Author Topic: Under $100 mechanical keyboard for gaming and typing, possible?  (Read 23081 times)
Offline gr1m
Hello, I lurked this site last night because lately I've been looking to order a mechanical keyboard for myself. I figured I'd join up and ask about which keyboard to get. I used to post under the name of Afrodisiac on Overclock.net so it's nice seeing some familiar faces here (got banned though).
What I'm looking for:
1- Switches
Something good for gaming, like Cherry MX Black switches. However, I'd say my usage is about half and half (half gaming, half typing). Summer is hardcore game time but I don't exactly play 8 hours a day with a salary for most of the year. That got me thinking that I should get something more friendly for typing. I've tried understanding some of the terms like tactile feedback and came to the conclusion that Cherry MX Browns might be suitable. Also, I read that a Cherry MX White is a Brown with some Black properties so would that be ideal for a gaming/typing hybrid? I'm currently using a Logitech G15 v2 (yes, laugh at me - I figured the LCD and backlighting would be useful for gaming, but oddly enough, after buying it, I realised that I mostly look at my monitor when I game).
2- Budget
Something not unreasonably expensive. I'd love to get a Deck Legend or the Filco tenkeyless NKRO but over $100 is a stretch. If you can convince me that spending $160 on a Deck Legend would be a very smart choice concerning future purchases and overall satisfaction, I have no qualms about buying it but the less I pay, the happier I am. Is $80 a reasonable budget?
3- Features
Tenkeyless and NKRO, and a PS2 connection. I don't really care about backlighting. I just want a solid, simple keyboard. It doesn't have to be tenkeyless, but I really love the tenkeyless style, and have never used the number pad on any of my keyboards in my life. Also, a good layout would be nice. To be honest, I'll use anything that's put in front of me because I'm not a picky guy, but I don't want to spend money and then realise I bought a shoddy-layout keyboard (like from what I read, the Steelseries 7G and 6Gv2 appear to be).
I don't like buying used stuff but if it is my best option, I'll go for it.
Thanks for your time,
gr1m
« Last Edit: Tue, 08 June 2010, 18:49:42 by gr1m »
Offline gr1m
« Reply #1 on: Tue, 08 June 2010, 19:00:16 »
I did. It wasn't even for a dramatic reason. I just like dropping the f-bomb and the infractions stacked up.
About tenkeyless, I'm not lacking desk space so I can use a full keyboard. If removing tenkeyless from my requirements increases the choices I have, then I'll live without tenkeyless.
Offline gr1m
« Reply #2 on: Tue, 08 June 2010, 19:24:55 »
How many people would recommend that I dish out the $120 for a Filco?
Offline SpatiallyAware
« Reply #3 on: Tue, 08 June 2010, 19:57:01 »
I personally feel like the blacks are too stiff.
Blues are perfect for typing but the clickiness can be a negative for gaming.
Browns are satisfactory for typing and IMO the best for gaming.  To me they're more linear than tactile. (i.e. similar to blacks but lighter, with a tiny bump to 'push' through)
Is noise a concern?  If not I'd get a Filco blue tenkeyless and if it's too clicky then get a 'cheaper' cherry brown switch board, or trade it for a Filco brown.
One benefit of the Filco boards is that they tend to hold their resale and are very trade-able if you decide a particular switch is not for you.
Offline ricercar
  • mostly abides
« Reply #4 on: Tue, 08 June 2010, 19:57:26 »
Give me $100 for my tenkeyless Cherry black TG3. Just like a red Deck tenkeyless; made by the same OEM.
Offline kriminal
« Reply #5 on: Tue, 08 June 2010, 20:18:11 »
cherry blacks are really great for gaming, browns are a good middle ground, typing on blacks currently...
