Author Topic: What is your WPM?  (Read 11846 times)
Offline dewcorps
What is your WPM?
« on: Thu, 17 November 2011, 20:11:21 »
I will start off, my average WPM is usually around 51, what is yours?
Here is a typing test just in case.
Offline oneproduct
What is your WPM?
« Reply #1 on: Thu, 17 November 2011, 20:18:23 »
There have been some other threads but there hasn't been one in awhile, so I'm sure this is fine.
Mine is about 82 average, of course it really depends on how difficult the text is. Generally my lowest is around 74 and if the text is real easy I can do around 95. These are texts from typeracer and keyhero. In the TypeFaster typing tutor on the "Common Words" exercise I get just above 100 pretty consistently, but it's both easy text and I've done it so many times that I know what comes next without even having to think about it.
Poker | Filco Tenkeyless | Realforce Tenkeyless Variable Silent | Truly Ergonomic | Kinesis Contoured Advantage | IBM Model M SSK | Cherry G80-3600LYC | TG3 w/ trackpad
Kensington Slimblade | RollerMouse Free2 | Logitech M570 | Microsoft Trackball Explorer
Colemak
  • Love that PBT
What is your WPM?
« Reply #2 on: Thu, 17 November 2011, 21:20:08 »
I run about 65-85, but I'm slow compared with some here.
I remember there was a good compendium of them not too long ago where people posted typeracer (I think?) screenshots, and there was a list. I was about at the bottom.
Recently, I had to transcribe some audio in QWERTY, and I surprised myself as to how fast I could do it, but it was a lot less comfortable for me than Dvorak. I think I'm about the same speed in QWERTY, but I tire out faster.
Hmm, the flash won't load for me.
My room-mate decided to cancel the internet without telling me.
Limited internet :(
Offline rvrebel
What is your WPM?
« Reply #3 on: Thu, 17 November 2011, 21:26:53 »
80-85. When I'm typing I feel like I can go faster but my fingers just can't keep up. Which sounds stupid but if only my hands were more coordinated!
Everytime Ive tried these tests my wife has to come in the room to see wtf is all the noise. (usually gaming with headphones)
|| Filco Majestouch 2 || Rosewill RK-9000 || WASD Custom Layout ||
Offline iindigo
What is your WPM?
« Reply #4 on: Thu, 17 November 2011, 21:28:30 »
Around 65-70 according to tests, but the combination of having to read off what I'm typing plus tests making me flustered slow me down on them. When I'm just typing thoughts straight from my head, I can easily go at least 20WPM faster.
Offline Tony
What is your WPM?
« Reply #5 on: Thu, 17 November 2011, 21:30:14 »
For typing speedtest, I suggest this website
http://hi-games.net/typing
This website has nice option of replaying the whole test you've just done. It has 4 different test times.
If you are typing in Colemak/Dvorak rather than Qwerty, you can also set the layout to reflect your layout while typing as well as replaying.
Sean Wrona, World Typing Champion, is on top of all records
My hi-games.net profile:
30sec: 84wpm
1min: 78wpm
2mins: 74wpm
5mins: 71wpm
These speeds are only the fastest speed. My average speed is around 65-66wpm.
« Last Edit: Thu, 17 November 2011, 21:36:44 by Tony »
Keyboard: Filco MJ1 104 brown, Filco MJ2 87 brown, Compaq MX11800, Noppoo Choc Brown, Noppoo Choc Blue, Noppoo Choc Red, IBM Model M 1996, CMStorm Quickfire Rapid Black
Offline Quarzac
  • Oft-Forgotten Moderator
What is your WPM?
« Reply #6 on: Thu, 17 November 2011, 21:35:56 »
I just did a typeracer. I hit 51. That's basically the speed I was at on my Model M, so I'm glad I'm back at it on my Cherry blues.
Got a smaller board with white ALPS, Montereys, Cherry Blues, Reds, or Clears you'd like to offload?  Shoot me a PM. Looking for a grey Leopold FC700R in particular.
Wyse buy colors were GSY for the dark grey, GBA for the light grey, and BBI for the fonts.
Offline Foodmanchew
What is your WPM?
