I have never tried a scissor switch so I can't answer that for you, but I will say that the distance is reduced quite noticeably, if the pad was any thicker, I would probably need to pass on the pads. Like sornda from above posted, he said the soft landing pads feel a bit 'mushy' and they do in fact, feel a little 'mushy' but it's better with than without. I'll order some o-rings from WASD and see how those compare. I like the soft landing, so that means I like the 'mushy' feel? heh
