Author Topic: Ringing Filco Majestouch-2 Plus Expanding Polyurethane Foam  (Read 12250 times)
Offline redpill
« on: Tue, 14 June 2011, 12:42:32 »
For those who have been following the other threads, I've been trying to stop my Filco Majestouch-2 from ringing in B♭ every time I press a key.
In one of those threads, someone (I should really circle back and remember who) suggested using expanding insulation foam to fill the gap between the PCB and the metal plate, thus dampening the noise.
So I was at my local Lowe's home improvement store and ran across this stuff...
...with the intention of injecting it into my new $150 keyboard.
But yes, yes I did.
It was an interesting experience.  This stuff goes absolutely everywhere.
What a mess!
So I got to the office this morning after the foam had cured and...
The ****in thing works!!!  No ****, it actually worked.  I'm typing on it right now.  Apart from a slightly sticky W and F keys, which should loosen up with some lube, everything feels great.  All keys are operational, amazingly.  And the best part?
NO MORE RINGING!!
That being said, for anyone who is as crazy as I am to try such a thing, please learn from the mess I made of my keyboard before you begin.  Some observations:
1)  This stuff REALLY goes everywhere.  Initially I had not removed the keycaps because I never thought it would come through the front of the board, but it did, and went everywhere.  Luckily I have a brand spanking new set of Ducky PBC keys waiting the wings after I get the board cleaned up.
2) Did I mention this stuff goes everywhere?  It's a mess.  Prepare accordingly.
3) You'll need to splice a narrower tube onto the main tube to get it in between the metal plate and the PCB.  I used a narrow drinking straw.
4) Wear gloves.  My hands still have this stuff on them.  The can says the only way to get it off is "mechanically."  Heh.  Appropriate I suppose.
That's all for now, will post more pics when I have her cleaned up and the new keys on.
Oh, and how could I forget...
UPDATE:
Got her all cleaned up and new PBT Keycaps on!
[video=youtube;h44LIiaZhHE]http://www.youtube.com/watch?v=h44LIiaZhHE[/video]
« Last Edit: Wed, 15 June 2011, 11:43:22 by redpill »
^ Current Favorite ^  Topre Realforce 87UB 55g  |  Topre Realforce 103UB 55g | KBC Poker/Browns/Sanded KeycapsDucky 1087 | Filco MajesFoam-2 | IBM Model M 1390131 Feb '87 | Still Love: Microsoft Trackball Explorer x3 | Now Unused:  Microsoft Natural Ergo 4k x2
Offline The Solutor
« Reply #1 on: Tue, 14 June 2011, 12:46:09 »
NO MORE RINGING!!
I had no doubts.
Well done.
Offline dannyp
« Reply #2 on: Tue, 14 June 2011, 13:04:07 »
What. the-****.
I remember talking to someone about this on #geekhack a few days ago or a week back.
After seeing the goop on the keys, and knowing what that product is like, well thanks for taking the hit. Now we know what will happen :P
[SIGPIC]http://i.imgur.com/Qz9y2.jpg[/SIGPIC]
Offline Surly73
« Reply #3 on: Tue, 14 June 2011, 13:11:21 »
I might make one modification for anyone seriously considering this.
DAP makes a latex-based expanding foam product.  It expands less than the yellow polyurethane foams (even the "window and door" variety) and is easier to clean up even after curing.
In my experience the yellow stuff is NASTY if you get it on anything unintentionally.
I will not be foaming my Filco, but this it the stuff I'm thinking of:
http://www.dap.com/product_details.aspx?product_id=11
Offline redpill
« Reply #4 on: Tue, 14 June 2011, 13:25:39 »
That's probably very good advice Surly.  Did I mention the yellow stuff goes everywhere and creates a mess?
Offline redpill
« Reply #5 on: Tue, 14 June 2011, 13:35:21 »
The can says acetone works if it's still tacky.  Otherwise once it's cured, you're hosed.  I probably should have read that part a little more closely before starting.  Heh.  Whatever I can't get off I'll Sharpie black since it's on the inside, shouldn't be visible once the case is on.
Offline redpill
« Reply #6 on: Tue, 14 June 2011, 13:38:51 »
Oh I'm not using acetone on the board.  Besides it's cured now anyway, wouldn't do any good.  Except hose the switches.
Offline redpill
« Reply #7 on: Tue, 14 June 2011, 13:40:51 »
Do they put them in the oven?
Offline redpill
« Reply #8 on: Tue, 14 June 2011, 13:48:29 »
Quote from: ripster;360679
This btw reduces your chance of a successful RMA considerably.
True.  Although it can't be as bad as trying to return a used electric shaver or something.
Offline canon.tk
« Reply #9 on: Tue, 14 June 2011, 13:55:55 »
Oh.
My.
God.
Pass.  You probably could have gotten the same results if you just did a few "spots" between the plate and PCB.  Still can't believe you did that.  I've used that stuff for its intended purpose and hated the mess it was.
Filco Majestouch 104 Cherry MX Black; Filco Majestouch 87 Ninja Cherry MX Brown; Filco Majestouch Indigo Blue 104 Cherry MX Brown; Filco Majestouch 2 104 Cherry MX Red; Leopold 87 Otaku Cherry MX Brown; Leopold 87 Cherry MX Brown; Razer Black Widow Ultimate
Offline Lpb45
« Reply #10 on: Tue, 14 June 2011, 14:06:42 »
seriously?  Id rather just deal with the ringing then have my keyboard look like a garbage pail kid.  I've used this stuff plenty of times, sealing holes, insulation yadda yadda and I wouldnt let this stuff within a mile of my keyboard,  I think the only way to remove large amounts is with a sawzaw or dremel.  You got balls lol
Topre - 86U   |   Filco - Tenkeyless Linear Red
Filco - Tenkeyless Blue       |   Filco - Fullsize Non NKRO Blue (Work)
Offline redpill
« Reply #11 on: Tue, 14 June 2011, 14:09:37 »
The ringing was starting to piss me off.  And don't worry, I'll get her cleaned up.