« Reply #7 on: Thu, 17 November 2011, 21:55:10 »
I recently learned how to touch type in September. On a site like this http://speedtest.10-fast-fingers.com/  with random easy words I get between 80-95 depending on how warmed up I am. (This is on a rubber dome or scissor switch keyboard). If I'm using a site like http://play.typeracer.com/ or http://app.typrx.com/ with passages, I'm usually around 70-85. Once there are numbers and symbols, I start slowing down. I'm sure once I'm typing on MX blues, my speed will increase. I'm hoping to consistently be around 100 by the end of the year.
Offline Playtrumpet
What is your WPM?
« Reply #8 on: Thu, 17 November 2011, 22:26:46 »
My old QWERTY speed was on average between 110-120. I stopped playing typing games for a while and my speed dropped to around 105-110 average. Then I wanted to mix things up and so I learned Dvorak.
I made this decision a few months ago, and I'm up to 100-110 average (much higher with easier words as easy/common words are especially easy in Dvorak). Because of this advantage, I've broken my high speed records with Dvorak, but I'm still working to build up to my old average speed. I spent years getting to that high average, so I'm patient about it.
Das S Ultimate Brown | Dvorak
Offline Namkung
What is your WPM?
« Reply #9 on: Thu, 17 November 2011, 22:32:14 »
I would say I average 140~150 on 10fastfingers.
no way I could hit that on other typing test sites though with punctuations, numbers, and etc. probably 120~130 on those sites.
http://profile.10-fast-fingers.com/39/Lei%20Namkung
i find myself typing fastest with red switches.
when i went to do the test on my blue after using red for some time, i found myself reading the words faster than i was typing them lol
* Proud winner of the first GH SC2 tournament *
REALFORCE 87UB 55g
Filco Majestouch 2 TKL
Offline drsauced
What is your WPM?
« Reply #10 on: Fri, 18 November 2011, 00:38:42 »
I'm usually around 80WPM on typeracer.  Much less if I'm drunk, but not much more if I'd had a lot of coffee.
Filco Ninja 104 Tactile w/PBT caps | Deck Legend Ice Linear | EK Order: #9001, #5640 | \'93 1391401 | Ping is Life
Offline bienc
What is your WPM?
« Reply #11 on: Fri, 18 November 2011, 00:44:43 »
Just got an 89wpm on the test posted by OP about astronauts. I think I could have gone faster but the year "1959" got me.
The second test put up by Tony, I got 97wpm.
Typing on my girlfriend's Sony VAIO laptop with island/chiclet keyboard.
| Rosewill RK-9000RE |
Offline cactux
  • Topre Knight
What is your WPM?
« Reply #12 on: Fri, 18 November 2011, 00:46:48 »
For how long are you able to hold such WPM ?
Offline bienc
What is your WPM?
« Reply #13 on: Fri, 18 November 2011, 00:51:14 »
I only did one minute tests and on typeracer I just got an 89 and an 85. So I guess my average is around the mid-80s. I can probably keep it up for a little while if I just have to read-type. I'm never in a position to keep typing for extended periods of time so not sure where I max out.
Offline cactux
  • Topre Knight
What is your WPM?
« Reply #14 on: Fri, 18 November 2011, 00:53:02 »
iWhat about holding such speed after 10 min? and your accuracy?
« Last Edit: Fri, 18 November 2011, 00:56:06 by cactux »
Offline bienc
What is your WPM?
« Reply #15 on: Fri, 18 November 2011, 00:57:01 »
That might be pushing it, for me at least. Never really tried it, and I don't see any of the tests listed going for more than 5 minutes.
Offline Skoobs
What is your WPM?
« Reply #16 on: Fri, 18 November 2011, 01:03:55 »
only get like 50... was getting 80 yesterday lol
Offline nar
What is your WPM?
« Reply #17 on: Fri, 18 November 2011, 01:14:14 »
According to type racer my average is 100.
On another note anyone here have their own version of touch typing rather than the standard homerow stuff? Like my hands usually rest on:
Shift, A, W, F, Hand Rest, Hand Rest, B, J, K, '
Keyboards: Topre HE0100 | REALFORCE 103UB | FILCO Majestouch 2 Ai Cherry MX Blue | CHERRY G84-4101SPAUS
Offline RColinTaylor
What is your WPM?
