Author Topic: HOWTO Build your own "CACTUX KEYCAP PULLER"  (Read 31183 times)
Offline cactux
  • Topre Knight
« on: Thu, 02 June 2011, 00:34:12 »
Since I could not find this way of pulling the keycaps in the wiki Cherry MX Key Pulling and Swapping Guide, I decide to document it and probably some other guys can use this HIGHLY SKILL TECHNIQUE.
MATERIAL
2 - Big Paper Clips (Thickness ~ 1mm)
1 - Pliers
HOWTO BUILD THE SUPER "CACTUX KEYCAP PULLER" :thumb:
Bend each Paper clip end (~4mm), using the Pliers. They will look like a hooks.
HOW TO PULL THEY KEYCAP
1) You have to softly slide each hook between the keycaps. The both hooks have to be in opposite corners.
2) Once the hooks are in place you can just softly pull and Voilą the keycap is out ;-)
The good things about this MAGIC tool are:
* It wont scratch your precious keycaps.
* Is free.
* Is the SIMPLEST Keycap puller out there
NOTE: The CACTUX PULL KEYCAP was tested on:
* FLICO MAJESTOUCH 2, * DELL KEYBOARD, * MAC KEYBOARD
BTW Maybe this post can be integrated in the "Cherry MX Key Pulling and Swapping Guide". If you like this tool you can send me a PayPal gift ;-)
« Last Edit: Thu, 02 June 2011, 18:44:18 by cactux »
[FS]☠ The temple lol ->HERE<-
Offline iJustin
« Reply #1 on: Thu, 02 June 2011, 00:42:52 »
You forgot your Paypal Email.
Offline cactux
  • Topre Knight
« Reply #2 on: Thu, 02 June 2011, 01:04:23 »
Quote from: iJustin;354589
You can PM and I will send it to you ;-)
Offline RiGS
« Reply #3 on: Thu, 02 June 2011, 09:18:09 »
I use the same DIY keypuller with cherry switches, and use two butter knives as a lever with my topre.
Offline cactux
  • Topre Knight
« Reply #4 on: Thu, 02 June 2011, 09:44:19 »
Quote from: RiGS;354660
I have not tried yet in any Topre base keyboard. Why did you also use butter knives? Are the topre keycaps to tight?
Offline RiGS
« Reply #5 on: Thu, 02 June 2011, 09:52:33 »
Yeah, those keys are very tight, and have a different height profile. The butter knife lever method works extremely well with topre keycaps.
Offline cactux
  • Topre Knight
« Reply #6 on: Thu, 02 June 2011, 10:02:37 »
Quote from: ripster;354669
Wrong Wiki.
I claim Patent Prior Art.
From the All About Keys Wiki.
Your right is the wrong wiki!, but you do not mention nothing about how to use the paper clips. Your technic and mine are different even thought we use the same key element (paper clip).
Offline dannyp
« Reply #7 on: Thu, 02 June 2011, 13:26:36 »
I wanna see the ultimate.
Offline sordna
« Reply #8 on: Thu, 02 June 2011, 13:31:08 »
It probably involves nickels
Offline Zet
« Reply #9 on: Thu, 02 June 2011, 15:16:27 »
Woah, its actually nice :D
The good thing is that my version of Filco came with the keycap puller, didn't had to get one separate, but I'll give it a try.
Thanks for the 'aporte' men
Offline cactux
  • Topre Knight
« Reply #10 on: Thu, 02 June 2011, 15:52:17 »
Quote from: ripster;354674
I've got the ULTIMATE key puller mod in the works as we speak.  Will post a mod post when the stuff dries.
Price wise do you think it will be less expensive than mine and simple 
Offline cactux
  • Topre Knight
« Reply #11 on: Thu, 02 June 2011, 15:54:59 »
Quote from: Zet;354781
Happy to know the some one else beside me may use this simple trick 
Offline cactux
  • Topre Knight
« Reply #12 on: Thu, 02 June 2011, 17:47:13 »
Quote from: ripster;354829
Plenty of links in the All About Keys Wiki for building them.
Like this one I just added.  Not mine.  British did this.
Same ingredients (diferent approach). This tool requires bendind the paper clip several times. mine just ONE time only. At the end of the road, the important thing is that GH guys will choose to use your super duper cool tools or a super simple approach 
Offline cactux
  • Topre Knight
« Reply #13 on: Thu, 02 June 2011, 17:58:52 »
Quote from: ripster;354853
How about this one?
Has a certain elegance.  Not mine.  Ben's.  Mines still drying.
you need to bend 2 times each clip mine 1 per clip 
Offline Zet
« Reply #14 on: Thu, 02 June 2011, 17:59:20 »
Quote from: cactux;354851
I'm still digging Cactux's keycap puller(yours), but I think we would improve the back parts where you pull from to something easier to hold with just bending the wires to leave it like a T or an upside down L instead of having it so straight.
