Author Topic: SONY NEWS keyboard converter  (Read 21014 times)
Offline hasu
  • @tmk
« on: Thu, 05 January 2012, 23:14:27 »
SONY NEWS is a BSD UNIX workstation with M68K/MIPS from late 1980s.
This converter allows NEWS keyboards to be connected to modern PC via USB. It works with NWP-5461 and NWP-411A.
See wiki for more technical info and the latest finds.
Online Keymap Editor supports Sony NEWS now. 2023-11-03
Preassembled TMK Sony NEWS Converter is also available here: https://geekhack.org/index.php?topic=72052.0
Limitations
- Buzzer is not supported. Added tone() 2023-11-06
- LEDs on NWP-5461 is not supported. Supported now. 2023-11-07
- Mouse connection is not supported.
Notes
Keymap Editor
You can edit keymap online.
https://www.tmk-kbd.com/tmk_keyboard/editor/
Firmware
Source code is available at Github.
https://github.com/tmk/tmk_keyboard/tree/master/converter/news_usb
Hardware
You can use  8-bit USB AVR family(ATMega32u2 by default) to make your converter.
Hook up PD2 to 'Keyboard Data' pin at least(other than power). Other pins are optional.
Code: [Select]
    AVR     NEWS
    PD0     7 Mouse Data
    PD1     2 BZ(Speaker)
    PD2     3 Keyboard Data
    PD3     6 Keyboard Command(NWP-5461)
    PD4     8 POWER ON Switch(NWP-5461)
    VCC     1 VCC
    GND     5 GND
Pinout
Cnnector is an EIA 232 type with metric threads.
NWP-5461
     -------------    1 VCC
     \ 1 2 3 x 5 /    2 BZ(Speaker)
      \ 6 7 8 9 /     3 Keyboard Data(from keyboard MCU TxD)
       ---------      4 NC
                      5 GND
                      6 Keyboard Command?(to MCU RxD via two schmitt triggers of Z8 74LS14)
                      7 Mouse Data(from Mouse Ext connector)
                      8 Power switch(directly to the switch via diode)
                      9 FG
 NWP-411A
    -------------    1 VCC
     \ x 7 x 9 /     3 Keyboard Data(from keyboard MCU TxD)
      ---------      4 NC
                     5 GND
                     6 NC
                     8 NC
                     9 FG
Protocol
NEWS keyboard protocol is a usual asynchronous serial communication. You can receive data from the keyboard easily with UART of micro controller.
- TTL level
- 9600bps
- 1-start bit
- 8-data bit(LSB first)
- non-parity
- 1-stop bit.
Scan Code
Its scan code is one byte which consists of 1-bit release(break) flag at MSB and 7-bit code.
For example 0x29 is sent when 'a' key is pressed and 0xA9 when released.
   MSB         LSB
    7 6 5 4 3 2 1 0   bit
    | +-+-+-+-+-+-+-- scan code(00-7F)
    +---------------- break flag: sets when released
/* NWP-5461
 * |Pow|   | F1 | F2 | F3 | F4 | F5 | | F6 | F7 | F8 | F9 | F10| | F11| F12| ,-----------.
 * |Esc|  1|  2|  3|  4|  5|  6|  7|  8|  9|  0|  -|  =|  \|  BS | |Hlp| |  7|  8|  9|  -|
 * |Tab  |  Q|  W|  E|  R|  T|  Y|  U|  I|  O|  P|  [|  ]|Del|   | |Ins| |  4|  5|  6|  ,|
 * |Ctrl  |  A|  S|  D|  F|  G|  H|  J|  K|  L|  ;|  '|  `|Enter | |Clr| |  1|  2|  3|   |
 * |-------------------------------------------------------------| |---| |-----------|Ent|
 * |Shift   |  Z|  X|  C|  V|  B|  N|  M|  ,|  ,|  /|   | Shift  | |PgU| |  0|  .| ↑ |   |
 * |Alt   |Cap|     |         Space     |          |   |   |     | |PgD| |Tab| ← | ↓ | → |
 * | 7A|   | 01 | 02 | 03 | 04 | 05 | | 06 | 07 | 08 | 09 | 0A | | 68 | 69 | ,-----------.
