Author Topic: Tenkeyless Terminal Model F (1387033) Interest Check  (Read 18267 times)
Offline REVENGE
« on: Wed, 20 July 2011, 11:55:08 »
In the last two hours, I've come upon two almost 100% confirmed sources for these keyboards. As a reminder, these are 104 key Terminal Model Fs which look like 122 key Terminal boards without a numpad (also referred to as the "Space Unsaver" by Kishy). Source #1 appears to have boards that are fairly clean and in good condition, while source #2 probably has dirtier, near salvage grade boards with or without moderate damage to various components (missing key caps, rust, damaged cords, etc.). Depending on who has how many boards in what condition, I'm looking at a tentative upper bound of about $60 per board + shipping to your location. If you would be interested in acquiring this board, please post in the thread below. At this point, I have yet to determine whether this will be a "Group Buy" handled by me or individual orders between you and the sources.
My personal example, the white balance is really off:
...and now I'm off to bed, expect to hear back from me towards the end of the day.
UPDATE: Scratch the previous statement about them being made in 96, it looks like it was a replacement label from someone. I do see one board with a legitimate Model F label, made in 91.
UPDATE: Source #1 has confirmed with pictures. The boards are somewhat clean, but may have a stretched cord and/or missing keys / key caps. Also, this seller might not have the terminal necessary to function test these boards, so they could be sold as is.
UPDATE: Source #1 has committed to cleaning the boards and ensuring they are as complete as possible, meaning replacement key caps for any boards which are missing some, etc. Source #2 has also indicated that they're going to do the same.
« Last Edit: Wed, 20 July 2011, 20:14:03 by REVENGE »
Offline 7bit
  • MX1A-G1DW
« Reply #1 on: Wed, 20 July 2011, 14:01:48 »
Quote from: REVENGE;384080
 I'm interested. I take the one in white!
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline xbb
« Reply #2 on: Wed, 20 July 2011, 14:15:39 »
Interested in a fairly clean one (first source)
« Last Edit: Wed, 20 July 2011, 17:40:42 by xbb »
« Reply #3 on: Wed, 20 July 2011, 14:25:03 »
Interested if you go with the first source.
Offline rodya
« Reply #4 on: Wed, 20 July 2011, 14:53:16 »
Interested in a clean one.
Offline REVENGE
« Reply #5 on: Wed, 20 July 2011, 17:39:53 »
Quote from: 7bit;384172
Well that's good, because they only come in white! And that picture of the painted board I received a while back has poor color balance, so expect them to be in the classic IBM Ivory.
Offline Soarer
« Reply #6 on: Wed, 20 July 2011, 17:51:32 »
I'm torn... I don't like tenkeyless, but this is an 'F' I have not yet acquired... :-D
Offline iMav
  • geekhack creator/founder
« Reply #7 on: Wed, 20 July 2011, 17:55:11 »
Are these PS/2 or will they require modding to use on a PC?
Offline REVENGE
« Reply #8 on: Wed, 20 July 2011, 18:08:12 »
Quote from: iMav;384307
Not PC compatible out of the box. They require a physical adaption to PS/2 or a direct connection to the Teensy, then you can use any of the firmwares our members have written that can do the conversion. This particular route can be solder-less, or involve very simple soldering.
If you want to be adventurous, you can swap out the entire controller for one with the custom firmware generated by JohnElliot's program, which would let you use it over PS/2 directly. Involves (more) complicated PCB soldering and requires a spare controller and programmer (could be expensive?).
Offline DaemonRaccoon
« Reply #9 on: Wed, 20 July 2011, 20:15:39 »
REALLY WANT, but too expensive for me...
122-Key Model F 6110345 1985-03-01 | Model M SSK 1391472 1991-01-22 | Rosewill RK-9000 v1 | KBC Poker X | Filco FKBN87M/PWE2
Offline 7bit
  • MX1A-G1DW
« Reply #10 on: Thu, 21 July 2011, 06:51:06 »
They should sell them dirty and cheaper!
Offline Ekaros
« Reply #11 on: Thu, 21 July 2011, 07:29:05 »
That must be largest tenkeyless there is... ;D
So I should add something useless here yes? Ok, ok...