Offline drsauced
« Reply #12 on: Tue, 14 June 2011, 14:11:41 »
A bit extreme, but at least it worked.  Thanks for taking one for the team and you got a pretty nice signature pic if you decide to use it.
Filco Ninja 104 Tactile w/PBT caps | Deck Legend Ice Linear | EK Order: #9001, #5640 | \'93 1391401 | Ping is Life
Offline redpill
« Reply #13 on: Tue, 14 June 2011, 14:22:03 »
Fixed...
Offline Tennobanzai
« Reply #14 on: Tue, 14 June 2011, 15:23:31 »
Hahaha I actually traded watercooling parts for video games with that guy. He's awesome
Offline noodles256
« Reply #15 on: Tue, 14 June 2011, 15:26:58 »
man, he part of my hood
RK-9000BR | DK1087XM | Corsair K90
Offline redpill
« Reply #16 on: Tue, 14 June 2011, 16:40:00 »
Dare I ask where your hood is?
Offline elbowglue
« Reply #17 on: Tue, 14 June 2011, 17:46:06 »
oh
my
****ing
god
This is epic.
So cool!!
« Last Edit: Tue, 14 June 2011, 17:51:14 by elbowglue »
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline nhwhaup
« Reply #18 on: Tue, 14 June 2011, 17:47:18 »
Red pill - you are a nut!
Current in order of preference:  RealForce 87U Silent White with variable weighted keys X 2, Filco Majestouch 2 Tenkeyless with Linear Reds, Filco Number-pad, Poker with Linear Reds
Sold or returned:  Multiple Microsoft and Logitech keyboards, Das Keyboard Silent, Cherry 6140, RealForce 103UB, RealForce 86U, Filco Majestouch 2 full sized with Linear Reds
Offline SecrtAgentMan
« Reply #19 on: Tue, 14 June 2011, 17:53:35 »
I'm sorry but I would never do that to my beloved Filco D:
Headsets + 100% volume = what ringing?
Offline morethanless
« Reply #20 on: Tue, 14 June 2011, 18:47:20 »
Nice, now I can see the mess.
Try alpha-foam next time :happy:
It is without hazardous gas and doesn't leave black stains on the skin.
http://www.alpha-bauschaum.de/en/anwenderfreundlich.html
http://www.alpha-bauschaum.de/en/handwerker.html
Installation foams based on alpha-technology don't stain the skin and can easily be rubbed off again. It is recommended that gloves be worn, but it is not strictly necessary.
Products: http://www.alpha-bauschaum.de/en/hersteller.html
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #21 on: Tue, 14 June 2011, 19:50:24 »
after seeing the pictures, I am foaming at my mouth!  Maybe my foam could do the job as well?
Offline alaricljs
  • I be WOT'ing all day...
  • Administrator
« Reply #22 on: Tue, 14 June 2011, 20:25:53 »
Quote from: SecrtAgentMan;360797
That would be the ringing in your ears that never goes away... just give it time, you'll start to notice it after a while.
Filco w/ Imsto thick PBT
Online rsantos97
« Reply #23 on: Tue, 14 June 2011, 20:30:36 »
I used this same product last week to fill in a gap I had above one of my doors and it was a total mess.
I underestimated how much this **** expands.  The only way I see removing this crap after it has cured is through sanding.  I should have warned you about that when I read your first post about going to try it out.
« Last Edit: Tue, 14 June 2011, 22:33:50 by rsantos97 »
Offline Wallach
« Reply #24 on: Tue, 14 June 2011, 21:24:35 »
This is actually pretty awesome. Good work dude. Now to find a way to perform that mod without it going everywhere!
Offline sordna
« Reply #25 on: Tue, 14 June 2011, 21:42:20 »
Quote from: litster;360851
Nope, your foam is probably conductive.
Kinesis Contoured Advantage LF with Cherry MX Red switches / Extra keys mod / O-ring dampening mod / Dvorak layout. ErgoDox with buzzer mod.
Also: Kinesis Advantage Classic, Kinesis Contoured Model 110, Data911 TG3, Fingerworks Touchstream LP, KBC Poker (Cherry MX Red), IBM Space Saving keyboard (Buckling spring), Goldtouch GTU-0077 keyboard
Offline Surly73
« Reply #26 on: Tue, 14 June 2011, 21:59:35 »
Quote from: rsantos97;360879
I used this same product last week to fill in a gap I had above one of my doors and it was a total mess, .  I underestimated how much this **** expands.  The only way I see removing this crap after it has cured is through sanding.  I should have warned you about that when I read your first post about going to try it out.
I just remove the excess with a utility knife. Or did you mean to clean up surface stains?  Yeah, they're pretty much permanent.
Offline sinis
« Reply #27 on: Tue, 14 June 2011, 22:11:16 »
nice work. you are one nerd!
kids, please do not try this at home!
Offline redpill
« Reply #28 on: Tue, 14 June 2011, 23:16:15 »
These are my wild formative keyboard years.  Like when Van Gogh drank absinthe and lived with Gauguin.  Well except before they went gay and Gauguin cut Van Gogh's ear off.
The absinthe part is good though.  I recommend Ridge Absinthe
Offline The Solutor
« Reply #29 on: Wed, 15 June 2011, 10:13:45 »
Btw, filco or not, pinging or not, this mod should be worth to improve the sound feedback of any plate mounted keyboard.
