Author Topic: Looking for a really good gaming keyboard with a certain key layout..  (Read 1929 times)
Offline LT1
I've been searching everywhere, but haven't had much luck.. I can't post any links because this is my first thread... So Google "Logitech Y-UQ85" or "Microsoft's Bluetooth keyboard". They have the same exacted layout that I'm looking for.
Offline peda
« Reply #1 on: Fri, 14 October 2011, 09:22:44 »
And what do you like about their layouts so much as they seem pretty standard to me?
(only searched the Logitech one on my mobile)
Offline StaCT13
« Reply #2 on: Fri, 14 October 2011, 18:32:29 »
Both of these boards seem to have a vertical orientation of the cluster of delete, home, end, etc...
The way how the two boards actually have them laid out is different, however.
It would help if you explained a bit (and maybe why you want this layout). Also, do you have a specific switch type in mind?
ErgoDox Classic Aluminium (MX Reds) | Leopold TKL Otaku (MX Browns) | Rosewill RK-9000 (MX Blues) | Dell AT101W (Alps Black)
Happily typing in Dvorak
Offline zareliman
« Reply #3 on: Sat, 15 October 2011, 23:46:24 »
I once tried that layout and couldn't stand the weird del position. I've never seen a mechanical keyboard with that layout either.
Offline LT1
« Reply #4 on: Tue, 18 October 2011, 18:27:51 »
Quote from: peda;430935
I've been playing counter strike source for since 05 and been using this style ever since.
Offline LT1
« Reply #5 on: Tue, 18 October 2011, 18:41:46 »
Quote from: StaCT13;431366
Just for gaming really... OCZ Sabre is the only one that has that layout and that is for gaming. http://www.ocztechnology.com/ocz-sabre-oled-gaming-keyboard-eol.html The "9 OLED Macro Keys" ruin's the thought of purchasing it :faint: I would never use them.. Those are the only reason that it's soo expensive. I do not use WASD. I use the arrows and all buttons around it. I like having the gaps that this layout has. Playing with WASD is just too cluttered for me. Plus CSS only has basic controls..