Offline cactux
  • Topre Knight
« Reply #15 on: Thu, 02 June 2011, 18:07:22 »
Quote from: Zet;354865
good there always room for improvements 
Offline cactux
  • Topre Knight
« Reply #16 on: Thu, 02 June 2011, 18:32:28 »
This one is the WINER ;-)
Offline keyboardlover
« Reply #17 on: Thu, 02 June 2011, 18:39:19 »
I thought Hamblet was the king of homemade key pullers.
Where is Hamblet anyway?
Offline DaemonRaccoon
« Reply #18 on: Thu, 02 June 2011, 18:40:33 »
Quote from: keyboardlover;354894
I believe he left after the database issues, thinking that he was censored in some way.
122-Key Model F 6110345 1985-03-01 | Model M SSK 1391472 1991-01-22 | Rosewill RK-9000 v1 | KBC Poker X | Filco FKBN87M/PWE2
Offline cactux
  • Topre Knight
« Reply #19 on: Thu, 02 June 2011, 18:48:49 »
Quote from: DaemonRaccoon;354895
Long live to the new king CACTUX the :first:
Offline dannyp
« Reply #20 on: Thu, 02 June 2011, 19:42:43 »
Quote from: ripster;354872
Like this?
This is Nanu's
woa nice :) should sell those :P
i'll probably be using the cactux method though :D
Offline cactux
  • Topre Knight
« Reply #21 on: Thu, 02 June 2011, 20:04:48 »
Quote from: dannyp;354921
I do not think that the clamping force in this guys is that good. Looks nice but slippery
« Reply #22 on: Thu, 02 June 2011, 20:10:40 »
Quote from: cactux;354942
Just like Ducky girls.
Offline lucas
    • lucasreddinger.com
« Reply #23 on: Thu, 02 June 2011, 21:40:23 »
wow, cactux is quite proud of his bent paperclips
Offline cactux
  • Topre Knight
« Reply #24 on: Thu, 02 June 2011, 21:50:46 »
Quote from: lucas;354989
I work with heavy high tech stuff, and I like to design some very PRIMITIVE things that anyone can do (even me ;) )
Offline Zet
« Reply #25 on: Sat, 04 June 2011, 14:34:53 »
I'm still waiting to see ripster's keycap puller. I bet he forgot or the puller got sticked to the surface where he was letting it dry xD
Offline dannyp
« Reply #26 on: Sat, 04 June 2011, 19:14:53 »
i've been waiting for the same :)
Offline cactux
  • Topre Knight
« Reply #27 on: Sat, 04 June 2011, 19:40:05 »
Quote from: ripster;355689
Jeez.  I haven't finished stress testing yet.
You'r for sure mech eng.
I can probably use my MTS tortion/tension machines ;-)
« Last Edit: Sat, 04 June 2011, 19:42:10 by cactux »
« Reply #28 on: Sat, 04 June 2011, 19:42:11 »
You're talking about a guy who spends 13 hours a day browsing internet forums.
Offline cactux
  • Topre Knight
« Reply #29 on: Sat, 04 June 2011, 19:45:17 »
Quote from: keyboardlover;355703
yes ;-)  . But we are lucky to have someone like him around with some extra time
Offline Dox
« Reply #30 on: Sat, 04 June 2011, 19:45:38 »
topre keypuller + shrink wrap + plastidip?
ErgoDox x2 | DoxKB x2 |   IBM SSK   | HHKB pro2
Offline cactux
  • Topre Knight
« Reply #31 on: Sat, 04 June 2011, 19:58:57 »
Quote from: Dox;355705
Its call the ULTIMATE
Offline cactux
  • Topre Knight
« Reply #32 on: Sat, 11 June 2011, 21:44:40 »
Quote from: ripster;358961
Actually I haven't really given the RipOpuller a good test run to see if the plastidip holds up (I'm skeptical).  Haven't had a chance to put my Ducky keys on a Blue Cherry Filco FOR MAXIMUM PING AWESOMENESS!!!!
In the meantime check Ceesa's Keypuller I got by lurking at a European Forum that considers every post I make there threadcrapping.  Plastic coated paperclips.
You may need some glasses!. Those keycaps have a hole in each end. So if someone is willing to make 4 holes in each of there keycaps, be my gest.
Offline cactux
  • Topre Knight
« Reply #33 on: Sat, 11 June 2011, 21:54:12 »
Quote from: ripster;359239
ART knows no limits.
You can not pull a keycap with a picaso 
Offline Wallach
« Reply #34 on: Sat, 11 June 2011, 22:02:50 »
Quote from: kalrykh;359242
no, but you can turn those upside down and use them to pull the keys of the same widths?
Pretty sure that is the point, yeah.
Personally I just use a really thin rubber cord of old headphones. I guess whenever I decide to order a spare set of keycaps it'll come with a proper tool.
Offline cactux
  • Topre Knight
« Reply #35 on: Sat, 11 June 2011, 22:05:07 »
Quote from: ripster;359245
The coated paper clips are there for Form And Function.
You seem resistant to constructive input.
Bring something MORE simple, chip, easy to make, and pratical than the Cactux one. If that happend I will switch right away
Offline cactux
  • Topre Knight
« Reply #36 on: Sat, 11 June 2011, 22:11:19 »
Quote from: ripster;359249
Next time try coated paper clips.
