Author Topic: Ergonomic DataDesk SB-5000 Mechanical Keyboard  (Read 2206 times)
Offline Suprcynic
« on: Thu, 02 June 2011, 22:51:52 »
I was referred over here by someone at OCN because he said this was the place to talk keyboards. I bought a DataDesk SB-5000 mechanical keyboard for 2.99 at goodwill. I was planning on using it but it's incredibly loud... too loud for my office. It works great, nothing sticks, just so freaking loud when you type. I almost threw it away but I heard that some of these are worth a few bucks. Is it worth anything or is it trash? I figured I'd ask before I got rid of it.
Sorry if this is the wrong place to ask. I'm unfamiliar with this forum format. Thanks.
By wekivasprings at 2011-06-02
Offline audioave10
« Reply #1 on: Thu, 02 June 2011, 22:57:01 »
Its made in the US and if it is "clicky" loud than it might be mechanical. If so, you can sell it here for sure.
You should try to "safely" remove a keycap to check for a switch.
DECK Legend "Toxic"
96 IBM Model M 82G2383- 95 IBM Model M 92G7453
Cherry G80-3000/Blues
Offline Suprcynic
« Reply #2 on: Thu, 02 June 2011, 23:05:37 »
This is what it has and yes it is a very loud and tactile click.
Uploaded with ImageShack.us
Offline audioave10
« Reply #3 on: Thu, 02 June 2011, 23:09:41 »
Maybe a white Alps switch...very clean too. Looks like the same as a Focus 2000, 2001.
« Last Edit: Thu, 02 June 2011, 23:13:09 by audioave10 »
DECK Legend "Toxic"
Offline Suprcynic
« Reply #4 on: Fri, 03 June 2011, 00:14:06 »
Any value to it or should I trash it?
Online iMav
  • babysitter
  • "En casa del herrero, cuchillo de palo"
« Reply #5 on: Fri, 03 June 2011, 00:20:56 »
My kids could use a good split mech 'board. If you don't want it for yourself, I'll take it.
DataDesk is worse then Unicomp when it comes to innovation and seeing a new project to completion.  They have been about to release their new Smartboard for years now.
To answer your question...these don't really have any collectible value and you likely won't be able to turn a profit worth your time.  But if the keyboard is fully functional, it would be a waste to throw it away.
Offline Touch_It
« Reply #6 on: Fri, 03 June 2011, 11:35:23 »
in short. dont throw it away. it is worth something.
im guessing you posted it on ebay :D?
Offline Suprcynic
« Reply #7 on: Fri, 03 June 2011, 23:22:17 »
Yeah. Hopefully it's worth the cost of shipping for someone.
Offline Suprcynic
« Reply #8 on: Sat, 04 June 2011, 22:34:06 »
I'm now finding that it's only for a MAC. I thought that it had different connections on the back but alas it has 3 of the same connector. All for MAC.
Online REVENGE
« Reply #9 on: Sat, 04 June 2011, 22:37:40 »
It's probably not going to sell for all that much then. Nice board for those who have adapters.
Offline False_Dmitry_II
« Reply #10 on: Sat, 04 June 2011, 22:40:48 »
The obvious mac keys (and to a lesser extent, the fact that it doesn't have a cord, seemingly at all) didn't give that away?
« Reply #11 on: Sun, 05 June 2011, 01:02:46 »
Oh well. I was considering getting it until I heard it was XM's. If I didn't like it (I have an adapter) I was going to put the complicated white switches into my XM whites board.