Filco 105-key NKRO MX Browns Sw/Fi-layout|IBM Model M 1394545 Lexmark 102-key Finnish-layout 1994-03-22|Cherry G80-3000LQCDE-2 with MX CLEAR
[SIGPIC][/SIGPIC]
Dell AT102W(105-key SF) (Black ALPS)|Steelseries Steelkeys 6G(MX Black) ISO-FI-layout|Cherry G84-4400 G84-4700 Cherry MLs
Offline sethstorm
« Reply #12 on: Thu, 21 July 2011, 13:57:17 »
Also interested as well, cleanliness/rust-free isn't important as much as it being structurally sound.
« Last Edit: Thu, 21 July 2011, 17:32:10 by sethstorm »
Current:
IBM: Model M: 1391401, 1386887 Terminal 122 Key
IBM: Model F: 6110668 Terminal 122 key with Trackpoint and M13 blacks
IBM: Specialty: Wheelwriter 5, Boltmodded.  AT F layout, M technology.
Lexmark/IBM: M13 Black Trackpoint
NCR:HO150-STD1-01-17 Decision Mate V - The other Gray NCR linear.
Offline LETE
« Reply #13 on: Thu, 21 July 2011, 14:17:06 »
Offline 7bit
  • MX1A-G1DW
« Reply #14 on: Thu, 21 July 2011, 14:38:18 »
I take 3.
« Last Edit: Thu, 21 July 2011, 18:16:20 by 7bit »
Offline wcass
« Reply #15 on: Sun, 24 July 2011, 23:09:17 »
Yeah, ill take one.
Offline Soarer
« Reply #16 on: Mon, 25 July 2011, 04:43:12 »
OK, I'm in for one :-)
Offline REVENGE
« Reply #17 on: Mon, 25 July 2011, 04:49:09 »
K, I should work out the specifics later today.
Offline REVENGE
« Reply #18 on: Wed, 27 July 2011, 16:51:15 »
Ok, I'll be doing orders with source #1 very soon. Unfortunately, it seems that in total there are less boards than we had previously expected, so I'll be going in the order of posts in this thread.
Offline wcass
« Reply #19 on: Wed, 27 July 2011, 21:14:09 »
Damn - i'm near the end of the list. i hope i make it in.
on the bright side, this should encourage another IBM key caps group buy, right? i still need Windows and media caps for my terminal SSK hack project.
[ Attachment Invalid Or Does Not Exist ] 22568[/ATTACH]
Offline Imagineer
« Reply #20 on: Thu, 28 July 2011, 23:21:13 »
Put me down for one as well, I hope there is still enough for everyone interested.
Offline dfj
  • Visit our irc: #geekhack on libera.chat!
« Reply #21 on: Fri, 29 July 2011, 10:36:03 »
If any turn up which are non working, or not actual 1387033, or which are too damaged for sale (or which have an uncommon connector) then I am quite interested. The adapter for the others has likely not yet to be written, and otherwise, I always need F parts.
dfj
Fave Switch manus: IBM, Topre, Matias, ...
Offline LETE
« Reply #22 on: Tue, 02 August 2011, 20:39:22 »
I'll take another if I can. How many are going to be available?
Offline REVENGE
« Reply #23 on: Wed, 03 August 2011, 03:19:24 »
Quote from: LETE;391953
Not enough, not to mention it's taking forever to get things coordinated.
Offline LETE
« Reply #24 on: Tue, 30 August 2011, 21:31:19 »
Is this deal still going down or what?
Offline REVENGE
« Reply #25 on: Thu, 01 September 2011, 01:38:58 »
Quote from: LETE;407789
To be honest, this is no longer GB worthy, mainly because it turned out that there's really no appreciable stock. I might be able to get my hands on something for the first few posters, I guess we'll wait and see.
Offline dgreekstallion
  • B.S. Fiend
Re: Tenkeyless Terminal Model F (1387033) Interest Check
« Reply #26 on: Tue, 01 April 2014, 14:57:13 »
I may have got my hands on one; I will update you fellas once I presumably get it.
Recent keyboard fanatic.
Model F-122 convert.
« Reply #27 on: Tue, 01 April 2014, 15:03:34 »
wow dat necro.....
