masking out the sides with scotchtape, i don't have painters tape laying around so i hope this works if not, no big deal i guess.
got a template made for the final physical mod (almost) the spacebar, i put a piece of paper to fit and poked lots of holes, came out with this.
putty'in up the space bar pcb and gonna cut it.
basically it cut to fit, just had to dremel a bit on the sides, but not bad.
spacebar pcb sprayed.
forgot to show that i putty'd up the right side and cut the wrist rest to fit too, looks nicer w/o all the glare and no gaping holes!
this is the underside of it all assembled and screwed in, time solder the connecting sections together, this is gonna be an even bigger undertaking than soldering alone since it's gonna be lots of criss cross, this is what i call the second layer, first layer was directly to pcb, now we're solding directly to wire. which is why i also took so much time dremeling out holes and sections so i could see each solder joint while the pcb was attached to the frame.
i bought a psp joystick controller too, it's the really small one, just to see how it'd fit, i don't know i think i'm keeping the right thumb/ space bar. I seem to only use the right thumb anyway for space so i could fully use the right thumb for a joystick switch for up/down/left/right => for modifiers shift/alt/ctrl (and don't know last one maybe space).
