Author Topic: [GB] Double shot replacements ROUND FOUR! - SHIPPING!  (Read 479640 times)
Offline dux
[taking orders!] Double shot replacements ROUND FOUR!
« Reply #30 on: Mon, 01 August 2011, 11:07:20 »
Expensive round will it be.
There should be some Round Three language kits left over (like Spanish). Will it be possible to order them together with the Round Four?
Offline 7bit
  • MX1A-G1DW
« Reply #31 on: Mon, 01 August 2011, 12:36:34 »
Quote from: noodles256;390637
who decided to sort and go through it this time?
We all decided it will be YOU!
Quote from: lysol;390643
Thats certainly true if you want to do different colors, but what I was getting at is maybe there could be a STD87 with a bit more of a price break than $1.
Prices are not fixed. I start with higher prices. Once you paid, I will lower the prices to trick you to get more key caps instead of a refund!
It worked perfectly in Round3. We had to stop it to make sure it doesn't getting on forever.
Quote from: dante;390721
Can I assume that the ALPs keys will fit perfectly the Matias Tactile Pro 3?
If you tell me the measures of the keys (especially the spacebar and distances of its key mounts) I can make sure it does (if possible).
Quote from: litster;390730
7bit, does MODIFIER kit include include both shifts and Enter/Return?  What is Rub Out?  Thanks.
The MODIFIER kit is an add-on kit (similar to what we had in Round 3, just in the current styles), What you mean is the MOD kit which is all the grey stuff in the graphic except for the number block and the function row, but including the \| key.
Rub Out is Delete and is found on Symbolics keyboards in place of Caps Lock.
Quote from: Lpb45;390916
Possible to get a Soware set in R4?  Pics below.
Ignore the WASD and other random caps besides the main set.
Pic taken from Taeyoung of Deskthority and OTD.
SP Has made this once or twice for OTD I believe,  I believe it was originally suppose to look differant and SP messed it up but OTD really liked it so they kept it.  I'm sure one of the OTD/Deskthority guys will come and correct me on the name and origin.
This is what I had in mind, but I did not find a picture of it.
You can have matching WASD keys and maybe this time we make a doubleshot Cherry key (maybe a bit simplified).
I think it would look better with a lighter green and red for Shift and Control.
Quote from: Garry;390859
Probably been asked before but what spacebar options are available this time round? Just Filco again?
All spacebars they can make. Someone at Deskthority investigated on how much it will be to make spacebars in new measures. I will contact him and see how much forward he came about that.
Quote from: daerid;390886
Oh man... I'm so going to get my Star Wars keys in on this.
Take your time ;-)
Quote from: dux;390935
There will be Round 3 style keys available. You can pre-order you ES kit now and have it shipped along with Round 4!
« Last Edit: Mon, 01 August 2011, 13:05:37 by 7bit »
Buy key caps here: Round 4
Buy switches here: CherryMX
Offline dux
« Reply #32 on: Mon, 01 August 2011, 13:41:54 »
I want those.
EDIT: That must have been a Lego fan.
« Last Edit: Mon, 01 August 2011, 13:43:56 by dux »
Offline 7bit
  • MX1A-G1DW
« Reply #33 on: Mon, 01 August 2011, 13:45:54 »
Quote from: dux;391053
I want those.
Why do the East Asians always get the best stuff?
edit: before you ask: It is doable, except that the font will be a bit thinner.
Offline Atenacius
« Reply #34 on: Mon, 01 August 2011, 13:52:09 »
I don't suppose there is enough interest to add the Cherry Corps red Esc key to this group buy is there?
Das Keyboard Model S BLUES w/ Cherry Doubleshots[/size]
Noppoo Choc Mini BLACKS
IBM Model M
1391401 09 MAR 93
Offline 7bit
  • MX1A-G1DW
« Reply #35 on: Mon, 01 August 2011, 13:59:23 »
Quote from: Atenacius;391064
This would be an add-on kit.
There will be red keys saying
ESCAPE
Escape
[/color] and
Escape
in white on red.
ps: Does anybody have the color codes?
