Author Topic: [IC] Star Wars faction key set  (Read 37835 times)
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« on: Fri, 14 September 2012, 02:19:35 »
f/64 made some nice looking mock ups for a potential Star Wars faction key set:
The top two are mandalorian raiders in colors from Boba Fett, the second row is Jedi and Sith logos, and the 3rd is Empire and Republic logos. We would potentially have them done at QWERKeys in the same style as their Team Liquid cap that was capable of having a lot more detail to it than the Team Liquid double shot from SP. I believe it is laser infilled J series Row 1 (Esc, Function, Numbers).
At the moment I am unsure of pricing for the J series, but the K series of large spherical keys were close to the following per key:
50 keys $3.25 each
100 keys $2.50 each
200 keys $2.20 each
400 keys $2.05 each
If the J series is similar and we get into the 100 key range I imagine it would cost $15 roughly for a full set of 6 keys. J series might also be cheaper. It may also be possible to do each key individually if people don't want it as a set.
The logos may also need to be simplified to be completed by QWERKeys, or getting dyesubs from imsto. I'm obviously open to opinions to see where the interest check takes us.
Where do you come in? Write what you would be interested in buying, and give alternative suggestions. Maybe only one Mandalorian raider key and make it a set of 5? Maybe there are other factions in Star Wars we want keys for and it should be an 8 key set?
Update 10-15-12est - mock up key pr0n:
« Last Edit: Sun, 14 October 2012, 23:59:08 by danielucf »
Offline i3oilermaker
  • techkeys.us
    • TechKeys
« Reply #1 on: Fri, 14 September 2012, 02:47:43 »
Those mockups have a lot of detail for qwer's process.  I would think to achieve that level of detail dyesub may be the only option.
Offline tsangan
  • 1000/600
Re: [IC] Star Wars faction key set
« Reply #2 on: Fri, 14 September 2012, 03:08:17 »
with QWER you're only going to get outline at best some you might not get anywhere even close to it
Keyboardless
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #3 on: Fri, 14 September 2012, 03:34:33 »
I have seen simplified versions of some of these icons and they still look good and are instantly recognizable. I'm not hooked on using QWERKeys, in fact I would want to utilize what ever would give everyone the best looking key set. This is the reason we do an interest check in the first place. Maybe we don't have enough Star Wars interest to do it, have to wait and see.
Offline Acanthophis
« Reply #4 on: Fri, 14 September 2012, 04:42:07 »
I am definitely interested, but those are some very fine details.
I doubt this can be done, not even with dyesubs.
I'm happy to be proven wrong, though.
Offline Mugen
  • O-Rings are the murderers of keyboard souls
« Reply #5 on: Fri, 14 September 2012, 07:35:54 »
I am 100% in for anything Starwars related.
Offline voightkampffme
« Reply #6 on: Fri, 14 September 2012, 08:57:52 »
Interested!
Offline OrangeJewce
  • ssk.ℜ
  • King of the Jewce
« Reply #7 on: Fri, 14 September 2012, 09:18:46 »
+1!
Cheers,
IBM Model M 1390120, Otaku Unicomp+RGB, CM QFR Green, Ducky YOTD Red, SSK MKII,
ErgoDox Blue, ErgoDox White
Offline logomancer
« Reply #8 on: Fri, 14 September 2012, 09:56:54 »
I'm in.
Unicomp Ultra Classic USB | Lexmark Model M 52G9658 | IBM Model M 1391401 (broken) | Rosewill RK-9000 | CMStorm QF Rapid (Blue)
Offline reaper
« Reply #9 on: Fri, 14 September 2012, 10:03:43 »
Not a big fan of Star Wars but these look cool.  In for a set.
Din Eli
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #10 on: Fri, 14 September 2012, 11:27:29 »
I would pick one of the Mandolorian keys, don't really need two. Jedi and Rebel would definitely need some simplifying for infilled keys. The Jedi starburst thing in the center looks like it would be a problem, and remove the circle and stars from the Rebel one and it would be fine. If go dyesubs, insane detail is possible and everything is fine then, but some of the color combinations are then impossible.
Definitely interested though. You should just make an order form now and if it has enough interest to move into payment stage half that work is already done.
