Poll
What is your interest in this set (check all that apply)?
 am not interested.
16 (4.8%)
 would be interested in a basic 104-key set.
112 (33.3%)
 would like some alternate/novelty keys included in the set.
112 (33.3%)
 would be interested in an international booster pack.
32 (9.5%)
 would be interested in some other kind of booster pack, e.g. for games.
64 (19%)
Total Members Voted: 170
Author Topic: Double shot replacements ROUND TWO!  (Read 62528 times)
Offline muchadoaboutnothing
« Reply #150 on: Mon, 15 November 2010, 15:15:36 »
Quote from: ripster;247139
I don't remember getting a choice there.
I like polls - what's a CSV?
Comma separated values. Survey tools like LimeSurvey will put out to it and it's pretty compatible with everything (works with Excel too; so you can export the CSV, Excel can convert it to an XLS, and then you can run whatever VLOOKUPs, SUMs, and formulas if you want.
Simple but effective file format.
Or you can open it in an entirely different program if you choose.
Offline Lanx
« Reply #151 on: Mon, 15 November 2010, 15:17:52 »
Quote from: Phaedrus2129;247135
Damfino. I'm using a Harbor Freight Tools $20 special. Centech I believe. Works well enough for my needs.
at the end pages of some magazines (maxum, pop sci) there is usually a harbor freight coupon page and usually the digital caliper is 8bucks w/ coupon (or 10?)
Offline Phaedrus2129
« Reply #152 on: Mon, 15 November 2010, 15:19:58 »
Quote from: Lanx;247150
IIRC they had three; one $15 one that came in a half-blister package (probably the coupon one), my $25 Centech one which came with a case and a couple extra batteries, and a branded one that cost $45.
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
« Reply #153 on: Mon, 15 November 2010, 15:27:13 »
Wait... What setting was my caliper on?
One sec
Edit: Derpaderp. It was set to imperial. Those measurements are inches.
« Reply #154 on: Mon, 15 November 2010, 15:37:40 »
Yay!
Ok, here's another thing to consider.
Nubs for F, J, and 5
I vote the centered dot style if possible.
Offline Mr. Perfect
« Reply #155 on: Mon, 15 November 2010, 19:47:49 »
The blue on black looks sweet. I wonder if they have a shade of blue that matches the blue LEDs on the Filco brown boards. :wink:
What does the gaming booster pack consist of? Colored WASD keys?
« Last Edit: Mon, 15 November 2010, 19:50:03 by Mr. Perfect »
Mr. Perfect - A name fraught with peril.
Not sure which switch is for you? Try one of the test pads!
Offline Fwiffo
« Reply #156 on: Mon, 15 November 2010, 19:58:36 »
There's not been any discussion of what a gaming booster pack might consist of. Special colored WASD keys would probably be part of the base set. I was thinking a gaming pack might include keys with special icons, but the number of icons, games, etc. may make it cost prohibitive.
You can call me... Keyboard Otaku... or not quite...
Offline Lanx
« Reply #157 on: Mon, 15 November 2010, 20:56:46 »
oh man game keys would be awesome!
fireball (hadoken)
pistol
knife
machinegun
hurricane
2 boots
shield
grenade
lightning bolt
tire
10 possible icons that could probably be used in most games and interchanged.
« Reply #158 on: Mon, 15 November 2010, 21:02:17 »
fwiffo, if you want, I can set up a LimeSurvey instance on a free web host. That'd allow you to conduct a survey (with images and a variety of question forms) and get usable data regarding what people's preferences are to a much greater degree than a vBulletin poll allows.
I just need a little advance notice to set up Limesurvey on a free webhost (it'll support SQL, but it'll get slow if more than a couple people are on at the same time. We're not serving video, so I doubt that'll be a huge problem).
Anyhow, let me know.
« Reply #159 on: Mon, 15 November 2010, 21:47:43 »
Maybe do two gaming booster packs. One for FPS, one for fantasy.
Most FPS games have a pretty consistent weapons system.