« Last Edit: Mon, 01 August 2011, 14:24:22 by 7bit »
Offline agor
« Reply #36 on: Mon, 01 August 2011, 14:04:06 »
1980-style off-center, top-left, text in Camel Case.
A-Z and punctuation keys in lightblue on gray, or light gray, maybe some cold white.
Modifiers in lightblue on dark gray with additional RGB on dark gray.
+1 for Light Gray oder Cold White for A-Z and punctuation!
Topre REɅLFORCE 88UB - Noppoo Choc Mini - Cherry G80-3000 LSCDE-2 Ergo Clear - Poker X Red / Blue
Phantom Ergo Clear - Cherry G80-5000
Offline dux
« Reply #37 on: Mon, 01 August 2011, 14:04:46 »
Quote from: 7bit;391061
My daughter and all my future children NEED that:)
Offline jblack801
« Reply #38 on: Mon, 01 August 2011, 14:05:08 »
I have a question regarding the Noppoo kit. What all does it include? I see on the "Pricelist" it contains 15 keys, but only lists 11 keys in the description. Also, with the Noppoo kit, is there no way to include the other modifiers that are needed (caps, tab, enter, etc) or does one have to buy the mod kit along with it?
Thank you good sir, I've been looking forward to participating in this.
Offline 7bit
  • MX1A-G1DW
« Reply #39 on: Mon, 01 August 2011, 14:26:06 »
Quote from: dux;391075
SP does not have that frog green, but some similar one. Problematic is that they have no violett.
Quote from: jblack801;391076
These kits are only add-ons, so you need a standard kit order something like that.
It shows 11 keys also in the price list.
« Last Edit: Mon, 01 August 2011, 14:30:41 by 7bit »
Offline Atenacius
« Reply #40 on: Mon, 01 August 2011, 14:33:22 »
Thanks 7bit, but I had this one in mind. It's alright, though, I can catch that in a later group buy or something
[ Attachment Invalid Or Does Not Exist ] 22982[/ATTACH]
IBM Model M
1391401 09 MAR 93
Offline 7bit
  • MX1A-G1DW
« Reply #41 on: Mon, 01 August 2011, 14:41:13 »
Quote from: Atenacius;391093
(Attachment Link) 22982[/ATTACH]
What do you measn with 'later' group buy? This group buy (as the previous did) will work like a vacuum cleaner.
Do you want the color as close as possible to Cherry?
Offline Atenacius
« Reply #42 on: Mon, 01 August 2011, 14:48:36 »
Quote from: 7bit;391096
Well I only wanted 2 of that key, close to the original Cherry as possible but I won't scrutinize harshly. I meant later group buy just in case there wasn't enough demand but I guess this is going to be relatively big anyway
Could I order just the 2 of this key? I don't really want anything from the other kits
« Last Edit: Mon, 01 August 2011, 15:05:26 by Atenacius »
IBM Model M
1391401 09 MAR 93
Offline jblack801
« Reply #43 on: Mon, 01 August 2011, 14:52:48 »
Quote from: 7bit;391090
My mistake, I guess I was reading too much into it. Thanks for the clarification.
One more question, do you know when text style and placement will be decided on for the Dark Side kit? That looks pretty cool.
Offline Lpb45
« Reply #44 on: Mon, 01 August 2011, 15:03:42 »
Quote from: 7bit;391072
ESCAPE
Escape
[/color] and
Escape
in white on red.
7bit,
Here are some better pics if you goto sixty's old thread on DT http://deskthority.net/viewtopic.php?f=8&t=614.  Should be easier to color match,  I would bet sixty knows the codes not sure if he will get mad again saying we are copying OTD.  Copying or not its a very very nice looking set and I have no other way of obtaining it.
Im also cool with the lighter green and red aswell.
Topre - 86U   |   Filco - Tenkeyless Linear Red
Filco - Tenkeyless Blue       |   Filco - Fullsize Non NKRO Blue (Work)
  • #1 in da hood, G
« Reply #45 on: Mon, 01 August 2011, 17:38:25 »
what are the chances of going with this color scheme
No freedom until we're equal.
