Author Topic: TLDR: use Windows 98, the Cult of (Formerly the microsoft windows megathread)  (Read 70442 times)
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
Even over 10 years after its release, more people use Internet Explorer 6 than Apple computers. The fastest browser that can render modern web pages is still alive and well!
I'd say that Internet Explorer 6 has to be one of the best and most successful web browsers ever.
« Last Edit: Thu, 04 January 2018, 15:50:26 by HoffmanMyster »
Offline hcry4
  • HHKB Hoarder
Internet explorer 6 will never die
« Reply #1 on: Thu, 18 August 2011, 12:42:29 »
When I started my job 3 years ago, we were still using XP and IE6. They have since "upgraded" to Vista and IE7. It's nice to have tabs, but javascript is still crap on IE7.
Offline Pylon
« Reply #2 on: Thu, 18 August 2011, 13:29:30 »
Mostly because of businesses. Same reason XP still has massive market share. Almost every large institution I've been to still uses XP.
Offline vils
« Reply #3 on: Thu, 18 August 2011, 13:52:48 »
I used Win2K until recently.
It\'s the glass pipe fallacy. You can only believe that if you\'re on crack.
Offline The Solutor
« Reply #4 on: Thu, 18 August 2011, 14:02:22 »
I'm used to open explorer just to run windows update, if I'm running xp or older windows.
Other than that there isn't a single reason to use it for a single user.
Unluckily the corporate environment is a different matter.
Offline ch_123
« Reply #5 on: Thu, 18 August 2011, 14:09:43 »
I read somewhere that on a daily basis, for every Google search, there are 200 million COBOL transactions.
Businesses have a bad habit of perpetuating silly things like this.
Offline N8N
« Reply #6 on: Thu, 18 August 2011, 14:30:49 »
I really wish that my company hadn't written certain web-based applications specifically for IE6, as many web sites - including some of our vendors - are now completely broken for IE6.
Or at least if they'd let me install Firefox in parallel w/ IE6 so I could actually get useful work done without having to use my personal machine to look stuff up after hours.
Not that I'm bitter or anything.
« Reply #7 on: Thu, 18 August 2011, 14:33:16 »
Quote from: hcry4;401055
Multiple windows and a good window manager are superior to tabs.
Offline bluecar5556
« Reply #8 on: Thu, 18 August 2011, 14:36:15 »
IE, you mean the internet browser from IE4-6 that has shell integration with Windows Explorer and becomes unstable, if it is removed?
Eww
"Internet Explorer removal has changed over its version history, but the nature of many of its upgrades and installation methods have been a matter of public interest. The first version to be included was version 2 with Windows 95 in late 1996. Later, users who upgraded to IE3 (which came out in 1996), could still use the last IE, because the installation converted the previous version to separate directory.
However, Internet Explorer 4 created a controversy with its shell integration with Windows Explorer, and with later versions removal (or inability to do so) became more complicated. The idea of removing Internet Explorer from a Microsoft Windows operating system was proposed during the United States v. Microsoft case. Later, some security advocates took up the idea as a way to protect Windows systems from attack via IE vulnerabilities. By the release of Internet Explorer 7, some of the shell integration began being reduced, such as changing ActiveX hosting and a different look than Windows Explorer.
As of build 7048 of Windows 7, Microsoft added the ability to safely remove Internet Explorer from Windows.[2] Dependencies such as the Trident layout engine are not removed through this process, but the Internet Explorer executable (iexplore.exe) is removed without harming any other Windows components, thus preventing Internet Explorer itself from running. It was proposed that a special version of Windows 7, Windows 7 E, would be shipped without Internet Explorer in Europe as a result of EU antitrust investigations against Microsoft.[3][4][5][6][7] However, in July 2009, Microsoft cancelled the Windows 7 E editions due to negative reactions from computer manufacturers."
-Removal of Internet Explorer/Wikipedia
« Reply #9 on: Thu, 18 August 2011, 14:59:37 »
You know, Wikipedia looks a lot better in IE6 than in your posts.
« Last Edit: Thu, 18 August 2011, 15:08:19 by microsoft windows »
Offline bluecar5556
« Reply #10 on: Thu, 18 August 2011, 15:05:58 »
Is it possible to downgrade IE 8.0.6001.18702 with IE6 under XP and go back to IE8?  If so, i'll gladly check it out, it's been a while.  The reason why I ask is because this isn't my computer.
« Reply #11 on: Thu, 18 August 2011, 15:09:01 »
You should be able to do so without much trouble. I downgraded one of my computers from IE8 to IE6 a while back.
Offline bluecar5556
« Reply #12 on: Thu, 18 August 2011, 15:17:57 »
Wait, I just realized the windows software box on your avatar only says "Windows," must be 1.0?