1 - melee
2 - pistol(s)
3 - SMG(s)
4 - shotgun(s) OR sniper(s)
5 - explosives
6,7,8 - special (could use lightning bolt as a generic)
Those keys would fit 90% of FPS games I've played. Really since those would all be on the number row you'd just need melee, pistol, SMG, shotgun, sniper, grenade or TNT or something, and a few lightning symbols. Don't even bother with the shift key or anything like that, just the weapon selection would be awesome enough for most I think.
The great thing about something like that is it can be marketed to the OCN gaming crowd. You could do a batch of 50 booster packs, then hawk them on OCN and other gaming forums. Might even be able to convince people to get mechanical keyboards, just for the awesome custom keycaps.
Offline Fwiffo
« Reply #160 on: Mon, 15 November 2010, 23:21:12 »
re: surveys - I'm not too worried about it at this point, but I'll keep that in mind. I figure whoever puts themselves in charge of organizing the order gets ultimate veto power over the set. :-) Anyhow, I'm a programmer at a web development firm and could put up a survey or whatever on one of my own domains. Again, I'm looking at doing this order in the new year.
re: game booster packs - I'm still inquiring about what kind of pricing we're looking at for custom art on double-shot keycaps. It could easily be in the range of $5 per key. Yeah, there might be a market for such keys, but $40 for a set is probably going to be too steep for most people.
I was really thinking about SCII packs, but the number of combinations is a lot more complicated. Even if I just did number hot-keys, the combinations of the number of units, buildings, etc. If I did unit or building hotkeys, that's even more icons and I have to handle both standard and grid layout for all three races... And the time it will take to develop all the art that looks good in two colors and fits the detail restrictions...
Quote from: The Ebullient Melissa at Signature Plastic
We are a bit limited on the detail with the 2-shot process as there has to be adequate room for material to flow on the keycap. The general rule is if there are gaps or 'islands' on a character, the space must be at least 0.008".
I'm going to bite the bullet and getting a sample ring of the available colors -- it's 35 bucks, but I figure I can send it off to the person who organizes the next project after me.
Offline Mr. Perfect
« Reply #161 on: Mon, 15 November 2010, 23:31:12 »
SC2 packs would be a pretty big hit with the Koreans buying up all the Filco boards.:suspicious:
Was the Filco font extra?
Offline Fwiffo
« Reply #162 on: Mon, 15 November 2010, 23:44:03 »
Filco font is a no-go. They were talking about doing it, but they've actually been backlogged and doing something like adding a new font is a huge project. It doesn't look like it's going to be available anytime in the near future.
Offline bakageta
« Reply #163 on: Mon, 15 November 2010, 23:48:21 »
Aww... What other options for font do we have then?
Offline Fwiffo
« Reply #164 on: Mon, 15 November 2010, 23:56:05 »
Different sizes and placements of the same font. :-/
Offline bakageta
« Reply #165 on: Tue, 16 November 2010, 00:44:11 »
Well, I suppose if they were roughly the same size/location as the Filco keys I'd be ok with that. I'd just rather not have the giant retro look going on.
Offline MyNameIsDan
« Reply #166 on: Tue, 16 November 2010, 00:48:25 »
Quote from: bakageta;247382
I'm with you. The first round on double shots looked a little funny with the huge retro letters in dead center. Filco placement and font is just too nice. At least having the placement like the Filco would be great.
Current Keyboard: Filco Majestouch 104 Browns (FKBN104M/EB)
Current Mice: Steelseries Xai (1400cc//800cc) on Steelseries 9HD.
Anyone want to donate me a keycap remover? <3
Offline strikeme
« Reply #167 on: Tue, 16 November 2010, 00:51:08 »
That's why blanks make so much sense.
1) no font problems or disputes
2) cost less (probably)
3) they're awesome!
Offline MyNameIsDan
« Reply #168 on: Tue, 16 November 2010, 00:51:51 »
I'd be down for blanks too, just black blanks :P
Well, I guess whatever goes well with majestouch, the orange was too much for me.
Offline Azuremen
« Reply #169 on: Tue, 16 November 2010, 00:54:11 »
I'm down for blanks. If we do go with legends, I would like it if they were small and in the upper left or some such. They are kind of nice to have sometimes for those of us that aren't perfect touch typists, but certainly don't need much contrast I feel.