Offline tsangan
  • * Moderator Supreme
  • 1000/600
« Reply #46 on: Mon, 01 August 2011, 18:30:29 »
Quote from: demik;391202
That red/pink on white looks awesome
Keyboardless
Online kaiserreich
« Reply #47 on: Mon, 01 August 2011, 19:11:58 »
There was a MO on the Red on White keys at Deskthorithy 1.5 months back
Offline jinhan108
« Reply #48 on: Mon, 01 August 2011, 22:05:15 »
According to Sixty orders are closed, and production has started! (5 weeks eta)
*Edit: Digressing aside, that's a lot of choices! How to decide :S
« Last Edit: Mon, 01 August 2011, 22:07:41 by jinhan108 »
Offline jil_jil32
  • Tokyo Press <3
« Reply #49 on: Tue, 02 August 2011, 01:07:56 »
Awesome!!!
Offline 7bit
  • MX1A-G1DW
« Reply #50 on: Tue, 02 August 2011, 01:41:09 »
Quote from: dante;391357
What kind of font is being used in this photo?  I LIKE IT!
Edit: The orange WASD keys with the large print.
It is the normal Signature Plastics font.
Offline Goly
« Reply #51 on: Tue, 02 August 2011, 02:20:08 »
7bit,
I ordered a lot of things in separate pm, sorry for that, and I dont know if all are correct :( Are you going to send an email or pm to confirm the orders?
thank you very much
Offline 7bit
  • MX1A-G1DW
« Reply #52 on: Tue, 02 August 2011, 04:21:12 »
Quote from: Goly;391463
7bit,
thank you very much
Yes, I just have to tweak my script a little bit.
Online kaiserreich
« Reply #53 on: Tue, 02 August 2011, 05:18:55 »
@jil_jil32
get a Mionix and save yourself the trouble of waiting for the green on black anyway :)
Offline Laggy-gaga
« Reply #54 on: Tue, 02 August 2011, 09:39:36 »
better have some simples...
Working: Ducky Dragon Blue
Looking for: 356L
For sale:Benchmark DAC1+Stello U3+Amber,RS1i,GS1000i,HE400,HD650,w4r,se535LE
AU only
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #55 on: Tue, 02 August 2011, 09:59:40 »
Quote from: 7bit;391011
Thanks 7bit.  Is it possible to use the new ordering system to construct an order to create a moogle kit with Round 3 STANDARD set's color?  I would like a few moogle kits for my Dolch keycaps.  I think I can figure out the FG and BG colors.  But the keys I think I have problem with.
Offline 7bit
  • MX1A-G1DW
« Reply #56 on: Tue, 02 August 2011, 12:34:09 »
Quote from: litster;391556
Just posted in the "Moogle kit 2" thread. I think it should be no problem. Prices will be higer when they really go for SVG legends. On the other hand, this should ensure at least the ledgends match. Personally, I don't like to mix old and new key caps. I would keep the old caps on the old keyboards.
Offline litster
« Reply #57 on: Tue, 02 August 2011, 13:51:49 »
Quote from: 7bit;391633
Very cool!  Thanks for adding CHERRYDOLCH and previous Moogle kits.  Could you also add the Starcraft keycaps from round 3?
Edit: never mind, you already said in the wiki that round 4 will have starcraft keys again.
« Last Edit: Tue, 02 August 2011, 13:55:00 by litster »
Offline palindrome
« Reply #58 on: Tue, 02 August 2011, 13:57:25 »
Just curious, will the Star Wars keys be included in Round 4?
I'm actually interested in a modifier and a ESC key replacement.
*Sorry if this is the wrong place to post requests.
« Last Edit: Tue, 02 August 2011, 14:03:04 by palindrome »
Offline dux
« Reply #59 on: Tue, 02 August 2011, 16:01:48 »
Wiki: These prices are only valid, if at least 25 units of each kit are ordered!
What does that mean exactly? There will be many kits that wont come to 25. Will there be a new price for each one?