[video=youtube_share;tGvHNNOLnCk]http://youtu.be/tGvHNNOLnCk[/video]
[video=youtube_share;e8M6S8EKbnU]http://youtu.be/e8M6S8EKbnU[/video]
« Reply #13 on: Thu, 18 August 2011, 16:29:02 »
It's a classic Windows 3.1 box.
Offline kps
« Reply #14 on: Thu, 18 August 2011, 16:33:39 »
If Internet Explorer did die, would its rotting corpse look any different than it does today?
Offline EverythingIBM
« Reply #15 on: Fri, 19 August 2011, 04:52:07 »
I'm most familiar with IE5.... those were the days. Loading up a dial-up connection on IE5 in the late 90's up until 2003. Then something horrible happened which made me temporarily "upgrade". But that's been resolved.
Offline itlnstln
« Reply #16 on: Fri, 19 August 2011, 09:03:27 »
Quote from: microsoft windows;401045
A few months off, and I still see that some things never change.
« Reply #17 on: Sat, 20 August 2011, 07:15:38 »
You gotta admit, though, that no other Internet software has enjoyed the level of popularity, success, and longeivity as MSIE6.
« Last Edit: Sat, 20 August 2011, 09:41:59 by microsoft windows »
Offline Daniel Beaver
« Reply #18 on: Sat, 20 August 2011, 08:42:40 »
Apache?
Home: Topre Realforce 87W45  /  Mionix Naos 3200
Work: Topre Realforce 87B  /  Microsoft Intellimouse Explorer 3.0
Offline keyboardlover
« Reply #19 on: Sat, 20 August 2011, 08:46:19 »
I was thinking perhaps IIS as well...
Offline kps
« Reply #20 on: Sat, 20 August 2011, 08:46:57 »
B I N D?
[Edit: stop “correcting” my spelling, vBulletin.]
Offline The Solutor
« Reply #21 on: Sat, 20 August 2011, 11:28:19 »
Sendmail
Offline bigpook
« Reply #22 on: Sat, 20 August 2011, 13:17:06 »
Postfix
Offline liist
« Reply #23 on: Sat, 20 August 2011, 23:30:55 »
Most of the computers at my workplace are still XP with IE6 or earlier. It's perfectly fine for checking logged hours and adjusting our schedules. We actually can't adjust our schedules without using IE.
Kinesis Advantage, Filco Majestouch-2 104, Unicomp Spacesaver with blank keys, Several IBM Model M\'s, two Microsoft keyboards (forever retired)
Offline bluecar5556
« Reply #24 on: Sun, 21 August 2011, 00:01:06 »
What's with websites only working with IE?  Never understood that, anyone?
Could it have anything to do with M$ shell integration into windows explorer?  Is M$ slowly becoming the ultimate monopoly alliance of all time?
"An alliance is an agreement or friendship between two or more parties, made in order to advance common goals and to secure common interests."
"The verb "monopolise" refers to the process by which a company gains much greater market share than what is expected with perfect competition."
Meanwhile, Steve Jobs with ridiculous amounts of money is being treated for his cancer with Chemical  -  Therapy drugs at "the same Clinic where Hollywood Actor the Late Patrick Swayze was undergoing chemotherapy," as the media puts a positive spin on marketing Chemical  -  Therapy.  Steve Jobs is having foreign mad-made chemicals pumped directly into his bloodstream instead of using the cancer curing properties of high concentrations from Cannabis oil extracts.  Cannabis is illegal so it MUST be bad.  :Drinks some beer of man-made ethyl alcohol:
Have people stopped questioning reality?  Seriously, the only viable competition must live on strong or else M$ will likely become one of the biggest monopolies of all time.  I wonder if Bill Gates got cancer, would he use Chemical  -  Therapy.
Windows 98
« Reply #25 on: Tue, 06 May 2014, 17:08:21 »
Get it now.
Offline Zeal
    • Zeal Generation Inc.
Re: Windows 98
« Reply #26 on: Tue, 06 May 2014, 17:10:44 »
OMG you're back!  ;D
Offline asdfjkl36
  • blue shirt guy
Re: Windows 98
« Reply #27 on: Tue, 06 May 2014, 17:12:57 »
Can i upgrade from Vista?
Offline iLLucionist
  • Topre is Love.
Re: Windows 98
« Reply #28 on: Tue, 06 May 2014, 17:20:27 »
I still have the original win 98 retail CD and STILL know the key by memory.. Oh the joy of reinstalling.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: Windows 98
« Reply #29 on: Tue, 06 May 2014, 17:23:23 »
Oldest I got is XP
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
Re: Windows 98
« Reply #30 on: Tue, 06 May 2014, 17:25:22 »
I may still have 3.11 and 95 on floppies somewhere.
