Author Topic: Not really happy with cherry brown :/  (Read 5565 times)
Offline Reason
« on: Fri, 24 June 2011, 02:34:53 »
So I bought the filco ninja with brown switch 2 weeks ago
and it felt amazing at first... but as I type more and more on it, I just can't get myself to like it
the main problem for me is that the keys feel too light and there is barely no resistance at all against my fingers... they just seem to push down too effortlessly...
I spam same keys a lot over and over again when playing games (starcraft 2)
and the lack of the resistance when pressing the key is really unsatisfying for me...
when one key is pressed repeatedly very fast, it just feels like im sliding a piece of plastic up and down.... it doesn't feel like i'm actually pressing something...
and bottoming out the keys feels a bit off too...
can anyone else recommend other type of switch for me?
Offline calavera
« Reply #1 on: Fri, 24 June 2011, 02:37:02 »
Black switches. Highest resistance of all cherry switches, but unfortunately doesn't have that tactile bump of browns. The only way to have best of both worlds would be to get springs from black switches and transplant them into the browns but filcos are plate mounted so in order to replace springs you'll have to desolder every single switch.
So black switches is your best bet as far as resistance goes.
« Last Edit: Fri, 24 June 2011, 02:39:27 by calavera »
Offline BaconKnight
« Reply #2 on: Fri, 24 June 2011, 02:39:17 »
Cherry blues, while not much "heavier" in keystroke than browns have a more pronounced tactile bump so maybe that's what you're looking for? Keep in mind it'll be a bit louder than browns with the click and all.
Another option is an Alps keyboard, probably white. It feels heavier and has a pronounced click, though some people think Alps are an acquired taste. Also that thing will be loud, even louder than a cherry blue.
Leopold FC200RC/AB
Noppoo Choc Mini
TG3 Data911
Cherry G80-8113LRCUS
IBM Model M 1391401
SIIG Minitouch 1903
Dell AT101W GYUM90SK
Image Gallery
Offline BaconKnight
« Reply #3 on: Fri, 24 June 2011, 02:42:20 »
Black switches have the highest resistance by far but I don't know if that will solve the OP's problem. When I use my black, it's heavy feeling yeah, but I get more of a snappy "I pressed the button!" feeling using blues or white alps. The linear nature of blacks make it feel like your just pressing till forever, no real feedback. Kinda like pressing down on a super thick sponge.
Leopold FC200RC/AB
Noppoo Choc Mini
TG3 Data911
IBM Model M 1391401
SIIG Minitouch 1903
Image Gallery
Offline Reason
« Reply #4 on: Fri, 24 June 2011, 02:51:23 »
hmm never considered alps before
where can i find one?
Offline The Solutor
« Reply #5 on: Fri, 24 June 2011, 02:58:26 »
Quote from: Reason;366771
Definitely Beige aka Ergo clears, don't waste your time and money in anything else.
Offline REVENGE
« Reply #6 on: Fri, 24 June 2011, 03:16:20 »
I think you want normal Cherry Clears. They're higher activation force tactile, non-clicky switches with a slightly more pronounced tactile bump than Browns. Ergo Clears are Clear stems matched with the low-force springs from Blues / Browns, they probably aren't what you're looking for.
As an aside, I played SC2 on a Cherry G80-8000 with Clear switches for a long time and they felt great. On the other hand, my friend who's a Master top 10 only plays on Browns.
« Last Edit: Fri, 24 June 2011, 03:21:05 by REVENGE »
Offline The Solutor
« Reply #7 on: Fri, 24 June 2011, 03:23:53 »
Quote from: REVENGE;366787
This is exactly what I tough before trying. And I was wrong.
In the real world the stiffer spring from clears will mask the more pronounced tactile bump of clear stems.
So a clear switch will feel as a stiffer brown switch but still doesn't give a good tactile feedback.
The combination of white stem and the softer brown/blue/red spring gives a definite tactile feedback while the keys will not become uncomfortably stiff and fatiguing.
« Last Edit: Fri, 24 June 2011, 03:25:57 by The Solutor »
Offline ch_123
« Reply #8 on: Fri, 24 June 2011, 04:41:43 »
Does it need to be non clicky?
