Are your eyes bleeding? You can always change your theme.
I recommend using it as a fancy earring.
Or use it as an excuse to get a Topre board
Been gone for a while, including the beige ones. They reduced the price a while back, guess it was for clearance.The Computer Warehouse still lists TKL RealForce: http://thecomputerwarehouse.com.au/components/keyboards/topre-realforce
They had some showing for me earlier this month.. for $269.. o.0 How cheap did you see them? Also thanks for the link. Only clearance on Realforce I saw were the number pads.
Yup, nokcha at Keypop.net (link).
That's where I saw it! Thanks!
Ragnorock might be adding a Zoidberg cap to his dyesub GB
I like the LoD version better but you know me.. probably end up getting both.
I can't imagine why anyone would disable the win key via the Windows Registry.Do you have Windows 7?Win+Tab, Win+left, Win+right <- those three right there are enough to justify it.
There are a lot more shortcut keys with the Windows key in Windows 8.
The Gas Mask keycap :3Show Image
Wow, that's the exact keyset I want for my own Filco camo. Is it a set from imsto or from where if not?Nice gaz mask too
Quote from: litster on Wed, 02 January 2013, 13:56:33There are a lot more shortcut keys with the Windows key in Windows 8. Ironic, for an operating system that is targeted at devices with touch screens.
Never again. Show Image
Here at GeekClack, time isn't worth anything because CCs are money.
Nail polish marbling is hard! lol. i dunno if you can tell but there's air bubbles in the polish from dipping it too fast this was my third attempt.
Quote from: metalliqaz on Wed, 24 October 2012, 19:39:26I can't imagine why anyone would disable the win key via the Windows Registry.Do you have Windows 7?Win+Tab, Win+left, Win+right <- those three right there are enough to justify it.I should have already known this.
I use Win-M occasionally - minimise all windows. What is the difference between Win-M and Win-D? Does Win-D minimise the gadgets too?
KBC Semi-Clear ABS 104-Keyset (Cherry MX Keycaps)Show ImageShow Image
It probably looks amazing in person, doesn't it?