Geekhacked Filco FKBN87M/EB modified with Brown, black and blue cherries, doubleshot keycaps
Deck KBA-BL82 with Black cherries
Cherry G84-4100LCMDK-0 Cherry ML switches
Cherry G80-8200hpdus-2 Brown cherries
IBM Lexmark 51G8572 Model M Keyboard
Geekhacked Siig Minitouch KB1948
IBM Model M Mini 1397681
Offline gr1m
« Reply #6 on: Tue, 08 June 2010, 20:38:21 »
Quote from: SpatiallyAware;191093
So if your yearly life broke down into 20% gaming and 80% schoolwork/general usage, you would get MX Blues?
I'm neutral about clickiness (although my environment has no noise restrictions). I don't see how clickiness can be a con for gaming though. If anything, I can clearly hear when I accidentally release a key (although, with my headphones on and the guns blazing, I can't hear anything outside of the game). Do blue switches have a tactile bump as well as clicking? Or are those the browns?
Also, since all I've used in my life are rubber-domed Logitech keyboards, I doubt a Cherry MX Blue keyboard would be as bad at gaming as the rubber-dome ones. I hate it when one of the buttons on my G15 just decides to stop being pressed (like when I'm walking forward in a game and then just stop moving even though my finger is firmly on the w key). I'm sure any mechanical keyboard will fix that.
And, good to hear about the Filcos. Looks like they're worth the money.
Quote from: ricercar;191094
Backlit, PS2, NKRO, tenkeyless, Cherry MX Blacks? Mmmmm. I'm tempted, but since it would cost me $20 more new and I'm already plunking down $100, I would prefer to buy new.
Quote from: kriminal;191097
So I think it boils down to Browns for more gaming/less typing and Blues for more typing/less gaming (Blacks would be ultimate gaming/no typing, right?). What about the Cherry Whites and Reds? How "bad" are blacks for typing? Are they uncomfortable, or require a learning curve?
I'm finding the tenkeyless otaku Filco boards attractive. They're so new and alien to me.
« Last Edit: Tue, 08 June 2010, 20:40:39 by gr1m »
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
« Reply #7 on: Tue, 08 June 2010, 21:08:23 »
There were under-$100 mechanical switch keyboards out there. My understanding, though, is that tactile feedback is best for typing, and linear switches are best for gaming.
So that seems to mean two keyboards, and your budget is shot right there. But others have pointed out there are some switches that occupy the middle ground.
Offline gr1m
« Reply #8 on: Tue, 08 June 2010, 21:14:44 »
What I'm worried about is people saying Cherry Blues shouldn't be bottomed out. Will not bottoming keys be hard to get used to? I can't imagine not bottoming keys out when I'm gaming.
Quote from: ripster;191116
Hmmm..... ProAdvantage does not allow returns it seems like.  Maybe you can find a retailer of the Addesso (n-key Cherry Blue) that will.
I think Filco (or any other manufacturer) could make a killing if they offered switch trade-ins. Buy an NKRO Tenkeyless Cherry Blue Filco, and if you don't like it, switch it for the same keyboard with Cherry Browns.
However, I sense that by going this in depth into keyboards, it's similar to entering the world of audiophiles; I'll eventually reach a point where I'll spend $100s a month on new keyboards and never be satisfied with any. I avoided becoming an audiophile by finding out enough about audio to get the best headphones for the money, and then reverting to my old ignorance-is-bliss self and being satisfied with them. I'm planning on doing something similar with mechanical keyboards. Learn enough to make a good choice and then forget what I learned and enjoy it.
« Last Edit: Tue, 08 June 2010, 21:17:52 by gr1m »
Offline isp
« Reply #9 on: Tue, 08 June 2010, 21:17:19 »
haha, is your name Sean by any chance?
hhkb
Offline Brodie337
« Reply #10 on: Tue, 08 June 2010, 21:19:27 »
Hey, nice to see you here!
Really is a pity OCN banned you, is it permanent?
Anyway, I was in your shoes when I bought my first mechanical, and I've found the Browns to be a fantastic switch. The problem with the Blues is that the activation point isn't in the same place as the deactivation point, so you cant hover over it and rapidly tap out presses.
