Author Topic: [IC] Cherry Switch Top Removal Tool  (Read 84442 times)
Offline korne
    • comscan
Re: [IC] Cherry Switch Top Removal Tool
« Reply #100 on: Fri, 14 December 2012, 15:31:00 »
I'm in
fantastic tool
Offline GMC
  • Shiny.
« Reply #101 on: Sat, 15 December 2012, 04:55:49 »
Is this still live?
WASD V1 - waiting on R4... - MX Brown
KBT Pure - Zinc caps - MX Brown
Cherry G80-1800 ISO WKL - SkiData caps - MX Clear
Offline Shadovved
  • King of Stickers (and GBs)
« Reply #102 on: Sat, 15 December 2012, 04:58:40 »
Hey beast!
I want the tool too!!!!!! (since a long time ago)  :p :p :p
Offline Leslieann
« Reply #103 on: Tue, 01 January 2013, 17:38:23 »
It's been a few weeks, any update on a time frame? I would really love to get one of these.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline The_Beast
  • I like wood ಠ_๏
« Reply #104 on: Tue, 01 January 2013, 17:43:20 »
I thought I bought enough to cover the plate GB and then have some to sell after, but I didn't. I'll probably put up a form sometime soon to order a second round.
Offline megaforce
« Reply #105 on: Tue, 01 January 2013, 18:11:58 »
Any chance of running another round of Poker plates as well?
Corsair K63 Wireless | Razer Huntsman Elite
Hokusai | Ogre| Yohane | Mc65 | Kaze | RBB
Former: LZ MX | LZ FE | LZ CLS TKL Silver |LZ CLS TKL Gray| LZ St | V.EA | Blackbird | LSV3 | OctagonV2 | Norbatouch | X60 | TX84 | Kyuu | SSK | 268.1| Jane CE | Corsair K95 | X60R | HHKB JP x JS HiPro | 910 CE |Nunu |Nunu FE | Jane V2 CE|Jane V2| RS (TKL)
Offline phetto
  • HHKB JP
« Reply #106 on: Tue, 01 January 2013, 18:13:07 »
When can I get my hands on this beasty ^_^
Offline CKTofu
  • I don't even...
« Reply #107 on: Tue, 01 January 2013, 21:20:57 »
I got mine in when I got home a couple days ago. Thing's great, now I just need to get around to desoldering the board.
Ducky Shine 2 - MX Red with Red LEDs
Offline KuhnTang
  • Game of Thrones
« Reply #108 on: Tue, 01 January 2013, 21:31:27 »
Would you consider making these colored?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #109 on: Tue, 01 January 2013, 21:36:07 »
Maybe
They're stainless steel, you can't anodize them. Why do they need to be colored anyways?
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #110 on: Tue, 01 January 2013, 22:38:18 »
Form filled.
Offline r3dx
« Reply #111 on: Wed, 02 January 2013, 08:12:31 »
Just submitted my form. I'm looking forward to getting a pair of these.
Filco MJ2 Ninja | CM Storm QFR | CM Storm QFR | IBM Model M | IBM Model M SSK | ErgoDox |
LZ-GH
Offline rindorbrot
« Reply #112 on: Wed, 02 January 2013, 08:23:01 »
That makes me sad :(
I hope this second round goes through a bit quicker ;)
Offline Rendom
« Reply #113 on: Wed, 02 January 2013, 12:10:54 »
Form filled! ;D
QFR - MX Blue
Offline Leslieann
« Reply #114 on: Wed, 02 January 2013, 16:40:51 »
Well, I guess that is both good and bad. :)
Count me in if you get some more.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline Glissant
« Reply #115 on: Thu, 03 January 2013, 09:44:42 »
Just received my plates and tools.
I have a question regarding the tool though; how am I supposed to use it? I put the tool in the only logical way and try to squeeze it loose and or try to pull the top up, but I can't for the life of me get both sides to open up at the same time. I feel challenged :))
Offline Glissant
« Reply #116 on: Sat, 05 January 2013, 17:47:00 »
Did I ask this in the wrong place?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #117 on: Sat, 05 January 2013, 17:51:24 »
yes, get out pls
1) insert the legs into the sides of the switch body, like dis:
Then pinch them enough to lift the legs of the switch top. Pull up and the switch should be disassembled
Offline Glissant
« Reply #118 on: Sat, 05 January 2013, 18:02:56 »
Well that's how I've been trying to use the tool. Hmm I'll keep trying to see if I can get it right =D Thanks for the reply, Beastie ;) .
Offline The_Beast
  • I like wood ಠ_๏
« Reply #119 on: Sat, 05 January 2013, 18:04:58 »
If you need any more help, ask someone else pls....
I be jokin ^___^
Offline Glissant
« Reply #120 on: Sat, 05 January 2013, 18:46:39 »
Offline The_Beast
  • I like wood ಠ_๏
« Reply #121 on: Sat, 05 January 2013, 18:58:41 »
If you really can get it, then I'll post a video of how they work
Offline Glissant
« Reply #122 on: Sat, 05 January 2013, 19:00:52 »
Don't worry about it =) I'll see if I can get it working for me. I'm sure there is some fine detail I'm just missing when doing it. I'll try the other set of tools to see if it might be a tight fit on one of the sides or something. No worries I'm just joking too ;) .
Edit: Yup. The other set of tools fit perfectly and pulled the switch right out :).
Offline The_Beast
  • I like wood ಠ_๏
« Reply #123 on: Sat, 05 January 2013, 19:11:13 »
You sure g-money? I wouldn't mind doing it for you
Offline cobraj
« Reply #124 on: Sat, 05 January 2013, 21:17:47 »
If you ever decide to have a 2nd round, I would definitely be in.
