Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 3532922 times)
Offline combataran
« Reply #7400 on: Tue, 22 April 2014, 09:31:57 »
Do new MX Blacks sound like this with 65g springs?
http://www.youtube.com/watch?v=PMIkwKgKFhc&list=UUi51LUI0D43OeR7zju-NM5g
The sound really depends on the case, caps, if you bottom out or not, material under the case and if there is a dampening mat inside.
Well what makes this particular board sound that good? That sound signature is what I'm shooting for, on a KMAC to be specific.
Cherry G80-1000HFD | CM Storm Spawn | Keypuller.com - Key Caps News & Database
Offline BlueBär
« Reply #7401 on: Tue, 22 April 2014, 09:35:59 »
Hard to say. Seems like he doesn't bottom out hard, and he probably has some sort of dampening mat inside the case. Looks like the case is also sitting on a sort of mousepad. The metal case is also of course a big factor.
« Reply #7402 on: Tue, 22 April 2014, 09:38:01 »
You told me you don't like the KMAC2, which has a similar design to that LZ-CE. But I think that block shaped case contributes to the sound signature. I'm not sure my KMAC LE would sound the same if I put the Blacks in it.
Offline combataran
« Reply #7403 on: Tue, 22 April 2014, 09:41:01 »
So the sound isn't totally dependent on the switches themselves? What a relief. Even his RF and RF10AE sound really silent(soothingly), even less so than his HHKB-S lubed with what, krytox 104?
« Reply #7404 on: Tue, 22 April 2014, 09:43:42 »
No. I agree with BlueBar with the factors that contribute to the sound of switches.
His HHKB-S lubed with what, krytox 104?
You can lube your Topre switches with the Krytox lube mixes from Techkeys.us or Originativeco.com. On GH, those Krytox mixes are the most popular option, I think, for lubing switches.
« Last Edit: Tue, 22 April 2014, 09:46:40 by CPTBadAss »
Offline combataran
« Reply #7405 on: Tue, 22 April 2014, 10:30:36 »
Thin or thick?
« Reply #7406 on: Tue, 22 April 2014, 14:47:40 »
Thin or thick?
I think mkawa said thick but you better double check.
Offline Zeal
    • Zeal Generation Inc.
« Reply #7407 on: Tue, 22 April 2014, 16:22:28 »
I believe mkawa developed the "super thick" lube for Topre switches.
« Reply #7408 on: Tue, 22 April 2014, 19:09:13 »
I have received my new barrel plate from unicomp.  Would it be OK if I get it warm with water while forming it to the backplate?  I am paranoid about cracking the new one.
It shouldn't hurt anything, but all the new barrel plates I've dealt with have been just fine.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #7409 on: Tue, 22 April 2014, 19:32:10 »
Thanks for the info.  Mkawa confirmed this as well.  I would assume for the actual install it goes the same as bolt modding the original?
Offline Pacifist
  • on hiatus
« Reply #7410 on: Tue, 22 April 2014, 23:48:29 »
2 questions
1. Breaking in clears before lubing-Myth or legit?
2. Lightest spring to use with clears with lube before it does sticky action.
Offline Melvang
« Reply #7411 on: Tue, 22 April 2014, 23:51:25 »
2 questions
1.  I believe both.  I think it has an effect but it would take so long to get past any sort of "break in" period to have a noticeable effect that it would be moot.
2.  I am using stock Cherry springs from browns with clear stems lubed with a fairly thing Krytox mix only on the sides of the slider and have zero issues with sticking using imso thick PBT.  Though spacebar was stock clear spring.
Offline Pacifist
  • on hiatus
« Reply #7412 on: Tue, 22 April 2014, 23:53:18 »
2 questions
1. Im going to use the clears from those POS boards from ebay, hopefully those are broken in enough.
2. Would 55g korean be lighter or heavier than browns?
Offline Melvang
« Reply #7413 on: Tue, 22 April 2014, 23:59:35 »
2 questions
1.  I don't see how they can't be if the board has been in service.
2.  I believe that they are just a touch heavier.  I could be wrong though.  But remember that korean springs are at bottom and Cherrys listings are at actuation.
Offline BlueBär
« Reply #7414 on: Wed, 23 April 2014, 02:23:38 »
55g should be a bit lighter than browns. The light cherry springs are around 60g (bottom out).