While the Filco might be out of your price range, there a few other very nice Cherry Brown keyboards our there by Cherry and Compaq, as long as you don't mind used.
« Last Edit: Tue, 08 June 2010, 21:24:36 by Brodie337 »
Offline gr1m
« Reply #11 on: Tue, 08 June 2010, 21:20:10 »
No, my name is Sevag. Style of gamer? Hardcore FPS. Name a multiplayer FPS and I play it. Tense moments when I'm hunched over the keyboard, sweating with concentration and getting a 25-kill streak. If I press a key during a gaming session, you bet your ass it's gonna be slammed down. I've transcended the level of smashing my keyboard out of anger, but I'm definitely a rough user.
Thanks Brodie. Yes, it is. I thought I was a valued member after getting my 598th rep point but they banned my ass! No biggie. Good information, I think I'm definitely going with the Cherry Browns. The Filco is out of my range, but if it will be a good decision to increase my range to buy a Filco, I have no qualms. I'd rather buy the best than get something cheaper and regret it forever.
Offline Phaedrus2129
« Reply #12 on: Tue, 08 June 2010, 21:21:06 »
Hey Afro, you won't remember me, I was a noob when you got banned, now I'm at 5k posts and the new PSU guru. 'Sup?
There's the ABS M1, Adesso MKB-125B, MKB-135B, iOne Scorpius M10, Unicomp Customizer and variants, the Cherry G80-3000, occasional G80-8200 boards, G84-4100 boards, the GeekHack space saver, the I-Rocks KR-6230, and a few odds and ends.
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline Mental Hobbit
« Reply #13 on: Tue, 08 June 2010, 21:21:56 »
Btw, are you touch typing?
Typing on blues.
Offline Brodie337
« Reply #14 on: Tue, 08 June 2010, 21:23:32 »
With regard to bottoming out, it is odd at first, and you're going to bottom out anyway while gaming, bit you can get used to it.
Offline gr1m
« Reply #15 on: Tue, 08 June 2010, 21:24:20 »
I type with my two index fingers but I'm planning on putting this eternally long summer to good use and learning how to type properly. I don't know if that's touch typing or not.
Phaedrus, I remember you. 5k posts eh, I would congratulate you but I need a rep number first :p They never made me a guru of anything, although the only area of expertise that I did qualify for was trolling, and being permanently banned is kind of like being a Trolling Guru. Just kind of.
Offline Brodie337
« Reply #16 on: Tue, 08 June 2010, 21:28:09 »
As an OCN n00b, you wont remember me, but I do remember your trippy-ass avatar.
What was the name of the little Compaq that had the numpad, but a smaller layout? Cherry Browns... MX11800 or something?
EDIT!: Those ones!
« Last Edit: Tue, 08 June 2010, 21:31:05 by Brodie337 »
Offline gr1m
« Reply #17 on: Tue, 08 June 2010, 21:29:14 »
Quote from: Brodie337;191129
EDIT!: Those ones!
http://s219.photobucket.com/albums/cc158/kugelfangibz/bunchie/
Knock yourself out! My collection.
Offline gr1m
« Reply #18 on: Tue, 08 June 2010, 21:34:46 »
http://elitekeyboards.com/products.php?sub=filco_keyboards,majestouch_87key&pid=fkbn87mnpek
My gut says to buy that but should I really get an Otaku? I'm not sure if I will have "Oh shi-  I wish I bought the damn labelled keyboard!" moments.
Offline Brodie337
« Reply #19 on: Tue, 08 June 2010, 21:38:41 »
Buy both!
Well, thats what I did... I bought the blank caps with the normal 'board.
The Otaku WILL force you to learn to touch type, and although its a pain at first, it looks awesome.
Om the flipside, you can always buy blank keys later.