Filco Tenkeyless Tactile Click ~ Kinesis Professional ~ White label Model M ~ DX HHKB Killer
Mionix Naos 5000 ~ Logitech Mx518
Flickr
Offline Fwiffo
« Reply #170 on: Tue, 16 November 2010, 01:05:59 »
I have inquired about prices/options on blanks. I'm certain they'll be much cheaper than custom-manufactured double-shots anyhow. But no reason it couldn't be part of one big order to get the maximum possible price-break. And I have gotten kinda excited about purple or blue legends on black keys.
Offline bakageta
« Reply #171 on: Tue, 16 November 2010, 01:08:49 »
Quote from: MyNameIsDan;247386
I'd say there's no real point in doing a set of black blanks, when you can already order a full set of filco black blanks... We might get them cheaper, but I'd imagine quite a few people who'd be interested in black blanks would've already ordered them. I'd be interested in colored blanks, depending on the color, but that may be even harder to get people to agree on...
Quote from: Fwiffo;247390
I'd be very interested in just how cheap sets of blanks would be, or what kind of minimum order it'd take... I'd love a bright pink set, but I know it's something that not many people would be interested in, so it's probably nothing I'll ever have. Maybe if the minimum order is small enough I can drum up some other interest in em... :P
« Last Edit: Tue, 16 November 2010, 01:11:24 by bakageta »
woody
  • Guest
« Reply #172 on: Tue, 16 November 2010, 03:52:29 »
Do two piece blank-likes - shell and a small frame on top in one colour, the rest of the top surface in other colour. Make few different selections for the "other" colour, i.e. the outer shell colour stays the same. That should satisfy the rainbow mania, be Otakuish, and be on the cheap side.
EDIT: This way, the legend will be rounded rectangle, filling most of the keycap top. Try experimenting with other ideas, like centered circle, Ying-Yang, etc.
« Last Edit: Tue, 16 November 2010, 03:56:08 by woody »
Offline eMps
« Reply #173 on: Tue, 16 November 2010, 05:41:34 »
Quote from: bakageta;247393
Heck yes. Bright pink blank keys with a white case.. that would look awesome.
HHKB Pro JP
Colemak since Jan. 10, 2011
Offline Twitchy
« Reply #174 on: Tue, 16 November 2010, 07:18:13 »
Quote from: woody;247401
I assume that two piece blanks like this would need tooling, unless they've produced them before?
Stuff
Filco Majestouch FKBN88M/UKB2
Topre Realforce 91UBY
Razer Imperator + Razer Vespula[/COLOR]
Offline verbel
« Reply #175 on: Tue, 16 November 2010, 08:15:45 »
I would definetly be down for a set of printed keys no matter what the colors are. I would also be interested in blank keys but only if they are in a differnt color as I already have black ones. I like the orange in Twitchy's avatar :nerd:
« Last Edit: Tue, 16 November 2010, 08:21:20 by verbel »
Offline Fwiffo
« Reply #176 on: Tue, 16 November 2010, 08:23:42 »
As far as I know, they don't do two-piece blanks, and I'm not sure what the benefit would be...
woody
  • Guest
« Reply #177 on: Tue, 16 November 2010, 09:23:52 »
Quote from: Twitchy;247432
Just a setup for a single keycap. I saw discussion for creating many custom keycap legends, so I understand the crowd is ready to swallow tooling costs.
woody
  • Guest
« Reply #178 on: Tue, 16 November 2010, 09:26:43 »
Quote from: Fwiffo;247449
The "blank" is as to lack of information from the legend, normal two-piece otherwise. It could be just a large rounded square or other figure.
Benefit - single tooling setup, Otaku style, your favourite legend all over the keyboard. Suppose you do a set of say 6 colours, 30 pieces each - then one can arrange his/her own rainbow Feng Shui.
« Reply #179 on: Tue, 16 November 2010, 09:36:56 »
I still vote black and blue. I think that will appeal to the most people.
On a side note, for better or worse I'm calling the headsup over at OCN. You're welcome. ;)