« Reply #28 on: Tue, 01 April 2014, 15:05:02 »
A little necro doesn't hurt
Offline r3dx
« Reply #29 on: Tue, 01 April 2014, 15:09:03 »
I'd be interested in one as well if there are any available. Been looking for one for a while.  :thumb:
Filco MJ2 Ninja | CM Storm QFR | CM Storm QFR | IBM Model M | IBM Model M SSK | ErgoDox |
LZ-GH
Offline Pacifist
  • on hiatus
« Reply #30 on: Tue, 01 April 2014, 15:11:58 »
check the dates
« Reply #31 on: Tue, 01 April 2014, 15:19:04 »
if they're cheap im so in
QFR | MJ2 TKL | "Bulgogiboard" (Keycon 104) | ctrl.alt x GON 60% | TGR Alice | Mira SE #29 | Mira SE #34 | Revo One | z | Keycult No. 1 | AIS65 | First CW87 prototype | Mech27v1 | Camp C225 | Duck Orion V1 | LZ CLS sxh | Geon Frog TKL | Hiney TKL One | Geon Glare TKL
Offline rodya
« Reply #32 on: Tue, 01 April 2014, 15:57:01 »
Dude, this thread is so old!
Offline dfj
« Reply #33 on: Tue, 01 April 2014, 17:00:12 »
check the date. :p
  • B.S. Fiend
« Reply #34 on: Tue, 01 April 2014, 17:21:07 »
Haha indeed it is.
« Reply #35 on: Tue, 01 April 2014, 18:21:06 »
oh wow damn
welp guess not
Offline berserkfan
« Reply #36 on: Tue, 01 April 2014, 23:52:59 »
Sign me up for two! I love model Fs! I don't need complete keycaps, but of course internals and casing must be ok.
Revenge, if you need to, allocate one with missing keycaps to me so that other geekhackers, who don't have as many spare keycaps as me, can get complete sets.
Offline Techno Trousers
  • ʘ_ಠ
« Reply #37 on: Wed, 02 April 2014, 00:01:38 »
Damn it. This April Fools joke is way over the line!
Offline berserkfan
« Reply #38 on: Wed, 02 April 2014, 01:42:34 »
Infuriating! It's no longer April 1 where I am and hasn't been for 15 hours, so I didn't realize it was an April Fool's.
« Reply #39 on: Wed, 02 April 2014, 01:53:18 »
it's still april fools in part of the world.
Anyway, This topic comes up in searches for 1387033, and makes it harder to find actual ones. I ran into this in 2012 and 2013 when I tried several times to actually get one.
Offline rodya
« Reply #40 on: Wed, 02 April 2014, 05:12:57 »
Can't tell if you guys are joking but this wasn't an April Fool's joke, people aren't looking at the date of the original post or even reading the thread.
  • ʘ_ಠ
« Reply #41 on: Wed, 02 April 2014, 22:41:06 »
The necro bump on April 1 2014 by dgreekstallion was the joke. At least I assumed it was intended as such.
If there are any more of these out in the world, the first few that go on sale will make an industrial SSK selling price look like a bargain.
  • B.S. Fiend
« Reply #42 on: Thu, 03 April 2014, 10:30:20 »
Lol, I'm not kidding guys. I found one.
« Reply #43 on: Thu, 03 April 2014, 10:33:58 »
Nice one, man. Post pics once it arrives! That really is one hell of a board you've found.
  • ʘ_ಠ
« Reply #44 on: Thu, 03 April 2014, 22:15:07 »
Congrats, that's awesome. I agree, pictures are definitely in order. And if you find any more, give ol' Techno Trousers a thought!
Offline rodya
« Reply #45 on: Fri, 04 April 2014, 00:33:40 »
No kidding, nice find.  Post pics for sure!
Offline AbuBakr
« Reply #46 on: Fri, 20 March 2015, 00:24:26 »
I'm interested if they're still here.
Offline jonathanyu
« Reply #47 on: Fri, 20 March 2015, 00:45:06 »
check the date bro... you just necro a thread that have been necroed before
Offline Data
« Reply #48 on: Fri, 20 March 2015, 10:22:16 »
A most ancient of necros has occured.   :-X
