Author Topic: [IC] Infinikey: PBT Islander - GB May 15 to 29 Deskmats added  (Read 83484 times)
Offline Abec13
« on: Tue, 14 April 2020, 12:32:55 »
Changes
The leaf, bag, and fossil have been modified to be less IP heavy.
225 Fishing rod novelty has been sized to fit a 1.5 novelty now.
A variation of fishing novelties has been added to 1.5 and is mirrored across the sides.
1.25 Fishing novelty has also been mirrored.
Added blue 1.25 Shift to Extension Kit for 40s users who will use this on the right side.
Added green 1.75 Shift for 40s users to use on the left side.
Added blue 1.00 Shift to Extension kit for Minivan users that will use this on the right side.
Changed blue 2u Shift to green as this is actually used on the left side.
Added brown accented leaf to novelties for 40s users to use as an escape novelty.
Added blue tilde-grave.
Added blue and green (whatever the name of that) ISO key.
Moved accent arrows and numpad enter to add on kit.
Removed 1.5u "Function" keys from Add On kit, as there is already a 1.5u Alt and Fn in Base Kit.
Centered icons.
Added Canadian Proxy.
Inspiration
Just like many have, I missed out on the New Horizons edition Switch -- this is me over compensating.
If you couldn't get the switch, can't get the switch, already had one... here's your chance to get it on your keyboard.
With the power of PBT this set is going to have the massive novelty kit it deserves.
Mentions
Special thanks to meatsmoothies for the help with all of these novelties in such a small time window.
If you need novelty work done, highly recommend.
Group Buy Date: May 15, 2020 - May 29, 2020
Vendors
NA: The Key Company
ASIA: zFrontier
OCEANIA: Switch Keys
EU: Prototypist
CA: Deskhero
Art Caps
For this set I will be working with:
CYSM: https://www.instagram.com/cysm_caps/
Alpha Keys: https://www.instagram.com/alphakeycaps/
Archetype: https://www.instagram.com/archetype_mk/
Please consider following their Instagrams to keep on top of when they will be running artisan raffles for this set!
As with most artisan keycap raffles, only those who purchased a base kit will be eligible to win.
IC Form: https://forms.gle/AZq2jJ7NeDerm3ym8
Kits
Base Kit - $80
Novelties - $30
Expansion Kit - $40
Renders
Iron 165
U80A
Adelie
Deskmats
Islander Hopper Mat - $20
Investors Mat (blue) - $20
Investors Mat (green) - $20
Please consider supporting this set by adding to your signature :)
Code: [Select]
[url=https://geekhack.org/index.php?topic=105735.0][img]https://imgur.com/gZkmZ0w.png[/img][/url]
« Last Edit: Thu, 14 May 2020, 14:40:55 by Abec13 »
45-ATS | Adelie | Gentoo | Volcano 660 | Think 6.5 v2 | SKOG | 7V | Hello M0110
[/url]
Offline eniigma
    • Storefront:
Re: [IC] Infinikey: PBT Islander
« Reply #1 on: Tue, 14 April 2020, 12:34:17 »
I actually love this! Gl with this! :thumb:
Offline bewareofpixels
« Reply #2 on: Tue, 14 April 2020, 12:35:44 »
Cute!!!
40% Only.
Offline Jae-3soteric
  • https://www.youtube.com/channel/UCAIHiFKJt69HNad6r
    • Jae | Top Clack
« Reply #3 on: Tue, 14 April 2020, 12:36:17 »
Yes, yes, yes!!!
Gotta love something themed after AC
Sent from my iPhone using Tapatalk Pro
Offline gasp
  • Formerly 'boop' (NTBCW Booper)
    • none
« Reply #4 on: Tue, 14 April 2020, 12:36:17 »
I'll take 10
Sent from my Pixel 3 XL using Tapatalk
Offline ttom
  • Formerly tvaro
« Reply #5 on: Tue, 14 April 2020, 12:39:01 »
Superb work as always
Hoarder Collector and designer
Classifieds
Offline gnhuy91
« Reply #6 on: Tue, 14 April 2020, 12:40:29 »
looks fantastic!
Offline HoodrowThrillson
« Reply #7 on: Tue, 14 April 2020, 12:40:56 »
Can't wait!
Side note: who got them turnip prices
[Mostly] Retired from Keyboards
Typing on: TKL One - Zealios v1 - 55g TX Springs, TX Films, Lubed with 205g0 - Xiami Beige Cadet + RGB
Collection: IDB60 (gone), Austere (gone), Matrix 1.2og (gone), Matrix 2.0add (gone), RS (so lit), Infinitum (gone), THRILL Proto (destroyed), Matrix 2.0add xmas Starry Night (gone), RS60 (traded), MC65 (traded), Jane v1 CE (gone), GSKT-00 (gone), TKL One Poly (returned), TKL One, RS60, Serenity Proto, Boulevard Proto
Offline Rensuya
  • Blue is my spirit animal
    • Link to the discord!