Do not fear change.  See the RipOmeter for details.
Nice try, keep trying . I will be waiting for your ultra secret keycap puller
Offline cactux
  • Topre Knight
« Reply #37 on: Sat, 11 June 2011, 22:33:53 »
Quote from: ripster;359257
Posted already.
Another one.  Not mine.
Yours is a Topre keycap puller plus some plastic. What is the expected life of the plastic coat?
Offline cactux
  • Topre Knight
« Reply #38 on: Sat, 11 June 2011, 22:59:06 »
Quote from: ripster;359272
Currently under research under a grant from the National Science Foundation.
What is the statistical probability of you scratching a key with a Confidence Interval of 99% and assuming a Poisson distribution?
BTW I like the symmetry of this variation.
clamping force = BAD
Offline CeeSA
« Reply #39 on: Sun, 12 June 2011, 11:40:07 »
@cactux
i don't like your keypullers because of 2 points
- you have a 2 peace keypuller (so you have to use both hands for first step)
- you have only 2 little points where the "power" pulls the cap (other versions pulls  2 whole sides)
i go with the "sippery" ones from nanu (do you have abnormal sweating hand?)
imo only nanu deserve the title :hail:
« Last Edit: Sun, 12 June 2011, 11:45:35 by CeeSA »
Offline cactux
  • Topre Knight
« Reply #40 on: Mon, 13 June 2011, 06:49:12 »
@cactux
For sure this tool is not appropriate for handicap people.
according to nanu:
I started out with a 7.5" (19cm) by 5/8" (16mm) strip of steel that I had on hand. It was coated in rusted black enamel, but some wet-sanding removed it quickly.
I cut 45-45-90 triangles away on all four corners to form points on either end. I then bent each tip 90 degrees, and trimmed them. I formed the "U" shape, and finally used a Dremel to grind away the tips until they protruded about 0.33 mm. More sanding throughout made all edges and corners smooth.
Since I work in an office. Like most of the avg guys I have access to SIMPLE OFFICE ITEMS SUPPLIES like PAPER CLIPS. So nanu's keycap puller requires some special material and some EXTRA LABOR. The goal of my tool is to provide a : SIMPLE, CHIP and EASY to MAKE TOOL.
« Last Edit: Mon, 13 June 2011, 07:21:44 by cactux »
Offline dannyp
« Reply #41 on: Mon, 13 June 2011, 14:39:18 »
I will be constructing mine today!
Offline elef
« Reply #42 on: Mon, 13 June 2011, 16:20:10 »
Ripster, thanks for posting these weird and wonderful creations.
I see your paperclips and raise you a... whatever the hell the english name of this thing is:
Sorry about the rubbish pic.
« Last Edit: Mon, 13 June 2011, 16:23:19 by elef »
Offline dannyp
« Reply #43 on: Mon, 13 June 2011, 16:25:17 »
Quote from: elef;360184
repost plz?
Offline elef
« Reply #44 on: Mon, 13 June 2011, 16:36:11 »
I changed the pic because the first one was too BIG, and edited the post. I guess you caught me during the edit, but it should work now - post again if you can't see it.
It should be at https://www.dropbox.com/gallery/16377950/1/mix?h=f6310d
Offline elef
« Reply #45 on: Mon, 13 June 2011, 16:55:53 »
The pic variously shows up and disappears for me in the forum. I have no idea what's going on, the direct URL is https://photos-1.dropbox.com/i/m/iQcWwCr1fhc9V-2CJnLT6p_cSh85E48bmioe2GQDUKc/16377950/1308088800/e4d86c0
Anyway, this thingie is a paper clip of sorts. AFAIK it's supposed to go in a hole made with a hole punch. Then you spread the legs and the fun begins... I mean, you spread the legs and it keeps the sheets together.
Offline Hamblet
« Reply #46 on: Fri, 17 June 2011, 19:25:32 »
Photos.. important thing is photos.
Ideas ? Worthless. Too easy.
15, Mar. 2011
10, Mar. 2011
28, Aug. 2009
I am dead K/L.
« Last Edit: Fri, 17 June 2011, 19:35:04 by Hamblet »
Offline audioave10
« Reply #47 on: Fri, 17 June 2011, 20:18:50 »
My Model M keypuller works fine for Cherry keys...so far.
DECK Legend "Toxic" - SOLD
96 IBM Model M 82G2383- 95 IBM Model M 92G7453 - SOLD
Cherry G80-3000/Blues
new: MechanicalEagle Z77 RGB/Blues
« Reply #48 on: Fri, 17 June 2011, 20:23:17 »
Welcome back Hamblet!
You keypuller guru you ;)
Offline Playtrumpet
« Reply #49 on: Sun, 28 August 2011, 13:22:24 »
Not to bump an older thread, and I'm sure I'm not the first to discover this.. But I just pulled a cap with a couple of these:
Couldn't do it with just a single one, but I'm sure with some intense bending it would work.
Dvorak