Offline jwaz
  • * based mod
  • #geekhack on freenode
Re: Windows 98
« Reply #31 on: Tue, 06 May 2014, 17:29:31 »
I have a monochrome screen NEC laptop with the clip on trackball and 3.1, includes the Star Trek and Pipe Dream games. Unfortunately the Hot Dog Stand theme doesn't look as... radiant on non-color displays :/
  • Live long and prosper
Re: Windows 98
« Reply #32 on: Tue, 06 May 2014, 17:36:56 »
I see your Windows 98 and raise you Windows ME!
« Last Edit: Tue, 06 May 2014, 17:39:00 by Computer-Lab in Basement »
tp thread is tp thread
Offline Coreda
Re: Windows 98
« Reply #33 on: Tue, 06 May 2014, 17:49:29 »
98 is a POS. XP tho... pretty good.
You can't convert me,  Microsoft Windows!
Offline Michael
  • Formerly Bro Caps
Re: Windows 98
« Reply #34 on: Tue, 06 May 2014, 17:52:23 »
Windows NT or GTFO.
Re: Windows 98
« Reply #35 on: Tue, 06 May 2014, 17:56:30 »
For me, the great releases were:
DOS 2.15, 2.5, 3.3, and 6.22
Windows 95, 98, XP, and 7
One day in the next year, when I have the time and money, I will probably go to 8
"The Trump campaign announced in a letter that Republican candidates and committees are now expected to pay “a minimum of 5% of all fundraising solicitations to Trump National Committee JFC” for using his “name, image, and likeness in fundraising solicitations.”
“Any split that is higher than 5%,” the letter states, “will be seen favorably by the RNC and President Trump's campaign and is routinely reported to the highest levels of leadership within both organizations.”"
Offline eth0s
  • Peace & Love
Re: Windows 98
« Reply #36 on: Tue, 06 May 2014, 17:57:38 »
Windows is for morons.  I'll never give up my Mac.
Offline Michael
  • Formerly Bro Caps
Re: Windows 98
« Reply #37 on: Tue, 06 May 2014, 18:02:39 »
Actually, Mac OS is Windows for morons. Just pointing out these #trufax for you
Re: Windows 98
« Reply #38 on: Tue, 06 May 2014, 18:03:23 »
I'm trying to get a copy of W98 to run some older games and software. Does anyone have a copy the'd be willing to sell? Ideally, I'd install it to a flash drive to boot from.
Offline eth0s
  • Peace & Love
Re: Windows 98
« Reply #39 on: Tue, 06 May 2014, 18:05:57 »
Well, Mac OS came out first is all I know.  Maybe when Gates and his minions copied the genius work of Steve Jobs, the software got smarter in its Windows clone-form, I dunno, but Mac OS was first.
Offline hashbaz
  • Grand Ancient One
Re: Windows 98
« Reply #40 on: Tue, 06 May 2014, 18:12:35 »
Pretty sure I have my old disc and serial number somewhere.  You're welcome to it if it will be of use to you.
Re: Windows 98
« Reply #41 on: Tue, 06 May 2014, 18:15:04 »
Got my Win98 disk sitting on a CD spool somewhere around here... might actually go look for it now, just in light of this thread...
Offline Michael
  • Formerly Bro Caps
Re: Windows 98
« Reply #42 on: Tue, 06 May 2014, 18:18:22 »
Oh you mean the OS that Steve Jobs took from Xerox. Hue
Offline hashbaz
  • Grand Ancient One
Re: Windows 98
« Reply #43 on: Tue, 06 May 2014, 18:19:03 »
Great artists steal, bro.  It is known.
Re: Windows 98
« Reply #44 on: Tue, 06 May 2014, 18:19:53 »
My understanding is that Palo Alto rules over all.
Re: Windows 98
« Reply #45 on: Tue, 06 May 2014, 18:23:27 »
And/or, as my Industrial Design professor Robert Nichols said in 1973, "It is best to steal from an obscure source."
Offline osi
Re: Windows 98
« Reply #46 on: Tue, 06 May 2014, 18:39:34 »
Windows ME...such a phenomenally designed version. Thank you for reminding me!!
Offline Michael
  • Formerly Bro Caps
Re: Windows 98
« Reply #47 on: Tue, 06 May 2014, 18:43:21 »
Not too sure Xerox was 'obscure' :P
Re: Windows 98
« Reply #48 on: Tue, 06 May 2014, 18:48:57 »
I have installations (some unwrapped) for most Windows between 3.11 and XP lying around at home.  Includes some of the server variants (NT Server and 2000 Server).  Even NT TSE somewhere!
Offline YummyTreeSap
Re: Windows 98
« Reply #49 on: Wed, 07 May 2014, 01:05:31 »
