Author Topic: Dvorak and poker.  (Read 975 times)
fossala
  • Guest
Dvorak and poker.
« on: Mon, 24 October 2011, 17:09:10 »
Does the 3rd layer on a poker (function level) change its positions when you have dvorak layout set in your OS? Can someone check it out for me?
Offline AUAnonymous
Dvorak and poker.
« Reply #1 on: Tue, 25 October 2011, 03:21:46 »
From my experience with a Noppoo Choc Mini, no it does not, and would assume it's the same for the Poker.
Noppoo Choc Mini (MX Blacks) - First mechanical keyboard :D
Why don\'t you give Colemak a try? You\'ll like it, I promise.*
*Not a real promise
fossala
  • Guest
Dvorak and poker.
« Reply #2 on: Tue, 25 October 2011, 03:22:45 »
Yeah thanks. Just had it confirmed for me on deskthority.
