Are your eyes bleeding? You can always change your theme.
these are called lead formers. they're little plastic jobbies straight lengths followed by a 90o angle. get two if you want to do both sides at once. they are very inexpensive, being extremely simple non-precision tools.
Quote from: mkawa on Mon, 14 April 2014, 20:56:16these are called lead formers. they're little plastic jobbies straight lengths followed by a 90o angle. get two if you want to do both sides at once. they are very inexpensive, being extremely simple non-precision tools.this?http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=106884
Just faster? Is there other reason?
Quote from: quochung1989 on Tue, 15 April 2014, 10:04:56Just faster? Is there other reason? pliers can damage the leads. i just use my hands to be honest, but lead formers are really cheap so i should probably get one XD
http://www.ebay.com/itm/161253327236
Quote from: jdcarpe on Tue, 15 April 2014, 10:56:44http://www.ebay.com/itm/161253327236There we go. GB and tour it.
After looking at some of the links I am still going to at least make one for myself. Though I won't be including the top half. Just the bottom half and bend them over with my fingers. Would anyone be interested in this?
Quote from: Melvang on Tue, 15 April 2014, 17:12:10After looking at some of the links I am still going to at least make one for myself. Though I won't be including the top half. Just the bottom half and bend them over with my fingers. Would anyone be interested in this?I would. Depending on price of course.
Quote from: mashby on Tue, 15 April 2014, 18:19:05Quote from: Melvang on Tue, 15 April 2014, 17:12:10After looking at some of the links I am still going to at least make one for myself. Though I won't be including the top half. Just the bottom half and bend them over with my fingers. Would anyone be interested in this?I would. Depending on price of course. ^^ what he said
Quote from: SpAmRaY on Wed, 16 April 2014, 06:08:52Quote from: mashby on Tue, 15 April 2014, 18:19:05Quote from: Melvang on Tue, 15 April 2014, 17:12:10After looking at some of the links I am still going to at least make one for myself. Though I won't be including the top half. Just the bottom half and bend them over with my fingers. Would anyone be interested in this?I would. Depending on price of course. ^^ what he said Where? Ray