Also, would you consider making plates for the KBT Race? (It feels too light after using the Filco :P)
Offline The_Beast
  • I like wood ಠ_๏
« Reply #125 on: Sun, 06 January 2013, 05:56:43 »
I would need a drawing of the plate (in autocad).
Offline netdevil
« Reply #126 on: Sun, 06 January 2013, 19:43:52 »
Interested!
Offline Glissant
« Reply #127 on: Sun, 06 January 2013, 19:49:09 »
So after more testing, one set of tools work perfectly, the other set just won't because the one tool is too thick to fit well enough in the slots. Hmmm now who do I know that has a belt sander/grinder.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #128 on: Sun, 06 January 2013, 21:30:38 »
Hmm, I'm pretty sure that I tested each pair to see if they fit in the slot. You would also hand sand it if you have ~10 minutes to spare.
Offline Glissant
« Reply #129 on: Sun, 06 January 2013, 23:15:06 »
Actually I just had a closer look at the tools, and the tool that helped me remove all the switches on my Poker in about five minutes while being distracted seem a little thicker than the tools that slip out when trying to remove the switches. So it seems like the tools that aren't working simply have too small "teeth" to "grab on" to the slots. And trust me, I've been trying different angles and pressures and pushing them into the switches and wiggling.
I'll add a picture just for comparison.
The top two pieces are from the set that works without issue. The bottom set just slips out even if I try to shove them down into the slots.
11325-0
It's an excellent tool, and I love the set that works. Keep up the great work =).
Offline NikoGasm
  • Platinum mad.
    • Twitch
« Reply #130 on: Sun, 06 January 2013, 23:20:16 »
Man, I'm jealous of all you with your own set. These are really neat and seem really useful. I can imagine this being commonly sold on commercial sites in the same fashion that keycap pullers are.
| MX Mini | Ducky DK1087 | A87 |
Offline The_Beast
  • I like wood ಠ_๏
« Reply #131 on: Sun, 06 January 2013, 23:53:22 »
Hmm, the set I use has really thin "teeth" and they work just fine for me. So I don't know what's up with your set :(
Offline KuhnTang
  • Game of Thrones
« Reply #132 on: Sun, 06 January 2013, 23:55:32 »
Are enough people interested for you to sell some of these Beast?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #133 on: Mon, 07 January 2013, 00:05:32 »
I'll do another buy later
Offline cobraj
« Reply #134 on: Mon, 07 January 2013, 05:01:33 »
Hmm. How would I go about doing this lol?
Sorry, I never really used the program in school, and don't need to use it at university :(
Offline rek55
« Reply #135 on: Mon, 07 January 2013, 09:32:07 »
This coming any time soon? I've got some cherry reds in the mail that will require opening. :)
My future Das Ultimate S, all modded up. For now, it's a bit more black.
Offline Dreadwyrm
  • typemaster wannabe
« Reply #136 on: Sun, 20 January 2013, 17:02:04 »
Form filled!  :-*
Das Model S Ultimate
Offline TDub
« Reply #137 on: Mon, 21 January 2013, 06:09:36 »
Got a set with my poker plates and they work like a charm. Soooo much easier to take switches apart now :)
Offline TheSoulhunter
  • Thorpelicious!
« Reply #138 on: Mon, 21 January 2013, 16:09:11 »
+1
This little helpers rock!
Offline cobraj
« Reply #139 on: Wed, 23 January 2013, 06:15:34 »
Offline KuhnTang
  • Game of Thrones
« Reply #140 on: Wed, 23 January 2013, 13:37:38 »
Is this thing still happening?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #141 on: Wed, 23 January 2013, 13:43:02 »
Yes, when I get time
Offline netdevil
« Reply #142 on: Wed, 23 January 2013, 22:11:27 »
I need this  :cool:
Offline rek55
« Reply #143 on: Thu, 24 January 2013, 16:54:39 »
I made due with some paperclips but if I was going to be doing many more I think a tool would have been very helpful.
Offline S2000Gan
« Reply #144 on: Sun, 24 February 2013, 04:23:18 »
Ok, this is the 2nd thread this has happened to me, but not all threads are doing this, I think the pics in the op are broken.
« Reply #145 on: Sun, 24 February 2013, 09:58:19 »
I think The_Beast said that his picture host crashed.
Offline Jagriff
« Reply #146 on: Sat, 13 April 2013, 10:13:58 »
Any updates on another run of this?
Offline r3dx
« Reply #147 on: Sat, 13 April 2013, 17:55:09 »
I'm also really looking forward to picking some of these up :D
LZ-GH
Offline cobraj
« Reply #148 on: Sat, 13 April 2013, 18:06:02 »
Might need a few after all the plates available with removable switch tops haha :D
Offline Larken
« Reply #149 on: Sat, 13 April 2013, 23:04:27 »
find two pairs of reverse action tweezers and bend them with some pliers. not as precise as what The_Beast is offering, but it beats using paperclips until he runs another round.
example - (not my picture, as I bent mine a long time ago and didn't get any 'before' pictures)
after
you want it to look like the one on the right. the reason why I specify reverse pressure tweezers is due to the narrower (and therefore weaker) middle part, which makes it easier to bend into a flat angle.
word of caution, the tweezers on the top left - that will work too, but it will ruin your cherry switch housing on account of being too sharp.
« Last Edit: Sat, 13 April 2013, 23:24:43 by Larken »
| Ergodox #1 | Ergodox #2 |