« Reply #8 on: Tue, 14 April 2020, 12:42:09 »
Cute set! gj  :thumb:
Offline vaf1en
« Reply #9 on: Tue, 14 April 2020, 12:47:04 »
Yes, please!
Offline Rilow
« Reply #10 on: Tue, 14 April 2020, 12:48:46 »
Yes! Count me in
Offline o3okevin
« Reply #11 on: Tue, 14 April 2020, 12:51:20 »
1000% in
Offline BigBabyJesus
« Reply #12 on: Tue, 14 April 2020, 12:54:53 »
I like this a lot!
Offline -Jerry-
  • OR '1'='1'
    • Jerry Talks Tech
« Reply #13 on: Tue, 14 April 2020, 13:14:55 »
This is really adorable and makes me wish I had AC :D
"Romeo"     "Split75"   "Melody96"     "KBD8X MKII"     "Womier K87"
Offline Inner-Ear
« Reply #14 on: Tue, 14 April 2020, 13:23:42 »
PBT tommy bahama
Offline soran
  • what have I done
« Reply #15 on: Tue, 14 April 2020, 13:26:15 »
:eyes:
Got a question, what's the reason behind a big expansion kit like that?
Offline BubbleheadBrett
« Reply #16 on: Tue, 14 April 2020, 13:50:51 »
Interested! My girlfriend will love this!
Offline DrHigsby
  • The doctor is in.
« Reply #17 on: Tue, 14 April 2020, 13:51:31 »
Yes, Yes, Yes, Yes, Yes, Yes! Would buy all three kits right now if able.
Onto feedback/Questions:
-Could you add/change some of the R3/4 novelties in 1.25u to be 1.5u? I'd love to have a slingshot and a net in 1.5u.
-I'd be interested in a second set of just alphas if they were offered.
-What are the RAL or Pantone colors codes you are using? And, more specifically, what colors are you color-matching for the blue, green, and brown?
Offline DrHigsby
  • The doctor is in.
« Reply #18 on: Tue, 14 April 2020, 13:54:43 »
:eyes:
Big extension kits for Infinikey are pretty typical. It has a lot to do with their MOQ system. See PBT Græn or Infinkey Pastel PBT for comparison. They have large extension kits as well.
https://geekhack.org/index.php?topic=105452.0
https://geekhack.org/index.php?topic=105387.0
Offline Abec13
« Reply #19 on: Tue, 14 April 2020, 14:01:31 »
:eyes:
From my understanding of what I've been told, there's a bottom line a per-kit pricing that comes from this manufacturer where price-per-key largely benefits from larger kits. And since these kits are much cheaper to manufacture and therefore sell, there's room in the budget to sell it as such. This also makes sure that there are plenty of these obscure child kits in the wild, easier to acquire after the fact.
GMK Cafe's 40's kit was $53. This add on kit might be less than that while containing all of these other bits. :)
[/url]
Offline hkiri
« Reply #20 on: Tue, 14 April 2020, 14:08:45 »
Tom Nook why are you doing this to my bank account...
Offline alper_maestro
« Reply #21 on: Tue, 14 April 2020, 14:11:43 »
Looks very nice.
Offline Brawlbeard
« Reply #22 on: Tue, 14 April 2020, 14:19:14 »
Very nice set!
Would at least buy two of each Kit, if you consider to add a NorDE Kit or support for German ISO.
Offline StanleyLelnats
« Reply #23 on: Tue, 14 April 2020, 14:24:21 »
Was hoping to see an AC themed keyset and this one checks all the boxes! Looking forward to GB  :thumb:
Offline kbye
« Reply #24 on: Tue, 14 April 2020, 14:29:45 »
Love the novelties! I'm in.
Offline rclewright
« Reply #25 on: Tue, 14 April 2020, 14:52:21 »
20/10, Love it :)
Offline soran
  • what have I done
« Reply #26 on: Tue, 14 April 2020, 14:57:25 »
:eyes:
Roger roger
Offline Serious salamander
« Reply #27 on: Tue, 14 April 2020, 15:23:04 »
Just when I thought I was done buying sets...my poor wallet.
Is it possible to get a quick overview of what layouts the base kit will cover?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #28 on: Tue, 14 April 2020, 16:01:17 »
yes.