« Reply #18 on: Fri, 18 November 2011, 01:37:46 »
On my first Dry Run of OP's preferred test I scored an 83 but there was a lot of hickups involved in the beginning; I am not too great at capitalizing names and doing formalities associated with names.
I like my Browns more than my Blues.
Offline Foodmanchew
What is your WPM?
« Reply #19 on: Fri, 18 November 2011, 01:41:08 »
I just created a profile at Speedtest fast fingers. I topped out at 92. :)  http://profile.10-fast-fingers.com/7787/Foodmanchew
Offline dippingriz
What is your WPM?
« Reply #20 on: Fri, 18 November 2011, 01:42:15 »
~65 with normal typing ~84 was the max for me.  I don't count the test unless it's gets less than 5% error.  Speed is nice, but I like to retain some accuracy.
Offline SBI
What is your WPM?
« Reply #21 on: Fri, 18 November 2011, 02:54:56 »
[ Attachment Invalid Or Does Not Exist ] 32348[/ATTACH]
Average on typeracer is 109. English or German doesn't really make a difference for me. When working I never reach those speeds because coding isn't really represented by theses tests, so it's pratically useless :D
Offline curro123083
  • String perText = "Hello, World!"
What is your WPM?
« Reply #22 on: Fri, 18 November 2011, 08:06:53 »
I will try some of these test sometime, but when typing up Technical specification documents, I go around 90-92 and that is average for long typing sessions, speed wise I average around 112ish, I can go faster but I end up making mistakes on this crappy rubber dome, cannot wait for WASD to get red switches then Ill go into BEAST MODE! lol
WASD V1 Custom
Offline NumberJ
What is your WPM?
« Reply #23 on: Fri, 18 November 2011, 08:17:50 »
My average on Keyhero or Typeracer is around 115-120. Typing for a long time doesn't really affect my typing speed in any way, although my fingers do tend to get tired after an hour or two.
Offline weenis
What is your WPM?
« Reply #24 on: Fri, 18 November 2011, 08:59:04 »
80-95, I use typeracer as well.
Dell AT101W | Unicomp Spacesaver PC | IBM SpaceSaver Keyboard | IBM Black Label M | KBT Oni Brown | Leopold Otaku Brown | Noppoo Choc Mini Brown
Offline Lanx
What is your WPM?
« Reply #25 on: Fri, 18 November 2011, 13:14:32 »
I for one never advocate these typing tests as "accurate" or even useful, i'm not a dictation person, no i use the computer to type out words that come from my head into the computer. And with that I do it nearly one to one, of course I could talk faster, but I'm happy with the way I can just "spew" out mind to type if i have to. I think someone linked one of those programs where it just gives you a wpm of how a "real" person types instead of looking at the screen and reverbing stuff doesn't actually measure your true speed, unless all you do is dictation.
Offline bckai
What is your WPM?
« Reply #26 on: Fri, 18 November 2011, 13:17:57 »
I'd say I average between 92-95 words per minute. I topped out once around 98. Haven't broke triple digits yet, but I'm working on it.
Offline Magna224
What is your WPM?
« Reply #27 on: Fri, 18 November 2011, 19:23:21 »
I vary from the 50-65 WPM range. My typing style is odd and keys I don't use often sometimes mess me up. My maximum ever was somewhere in the 90s in high school.
Offline Playtrumpet
What is your WPM?
« Reply #28 on: Fri, 18 November 2011, 21:15:25 »
I can maintain a standard/easy literary text for 5 minutes at 108 WPM apparently. I'd say that's actually a good estimate of my current average with Dvorak.
« Last Edit: Sat, 19 November 2011, 09:33:29 by Playtrumpet »
Offline cactux
  • Topre Knight
What is your WPM?
« Reply #29 on: Fri, 18 November 2011, 22:09:44 »
Quote from: Playtrumpet;455229
I can maintain an standard/easy literary text for 5 minutes at 108 WPM apparently. I'd say that's actually a good estimate of my current average with Dvorak.
very impressive :-) . To reach such spead you must spend severals hours typing (straight hours) per day. Let me guess you are a writter :-)