Offline poopmat
« Reply #11 on: Fri, 14 September 2012, 11:36:40 »
Mandolorian keys are awesome
im in for @ lest 2
REΛLFORCE 103u, Ergodex DX1, IBM model M, Daskeyboard II, QFR brown,
Offline nebo
« Reply #12 on: Fri, 14 September 2012, 11:38:04 »
Interested in the Jedi one but would get all six if a set is the only option. If QWERkeys was used I'd prefer the J series just because the K series does stand out a bit, even if it is on an esc key.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #13 on: Fri, 14 September 2012, 11:43:45 »
I ordered the full metal alchemist keys which are imsto dyesubs so I'm quite interested in seeing them in person to see the quality. This may be the route we go if we want to maintain all the detail. Unless people really like engraved and infilled. I think a mandalorian key engraved infilled would be cool, but the others probably dyesub. However as a set I think I would potentially want them all to be identical, but a set of 4 keys (Sith, Jedi, Imperial, Republic) and a Mandalorian key, or double set separate could be good also.
Offline telepete
  • Jedi Knight and friend of Captain Solo.
« Reply #14 on: Fri, 14 September 2012, 11:48:20 »
The only thing I like more than imsto keys is Star Wars. 100% in.
Don't you wish Carnifex was at your side?
Offline DaClownie
  • Handsome Devil
« Reply #15 on: Fri, 14 September 2012, 13:01:12 »
Very interested.
Offline Kronen
« Reply #16 on: Fri, 14 September 2012, 14:23:19 »
I'm tentatively interested... would be moreso if SWTOR wasn't such a complete flop....  Oh well.
Interested in some O-Rings? Try mine: http://geekhack.org/index.php?topic=33329.0
Offline rayuki
  • RAAAAAAR
« Reply #17 on: Fri, 14 September 2012, 14:35:21 »
1million % in no matter what it looks like as long as it RESEMBLES the actual logo lol
can we do star trek as well :P
« Reply #18 on: Fri, 14 September 2012, 14:53:41 »
If the pricing does not change too much, I will buy at least three sets.
However, I would suggest that you get a red or blue Rebel Bird on white background instead of the New Republic logo. The bird is classic and more recognized.
BTW, member the_buff made better SVG files of the Imperial cog logo, after I had supplied him with a high-res shot of a screen-used helmet that had an original cog decal. These are more accurate to the original shape than in the mockup.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #19 on: Fri, 14 September 2012, 14:59:07 »
Add more keys and make it a whole f-row set.
Anyways in for at least one set.
Offline f/64
« Reply #20 on: Fri, 14 September 2012, 16:38:30 »
I also made this one just for giggles. I don't think there's any way to get it made though.
« Reply #21 on: Fri, 14 September 2012, 17:05:12 »
Not unless you can convince imsto to do an all over print like the spongebobs... but that would look slick with starfield down the sides too.
Offline f/64
« Reply #22 on: Fri, 14 September 2012, 17:07:33 »
I just left the bottoms white so there was some definition, otherwise it'd just be a black square.
Offline f/64
« Reply #23 on: Fri, 14 September 2012, 17:41:49 »
If a whole F row is wanted, we could break down the keys in to some characters.
The C3PO doesn't really match the same style as the R2D2, but just consider them place holders as an example for what the rest of the F row could look like.
« Last Edit: Fri, 14 September 2012, 18:30:18 by f/64 »
Offline JonDBurnett
« Reply #24 on: Fri, 14 September 2012, 18:29:34 »
anything star wars related? i'm certainly in for a set :D
Filco MJ2 TKL | HHKB Type-S w/ MX Sliders
  • techkeys.us
    • TechKeys
« Reply #25 on: Fri, 14 September 2012, 18:34:17 »
I'm starting to like the direction this is going :)
« Reply #26 on: Fri, 14 September 2012, 18:56:20 »
If it turns into a zillion key set I will be out. I would only use a couple, not really huge into novelty keys. If you are going to have a bunch, please don't force a set let pick and choose.
Offline Inochi
« Reply #27 on: Sat, 15 September 2012, 09:15:02 »
You can count me in for 2/3 sets. The fiance saw these and demanded them.
Offline bnp70kr
« Reply #28 on: Sat, 15 September 2012, 09:42:08 »
I'm surely in for a set.
Offline rindorbrot
« Reply #29 on: Sat, 15 September 2012, 11:22:24 »
I'm interested as long as the empire key is white on black...
