Author Topic: QGMLWB keyboard layout  (Read 4690 times)
Offline xorxpto
« on: Mon, 28 November 2011, 05:28:13 »
“When a modified QWERTY layout is fully optimized (where the P and ; keys are swapped),
the resulting layout is QGMLWB and effort is reduced by 44%.
Note that ZXC maintain their position relative to QWERTY, as do Q and S.„
[ Attachment Invalid Or Does Not Exist ] 33129[/ATTACH]
(For more information, go to
http://mkweb.bcgsc.ca/carpalx/?full_optimization)
• Here are the install files:
http://dl.dropbox.com/u/49319255/carpalx/qgmlwb.zip
• Typing lessons:
- install RapidTyping (http://www.rapidtyping.com/downloads.html)
Before running RapidTyping for the first time, go to directory "\RapidTyping\Resources\Lessons\" and replace file "Default.xml"
with this one http://dl.dropbox.com/u/49319255/RapidTyping/Default.zip
This file configures any layout for the English Language, showing all the lessons in levels Intermediate and expert in English.
(Note: if you skip this, and don't overwrite file "Default.xml" before running RapidTyping for the first time,
you will get only lessons for the Beginner level, on this keyboard layout)
• To try it without installing anything, use this Autohotkey file:
http://dl.dropbox.com/u/49319255/AutoHotKey/QGMLWB.exe
(Note: “Pause” key alternates between keyboard layouts)
