sat, 13 July 2013, 10:09:04 »
Can someone please test the video link in my Ultimate Profile? Kthanxbi.
« Reply #49 on: Sat, 13 July 2013, 10:10:22 »
I love that video!!....too bad I don't have flash installed....;)