Offline silat
« Reply #30 on: Sat, 15 September 2012, 12:28:33 »
Interested.......
Fighting the Christian American Taliban daily with my Deck Legend loaded with Cherry MX Clears //
Deck Legend Ice Clears // Deck Legend Frost Clears // Ducky Shining Purple Browns//QPAD MK85 Browns //
Offline daerid
    • Rossipedia
« Reply #31 on: Sat, 15 September 2012, 15:51:19 »
Having started the last Star Wars related IC thread that got shut down, I'll take whatever comes out of this thread
Offline noog
« Reply #32 on: Sat, 15 September 2012, 19:10:26 »
Interested.
« Reply #33 on: Sat, 15 September 2012, 22:57:58 »
I'm interested for obvious reasons. For all those that doubted my interest: I find your lack of faith disturbing.
Can we get an optional Dyesub empire and sith logos? I'm cool if the colours are reversed. The jedi and rebel should be left as thin ABS to further characterize their weakness.
Offline TheBackgammon
« Reply #34 on: Sun, 16 September 2012, 01:22:21 »
Interested. Possibly 2 sets minimum.
Offline JSaintS
  • Formerly eNrageDSainT
    • JSaintS
« Reply #35 on: Sun, 16 September 2012, 07:49:00 »
In for a set! :) now what exactly do you guys want as a final set? so I can get a clear idea of what I'll get =)
as I love SW I'll get a complete set anyway :)
Offline palindrome
« Reply #36 on: Sun, 16 September 2012, 17:14:17 »
Very much interested.
OG KBC Poker X (Brown)     Leopold FC660M (Brown)
Offline ZioExcalibur
« Reply #37 on: Sun, 16 September 2012, 19:45:33 »
Interested
Offline Scirocco
  • Not the usual grandma!
« Reply #38 on: Sun, 16 September 2012, 20:51:14 »
Definitely interested.
Offline Lukasevic
  • World Famous Gamer™
« Reply #39 on: Sun, 16 September 2012, 20:54:53 »
I like the mandalorian mock ups, very cool color and idea
Offline JSaintS
    • JSaintS
« Reply #40 on: Mon, 17 September 2012, 13:55:13 »
any ideas if we have enough person interested in it? and when will the orders begin?
« Reply #41 on: Mon, 17 September 2012, 13:56:27 »
Count me interested!
Offline eon
« Reply #42 on: Mon, 17 September 2012, 14:24:28 »
Interested too !
Poker MX Red - Photos
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #43 on: Mon, 17 September 2012, 15:23:52 »
Well I guess we need to decide if we want to make slightly more simple versions of the logos for engraved infilled from QWERKeys, or dyesubs from imsto. Either way I think we may need to simplify a bit. f/64 made the images so if he can also make SVGs that is another step we need complete before we can start getting quotes.
When it comes to the group buy I'm not sure I want to run one with international shipping again so I'll run it if someone else wants to handle the international portion. Or I'll step aside and let someone else run the group buy. At the moment with two college classes 40+ hour work weeks, and planning a wedding I just don't have the time to do US and International.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #44 on: Fri, 21 September 2012, 10:31:18 »
I asked sleabo at QWERKeys about the mandalorian keys and he is going to make mock ups of everything. Here is the pricing structure he gave me for a set of six keys:
50+ @ £12.00 each = $19.51
100+ @ £10.20 each = $16.59
200+ @ £9.60 each = $15.61
400+ @ £9 each = $14.63
These are the rough conversions that Google gave me and may change depending on conversion rates.
Offline JSaintS
    • JSaintS
« Reply #45 on: Fri, 21 September 2012, 11:15:55 »
still in, whatever the price is! =)
Offline Elrobo
« Reply #46 on: Fri, 21 September 2012, 12:06:02 »
Interested in a set.
Offline cix
« Reply #47 on: Fri, 21 September 2012, 14:09:21 »
Color me interested
Offline rao2100
« Reply #48 on: Sat, 22 September 2012, 03:46:07 »
Interested
| KMAC LE Vintage Blues | LZ-S Ergo Clears | Filco TKL MJ2 Ninja Reds | CM QFR - Blues | IBM Model M SSK 1991 |
Offline Thion
« Reply #49 on: Sat, 22 September 2012, 07:33:38 »
Looks good, i'm in.
