Author Topic: Removing dye infills  (Read 579 times)
Offline Tycn
« on: Tue, 22 November 2011, 06:31:07 »
Would it be possible to remove the dye infill from lasered keys (preferably without destroying the ABS) to create ghetto engraved keycaps?
« Reply #1 on: Tue, 22 November 2011, 10:19:03 »
I doubt it. I did it once, on a few Windows keys using nail polish remover and while it removed the infill very easily it also damaged the surface of the key slightly. The keys were somewhat shinier than before. Some time afterwards, when I cleaned the keys, one of the two keys turned cloudy.
Friends don't coerce their friends to use Facebook.
My daily drivers: Dolch G80-1813HFX (Cherry MX Blue dampened with dental bands), Cherry G80-3000LQCDE-2(Cherry MX Clear)
Offline itlnstln
« Reply #2 on: Tue, 22 November 2011, 10:26:14 »
I would also imagine that for infilled caps, the grooving isn't quite as deep to get the proper "engraved" effect.  It also depends on the lasering process.  WASD doesn't use an in-fill process, per se.  They use plastics that change colors as they are etched to produce contrast; I think they might even have a video somewhere, too.
Offline heliar
« Reply #3 on: Tue, 29 November 2011, 08:31:42 »
sandblas? how about those polish cream used to polish watch for example? and btw, how to fill up the grove of those laser printed letter? Mine are getting very thin.