Offline REVENGE
« Reply #9 on: Fri, 24 June 2011, 05:29:30 »
Quote from: The Solutor;366789
Well, OP seems to have a problem with low activation force, not low tactility. If I could, I would go for high activation force + high tactility, ie a Cherry Green board.
Offline The Solutor
« Reply #10 on: Fri, 24 June 2011, 05:44:57 »
He will certainly clarify later, but I'm sure that the two things are easily confused, especially by the newcomers to the cherry world.
Most of users will expect browns as something like blue switches w/o the click and will end with something like a linear switch with some lube problem.
Keep also in mind that more tactility means also more force to past the tactile point using the same spring.
You should really try a cherry clear switch. It's counterintuitive but the more stiff is the coiled spring, the less tactility you feel.
If you go to greens or grays you will get more stiffness but less tactility, to have both improved a more pronounced bump on the stem should be needed, practically you need a switch which doesn't exist
Online gilgam
« Reply #11 on: Fri, 24 June 2011, 05:51:03 »
Quote from: REVENGE;366809
Not so easy to find one brand new
The black is the best to test, then clears, i got both (clear seems to be europe only) and at the beginning i loved the black. But the more i use mechanical keyboards the more i love light switches like browns or red.
So test a black one, then try a clear one (only cherry but for50-60 euros in europe -80$ ?- plus shipping...
Realforce 105 FR, HHKB Pro 2 black, 1 Raptor K1 Black Cherry and 1 Raptor K1 Red Cherry , Compag MX 11800  tBrown Cherry, G80-3000 Clear Cherry , G80-1000 Blue Cherry / Ghetto red, Lexmark 1992 SSK Buckling spring, Unicomp 2011 Customizer 102 Buckling spring
and a few rubber dome/scissors keyboards from Apple/Logitech
Offline scribble
« Reply #12 on: Fri, 24 June 2011, 06:57:51 »
I've typed on my friend's who had a cherry clear before I even knew about mechanical keyboards... it's more like a rubber dome type of force required, but the key comes up much quicker, that's how i would explain it to you. And the click you get from it is definitely there as well. I can't imagine typing for straight hours on that thing though, I could bet that your fingers would get sore.
It was a Deck Legend cherry clear
Filco Majestouch Tenkeyless Cherry MX Blue | PLU ML-87 Cherry MX Red
Offline slueth
« Reply #13 on: Fri, 24 June 2011, 07:11:10 »
for gaming brown is the way to go, or blues if u want click.. for cherry switches.  Topre isn't bad either, for starcraft buckling is tooooo heavy.  can't go quick on it.  its doable but its a drag.   There is no reason you would want it heavier in my opinion if you want fast apm.
Offline bhtooefr
« Reply #14 on: Fri, 24 June 2011, 07:12:48 »
Wait, if clicky is OK, and you want high activation force and high tactility...
Why are we looking at Cherry at all? This is the realm of Model M buckling spring...
want mature keyboard discussion? try deskthority.
Offline HaiiYaa
« Reply #15 on: Fri, 24 June 2011, 07:37:44 »
I felt the same way as you.
I would advice you to try out cherry mx blacks
Online mmmty
  • bang! bang!
« Reply #16 on: Fri, 24 June 2011, 07:47:37 »
"Thermaltake Meka G1 is the best Cherry MX Black"  : )
I HATE KEYBOARDS W/ BLUES
Offline theferenc
« Reply #17 on: Fri, 24 June 2011, 08:14:04 »
I would just avoid Cherry altogether, and look at buckling spring, topre, and alps clones.
Offline The Solutor
« Reply #18 on: Fri, 24 June 2011, 09:18:34 »
Quote from: HaiiYaa;366839
I think blacks are just the exact opposite of what the OP needs.
Offline False_Dmitry_II
« Reply #19 on: Fri, 24 June 2011, 13:31:45 »
So try Buckling Spring, clear, ergo clear, and alps.
I'd get the model m from ebay or the classifieds, an alps from the classifieds (since this is to test/try different things, so probably a dell), then the clear from the super cheap great finds/ebay board. Then you'd have to find something to mod to get ergo clears if you wanna make that final step.
