So, I've noticed that some keys on the left side were "lighter" than some keys on the right on my HHKB Pro 2 (which I recently got and love for work). I first noticed the difference on the 'q' and 'fn' keys ('fn' key felt "lighter than the 'q' key). I was thinking that I was just being crazy. So, I thought I would do the nickel test on the 'q' and 'fn' keys to confirm whether I was crazy or not. So, after repeating this test multiple times, I found that the 'q' key requires about 10-11 nickels to be fully depressed and the 'fn' key requires 8-9 nickels to be fully depressed. I also found out that the nickel is about 5 grams. So, from my nickel tests, 'q' requires 50-55g and 'fn' requires 40-45g.
Is a 5-15g difference between topre switches that are supposed to be uniformly 45g weighted normal?
