Author Topic: Used Keyboards  (Read 691 times)
Offline Mackem
Used Keyboards
« on: Sat, 15 October 2011, 11:24:55 »
So I was thinking about buying a used Filco Majestouch 1 from someone on Geekhack. He says it's 5 months old and purchased it from your site. I was wondering what would happen in terms of warranty if I bought it and it broke?
Offline Bruce
  • Moderator
    • http://www.keyboardco.com
Used Keyboards
« Reply #1 on: Sat, 15 October 2011, 12:54:26 »
Hi Mackem.
A used Filco should be a good purchase as they last very well. We will support any remaining warranty so if it is 5 months from the original date of purchase then you have the remaining 7 months. Ask for a copy of his receipt if you want to be sure about the date.