« Last Edit: Tue, 08 June 2010, 21:40:46 by Brodie337 »
Offline gr1m
« Reply #20 on: Tue, 08 June 2010, 21:46:51 »
Also, I do touch-type (now that I figured out what it meant). Even though I use my two index fingers, I know where my buttons are. I did not look at my keyboard once to type this post. The Otaku just looks too badass. Tenkeyless + Otaku = BAMFnation. $29 shipping to Canada though... seriously? A $120 keyboard will now cost me $150. Joy.
Offline Brodie337
« Reply #21 on: Tue, 08 June 2010, 21:51:23 »
Hey, try shipping one to Australia... Thats fun. Spend enough time on here and you'll stop thinking about the money, trust me.
Offline gr1m
« Reply #22 on: Tue, 08 June 2010, 21:53:42 »
That's what I'm scared of :p
So, all in favor of me buying an Otaku Cherry Brown tenkeyless NKRO Filco Majestouch, replacing my ****ty Logitech G15 with it and exploding from the sheer awesomeness of the Filco?
Offline kishy
  • Eye Bee M
    • http://kishy.dyndns.org/
« Reply #23 on: Tue, 08 June 2010, 21:57:37 »
Quote from: Brodie337;191140
From Canada, that's around 20-25 bucks (the really slow way - rowboat post as I call it)
USA to Canada is frustrating. $29 sounds like at-cost USPS Priority to me. The frustration is because a keyboard is too large and heavy for First Class.
my keyboards
'81 XT F | '83 'Kishsaver' F | '85 AT F |  '86 122 F | '86 122 M x2 | '87 107 F | '91 101 M | '92 104 F | '93 101 M | '97 101 M13
"XT", "AT" or "Terminal" goes before "Model F" or "Model M"
« Reply #24 on: Tue, 08 June 2010, 22:06:28 »
Quote from: gr1m;191128
649 rep. :)
I'm one infraction away from a ban (I'm a potty mouth as well), but they won't infract me because I'm so helpful. :p
Offline gr1m
« Reply #25 on: Tue, 08 June 2010, 22:11:25 »
That's what I said before I got the boot. But then again, I did bypass the swear filter with the word "****".
Now I'm stuck in a rut. I was excited about the Filco but reality just hit me. Am I really about to spend $150 on a keyboard?
« Reply #26 on: Tue, 08 June 2010, 22:18:04 »
Quote from: gr1m;191147
Yes.
How much time do you spend in direct physical contact with your CPU?
And how much time do you spend in contact with your keyboard and mouse?
My rule of thumb is that 30-50% of any computer budget should be spent on peripherals, unless you already have good ones or have a really pressing need for more under the hood. Or unless you get a great deal. Point is, peripherals are important and keyboards are no exception.
At least you're not spending it on a G19, right?
Offline gr1m
« Reply #27 on: Tue, 08 June 2010, 22:22:57 »
Damnit, you're right. I upgraded to a Logitech G500 a few days ago, and a 24" monitor is in the mail. The G500 was God-sent. I started rediscovering the joys of my PC.
So, I'm buying the Filco. But first, I'll try selling this G15 v2. It still costs $136 in retail stores so I'll sell it local. If I make $100 from the sale, then I'll lose all faith in humanity. However, the money recuperated from selling my old monitor and G15 should make up for the $150 Filco.
« Reply #28 on: Tue, 08 June 2010, 22:26:45 »
The G500 is a nice mouse, no denying it. :)
I got a great deal on a Cherry G80-8200, $35 shipped NIB. The guy is still selling them for $38 shipped. Great keyboards, but uuuuuuugggglllyyyyy. That's U-G-L-Y. But I don't mind. We're a matching pair. :)
Offline gr1m
« Reply #29 on: Tue, 08 June 2010, 22:28:12 »
I was reluctant to move to laser sensors (OG Deathadder > your mother) but the features and support of Logitech mice were attractive. Then the laser sensor in the G500 and G9x proved to be as good as any optical in tests so I had no qualms about getting one.