Offline phoenix1234
« Reply #7415 on: Wed, 23 April 2014, 02:59:04 »
55g Korean springs are good for Cherry MX Brown. I have tried 55g Korean spring from Originative and used them on Cherry MX Brown collected from G80. From what I feel, the springs are lighter than the Cherry MX default light spring but it brings better results : the tactile is more obvious.
However, the 55g is too light for Cherry MX Clear unless you have very old Vintage Cherry MX Clear whereas the white stem turned into yellow and the tactile degraded significantly. In that case, the MX Clear has similar tactile force as Cherry MX Brown so that we can use 55g spring on them.
I like linear switches
« Reply #7416 on: Wed, 23 April 2014, 07:10:59 »
2 questions
1) Everything wears so you could wear away the friction points before lubing but I'm not sure how long it would take to get you to your desired wear state. Personal testing is probably needed.
2) I've tried lubed 55g that didn't stick and ones that did stick. Mistakemistake had new lubed 55g clears that were fine. But I've tried more boards with missed clears that stuck than didn't. Seems to me 62g it's the lowest is want to go. And I prefer 65g or MX blacks.
Offline intelli78
« Reply #7417 on: Wed, 23 April 2014, 10:28:01 »
I'm getting a Duck Mini V2 shortly that has 59g unlubed (afaik) ergo clears. Odd spring strength, I am interested to see whether I have to replace them.
Anyway, my question is: what type/size of screw/bolt is used to hold the Duck Mini V2 riser onto the keyboard? I haven't been able to find any good pics. It almost looks like a square head (?)
Offline cannonking
« Reply #7418 on: Wed, 23 April 2014, 11:36:26 »
What is the difference between a 'limited' spring and a normal spring here?
http://www.originativeco.com/collections/accessories/products/springs
« Reply #7419 on: Wed, 23 April 2014, 11:38:42 »
From this thread, the limited springs should have a tighter tolerance and less spring weight variation between each spring.
Offline Zeal
« Reply #7420 on: Wed, 23 April 2014, 12:31:08 »
I don't have a Duck Mini V2, but those "square head" screws are Robertson's, which are almost exclusively used in Canada due to patents and such. Perhaps someone who has one can chime in. From the look of pictures with the fixing bolts on the side, I'm going to say that it uses Hex screws.
Offline ajx
« Reply #7421 on: Wed, 23 April 2014, 13:44:25 »
is there any 60 size with dedicated arrows on the right bottom of keyboard?
Offline intelli78
« Reply #7422 on: Wed, 23 April 2014, 13:45:55 »
FC660M/C is the closest, Poker X kind of (FN+space toggles the modifier cluster to work as arrow keys).
« Reply #7423 on: Wed, 23 April 2014, 13:49:41 »
Pure Pro and Filco miniLA as well
QFR | MJ2 TKL | "Bulgogiboard" (Keycon 104) | ctrl.alt x GON 60% | TGR Alice | Mira SE #29 | Mira SE #34 | Revo One | z | Keycult No. 1 | AIS65 | First CW87 prototype | Mech27v1 | Camp C225 | Duck Orion V1 | LZ CLS sxh | Geon Frog TKL | Hiney TKL One | Geon Glare TKL
Offline ajx
« Reply #7424 on: Wed, 23 April 2014, 13:53:40 »
I got Pure Pro but faulty keyboard and layout was awful to get used to type on.
I would rather stay on ANSI if possible
Offline stancato9
« Reply #7425 on: Wed, 23 April 2014, 14:29:28 »
Does anyone know if there's a male usb a connector on ebay that's plastic housing is big enough to put a sleeved cable though? The ones I have right now are way too small. Thanks. :thumb:
Poker 2 - MX Red
Offline BlueBär
« Reply #7426 on: Wed, 23 April 2014, 15:14:25 »
I did this:
62137-0
Looks pretty good and seems to hold quite well.
Offline ajx
« Reply #7427 on: Wed, 23 April 2014, 16:02:41 »
I use desk lamp to light keyboard but i want to know it might damage keyboard (i have also white keyboard)? i have basic desk lamp and its pretty hot in there
« Reply #7428 on: Wed, 23 April 2014, 16:03:25 »
Should be fine.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #7429 on: Wed, 23 April 2014, 16:52:19 »
I did this:
This is what I was planning to do for mine as well...
