So some of you may know that once upon a time there was another switch in the Cherry MX family - the white stem switch. This was the clicky switch that was being used before Cherry introduced the MX Blue switch.
Recently I managed to get my hands on
a NIB keyboard that uses these long forgotten switches. Made in July 1986, it is equipped with lots and lots of these old clicky Cherry MX switches. If Cherry was already following their production-time-scheme back then, its safe to assume that the switches were probably already produced in late 1985. Which would mean that MX switches are about 1 or 2 years older than I had originally researched.
Now, first things first, we should stop calling clear switches clear and call them white, or stop calling white switches white and call them clear as well, because afterall they are the same damn color:
Next... how does this switch compare to the clicky blue switch? Its pretty similar. The sound is a little less annoying and the key feels a bit smoother. I would roughly guess it needs 5-10g less to activate. However, after opening one up it turns out that there are quite a lot of differences in comparison to the modern blue MX switches.
The springs also are entirely different:
So there you have it. A lot of new information on a switch you will most likely never have the chance of using. What a waste of bandwidth and time!