Offline kawaiislowpoke
« Reply #29 on: Tue, 14 April 2020, 16:39:46 »
pls gib
Offline o3okevin
« Reply #30 on: Tue, 14 April 2020, 16:40:37 »
Also Canada proxy please
Offline rewke
« Reply #31 on: Tue, 14 April 2020, 16:58:07 »
I need this ASAP! So glad it's a PBT set.
Offline Pizza_on_Pineapple
« Reply #32 on: Tue, 14 April 2020, 17:05:58 »
Yes! I've been waiting for someone to do it proper way. The colorway is so great. Definitely interested!
Offline mchanneh
  • trying to reset terrible typing habits!
« Reply #33 on: Tue, 14 April 2020, 18:07:16 »
This looks great, keeping subbed for updates and GB!
Kailh Box Royals | Cherry Reds | Knockoff Blues
Offline jakereps
« Reply #34 on: Tue, 14 April 2020, 18:56:42 »
People bombarded the GMK Mudkip IC with this question, but I don't see any mention here. Is TKC/Infinikey going to produce a kit tied so closely to Nintendo? The novelties are essentially cloned from the game which seems like an immediate takedown/cease and desist request once it gets on a product page. Love the idea and want to see it happen, but curious if it will run in current form.
Offline Abec13
« Reply #35 on: Tue, 14 April 2020, 21:07:55 »
I'm going to guess that the reason Mudkip got bombarded so hard was because it's using a strait character and name. While I know some of these may mimic a bit close, I'm open to modifications. I at the very least made very sure not use character art which are the heavy hitters of IP (imo).
This is day 1 IC level at the moment so I'm not going to make any declarations, or claim to be a legal mind. But believe-you-me this will get made while still holding the resemblance people love it for. :)
Thanks for your concern and less abrasive approach.
[/url]
Offline depletedvespene
    • Keyboard-related resources.
« Reply #36 on: Tue, 14 April 2020, 21:31:24 »
Interesting choice of colors (I'd now need to have not a beige case, but a sand colored one).
Regarding the layout, I see its following Infinikey's actually pretty good template for the base and expansion kits. That said, there are a couple suggestions I'd make to improve this IC (and the template).
1) The base kit has two `~ keys, as is standard: alpha-colored and a mod-colored. That said, in this key there's "left-mod" (green" and "right-mod" (blue colors), and this key is only available as left-mod. Perhaps there could be an additional right-mod version of it, for the compat 60% keyboards that move it to the right side of the keyboard.
2) Swap the R3 #~ (UK-only) in the base kit with the R3 \| (US only) key in the expansion kit. This is a problem shared with all the recent Infinikey sets, which (IMNAAHO) should be solved before it gets "codified", so to speak, as the "correct" way (which... isn't). For extra brownie points, an R4 <> keycap could be added, to allow both PC style and terminal style to be supported.
HTH!
Offline VoodooBear
« Reply #37 on: Tue, 14 April 2020, 21:55:21 »
I need this desperately.
Offline armintehgreat
« Reply #38 on: Tue, 14 April 2020, 22:05:38 »
This is amazing! I need it.
Offline Raravin
« Reply #39 on: Tue, 14 April 2020, 22:05:44 »
Damn that is a fat novelty pack
Offline Ustinj
« Reply #40 on: Tue, 14 April 2020, 22:20:36 »
I love this!! Please see it to completion.
Offline hellokevin
« Reply #41 on: Tue, 14 April 2020, 22:41:14 »
You know we want it, an interest check shouldn’t even be needed.
Offline MudkipMao
« Reply #42 on: Tue, 14 April 2020, 22:58:48 »
wait, this is awesome
Offline heartbreak
« Reply #43 on: Tue, 14 April 2020, 23:03:09 »
stimulus check going on a new keeb ;D
Offline shansoft
« Reply #44 on: Wed, 15 April 2020, 01:37:08 »
The brown legend color on mod is a bit too strong IMO.
Is there a version with Mod legend using alpha's base color?
Offline sirieous
  • help
« Reply #45 on: Wed, 15 April 2020, 02:06:14 »
very cute, in it to win it if this can happen and doesn't run into trouble with nintendo
Offline cinnabolt
« Reply #46 on: Wed, 15 April 2020, 02:49:02 »
100% in
Offline dibkib
« Reply #47 on: Wed, 15 April 2020, 03:53:02 »
Can I buy using Nook miles plz?
Offline Quinella
« Reply #48 on: Wed, 15 April 2020, 05:57:13 »
extremely adorable!!
Offline Abec13
« Reply #49 on: Wed, 15 April 2020, 09:16:23 »
Tried that, two things:
1. Killed uniformity of contrast
2. Removed regular dyesub compatibility.
[/url]