Offline jonathanyu
« Reply #7430 on: Wed, 23 April 2014, 17:44:40 »
The pbt set that sold on originative has a profile or b profile bottom row?
« Reply #7431 on: Wed, 23 April 2014, 18:55:27 »
IIRC b profile
Offline ajx
« Reply #7432 on: Thu, 24 April 2014, 06:33:34 »
I ve seen on my Poker II there are poling rate settings, whats the purpose?
Meaning if i enable the lowest amount, should i become to type faster?
Offline BlueBär
« Reply #7433 on: Thu, 24 April 2014, 06:48:13 »
Polling is basically how often the keyboard and the PC exchange data, the higher it is the more often data is exchanged and the less "lag" between pressing the key and it getting registered by the PC occurs. However, even fairly low polling rates are enough for keyboards, it is more important for mice.
Offline ajx
« Reply #7434 on: Thu, 24 April 2014, 06:52:09 »
Are you telling me they added usuless features? lol
Yes that what i thought, it does not feel necessary since you can type way faster with mechanical keyboard than anything else
Offline BlueBär
« Reply #7435 on: Thu, 24 April 2014, 07:16:09 »
Well it's useful for marketing I guess :))
That is not necessarily true. If you would have a keyboard with less than 2mm travel until actuation you can in theory be faster. So you could be typing a lot faster on something like a touchscreen than on a mechanical keyboard, but we all know that is not really true and doesn't feel nearly as good :thumb:
Offline b7ad
  • ゆめうつつ
    • mechblog
« Reply #7436 on: Thu, 24 April 2014, 14:06:36 »
Does anyone have a 'default' .map file for a GON NS 38 GT? Had some troubles mapping.
« Last Edit: Thu, 24 April 2014, 16:32:31 by b7ad »
Offline b7ad
  • ゆめうつつ
    • mechblog
« Reply #7437 on: Thu, 24 April 2014, 16:32:15 »
Offline intelli78
« Reply #7438 on: Thu, 24 April 2014, 16:47:54 »
Is there a 60%+numpad custom board? Like a lightsaver, but without the function keys?
« Reply #7439 on: Thu, 24 April 2014, 16:51:24 »
That new Chinese "Red Scarf II"
« Reply #7440 on: Thu, 24 April 2014, 16:53:44 »
What jdcarpe said or I think there was one from the DT custom build thread. But I can't remember 100%. You'll have to doublecheck yourself. This thread might also have some information.
Just edit your previous post. Please don't double post.
Offline intelli78
« Reply #7441 on: Thu, 24 April 2014, 16:56:22 »
Interesting, thanks!
Offline nuclearsandwich
« Reply #7442 on: Thu, 24 April 2014, 17:48:03 »
I will post one when I get home. I think I have a Poker II-ish layout.
Offline b7ad
  • ゆめうつつ
    • mechblog
« Reply #7443 on: Thu, 24 April 2014, 18:37:51 »
Thanks so much that would be extremely helpful! I haven't used this software before and stupidly managed to delete the whole layout and upload it to the keyboard so nothing works now - and when I try to remap the keys it seems like only sometimes it works, I don't know. Spent hours messing with the software anyway trying to fix it and I'm pretty fed up at this point!
« Reply #7444 on: Thu, 24 April 2014, 18:48:43 »
Yeah, I learned pretty early on in messing with layouts to always have a QFR (or equivalent keyboard you can't screw with) on hand in the event of excess humanity.
Offline Melvang
« Reply #7445 on: Thu, 24 April 2014, 23:26:14 »
Was there ever a Model F that had the inverted T arrow key layout?
« Reply #7446 on: Fri, 25 April 2014, 00:28:30 »
PM'ed you a matrix file but since both my Aikon boards are out of the house right now I have no real way of verifying it. Tomorrow I'll bring one home and double check everything but I have no Windows at work so I can't get it to you until I return. Why isn't there time travel yet?
Offline intelli78
« Reply #7447 on: Fri, 25 April 2014, 00:30:03 »
Nope, the closest thing is the arrow cluster on the F122.
Offline Melvang
« Reply #7448 on: Fri, 25 April 2014, 00:54:30 »
Alright thanks.  That is the 5 key plus sign layout right?
Offline Pacifist
  • on hiatus
« Reply #7449 on: Fri, 25 April 2014, 00:55:19 »
yup