Offline noodles256
« Reply #20 on: Fri, 24 June 2011, 13:35:59 »
grow a beard
RK-9000BR | DK1087XM | Corsair K90
Offline SecrtAgentMan
« Reply #21 on: Fri, 24 June 2011, 13:42:03 »
Ripster in the next couple years?
Offline The Solutor
« Reply #22 on: Fri, 24 June 2011, 14:04:27 »
Quote from: ripster;367120
F*** German Engineering.
Braun was owned by Gillette since 1967, then Gillette was bought by Procter & Gamble in 2005, so it's safe to consider it an american company.
Online alaricljs
  • I be WOT'ing all day...
  • Administrator
« Reply #23 on: Fri, 24 June 2011, 14:06:47 »
Quote from: The Solutor;367126
That goes directly against what you JUST said here.   I think I'm beginning to see the light.
Filco w/ Imsto thick PBT
Offline The Solutor
« Reply #24 on: Fri, 24 June 2011, 14:12:26 »
Quote from: alaricljs;367128
Company acquisition aren't always done in the same way, sometimes company are left completely independent, sometimes are completely assimilated.
There's not a single way.
Offline Titmouse
« Reply #25 on: Fri, 24 June 2011, 14:16:21 »
Hmm, I never knew that some Leica binoculars are made in Portugal. Oh, well, made in Germany or not, they are still too rich for my taste.
"Surprise! We threw away your old ugly keyboard and got you a brand new ergonomic keyboard from Microsoft!"  -- Findecanor
Offline Reason
« Reply #26 on: Fri, 24 June 2011, 14:16:26 »
lol wow sorry guys
I started this thread last night and I fell asleep so I couldn't respond to your posts :S
hmm so how do ergo clears and clears feel compared to eachother?? im not quite sure what different stems/springs feel like...
I'm currently rank 3 masters with 1700 points ... and I got there using the scissor switch keyboard on my laptop lol... I got tired of the laptop keyboard not responding quick enough and that's why I was looking for a mechanical keyboard...
Brown does make clicking / spamming effortless but it just doesn't feel satisfying for me...
it doesn't matter
hmm... i'm not quite sure what the difference is between the activation force and tactility...
I just want the keys to respond to my touch when I press on them unlike brown..
I really like the feel when I bottom out the browns but I usually have really light touch and when I press the buttons lightly, I just don't feel any response... and that really bugs me.. I mean I like it because the keys are recognized without jamming on the key but it also feels unsatisfying
Well, the keys are recognized properly without effort but I don't feel the response from the keyboard when I'm moving across the keyboard and rapidly pressing different keys very fast... and that throws me  off and I don't really have fun typing on it.. lol
SO... so far the candidates are..
-Cherry Black
-Cherry Blue (I've used cherry blue before but I want to try it again to compare with brown)
-Cherry Clear
-Cherry Ergo Clear?
-Buckling Spring
-White Alps
...the problem is I'm currently a student and I really don't have the money to actually buy the keyboards to try all the different switches out...
What will be the best way to try out all these switches?
and what keyboards have switches such as clear , ergo clear, white alps? that I can find in US?
Offline The Solutor
« Reply #27 on: Fri, 24 June 2011, 14:21:11 »
Damn!! After the backlit keyboards we have the backlit posts. :)
BTW for ergo clears just read the thread I linked before
Offline theferenc
« Reply #28 on: Fri, 24 June 2011, 14:23:18 »
Reason, where are you? No, that isn't a joke.
If you're near another geekhacker, they can probably let you try at least some of those.
I know Indiana, at least, has fairly decent geekhack coverage (near purdue, near IU, southern Indiana, near Indy). I'm pretty sure there's more than a few in California, as well.
Online alaricljs
  • Administrator
« Reply #29 on: Fri, 24 June 2011, 14:24:25 »
You're not going to cheaply/easily find clear without buying a used POS off ebay.  That can be cheap tho... ergo clear is a clear switch with the spring from a brown switch, requires KB surgery.  I know nothing of alps...
As to the difference between activation and tactility.   activation is the force from the spring, tactility is the bumpiness provided by the stem.  black/red only have activation force.  blue/brown/clear have differing activation force and differing tactility.
edit: thereferenc, knew that... meant to throw in cheap/easy