 * `---'   `------------------------' `------------------------' `---------' | 64| 65| 52|
 * | 0B| 0C| 0D| 0E| 0F| 10| 11| 12| 13| 14| 15| 16| 17| 18|  19 | | 6A| | 4B| 4C| 4D| 4E|
 * |  1A | 1B| 1C| 1D| 1E| 1F| 20| 21| 22| 23| 24| 25| 26| 27|   | | 6B| | 4F| 50| 51| 56|
 * |  28  | 29| 2A| 2B| 2C| 2D| 2E| 2F| 30| 31| 32| 33| 34|  35  | | 6C| | 53| 54| 55|   |
 * |-------------------------------------------------------------| |---| |-----------| 5A|
 * |  36    | 37| 38| 39| 3A| 3B| 3C| 3D| 3E| 3F| 40| 41|   42   | | 6D| | 57| 59| 58|   |
 * | 43  | 44 | 45 |       46          |    47    | 48| 49|  4A  | | 6E| | 66| 5B| 5C| 5D|
 *  NWP-411A
 *         | F1 | F2 | F3 | F4 | F5 | | F6 | F7 | F8 | F9 | F10|
 * |Esc|  1|  2|  3|  4|  5|  6|  7|  8|  9|  0|  -|  =|  \|  BS |  |  7|  8|  9|  -|
 * |Tab  |  Q|  W|  E|  R|  T|  Y|  U|  I|  O|  P|  [|  ]|Del|   |  |  4|  5|  6|  +|
 * |Ctrl  |  A|  S|  D|  F|  G|  H|  J|  K|  L|  ;|  '|  `|Enter |  |  1|  2|  3|  ,|
 * |Shift   |  Z|  X|  C|  V|  B|  N|  M|  ,|  ,|  /|   | Shift  |  |  0| ↑ |  .|   |
 * |-------------------------------------------------------------|  |-----------|Ent|
 * |Alt   |Cap|     |         Space         |     |   |   |      |  | ← | ↓ | → |   |
 *         | 01 | 02 | 03 | 04 | 05 | | 06 | 07 | 08 | 09 | 0A |
 * | 0B| 0C| 0D| 0E| 0F| 10| 11| 12| 13| 14| 15| 16| 17| 18|  19 |  | 4B| 4C| 4D| 4E|
 * |  1A | 1B| 1C| 1D| 1E| 1F| 20| 21| 22| 23| 24| 25| 26| 27|   |  | 4F| 50| 51| 52|
 * |  28  | 29| 2A| 2B| 2C| 2D| 2E| 2F| 30| 31| 32| 33| 34|  35  |  | 53| 54| 55| 56|
 * |  36    | 37| 38| 39| 3A| 3B| 3C| 3D| 3E| 3F| 40| 41|   42   |  | 57| 58| 59|   |
 * |-------------------------------------------------------------|  |-----------| 5A|
 * | 43   |44 | 45  |       46              | 47  | 48| 49|  4A  |  | 5B| 5C| 5D|   |
« Last Edit: Tue, 28 November 2023, 22:19:48 by hasu »
Offline hasu
  • @tmk
Re: SONY NEWS keyboard converter
« Reply #1 on: Sat, 23 November 2013, 19:57:38 »
I just got my second NWP-5461 now. I found this NEWS keyboard on auction after 1 year since I got my other NWP-411A. I'm typing on this.
I found it clicks with very low volume from its speaker when I type keys today. I didn't found this click before. I guess it needs UART voltage 12V to drive the speaker properly. Clicky Topre! it is fun.
Offline Trente
« Reply #2 on: Mon, 10 July 2017, 12:02:58 »
Hey Hasu, I am wondering how the keyboard feels like compared to other topre keyboard? I had heard that it is a bit less tactile and more linear, but how is this linear feels compared to the mx black or the linear Alps switch? Also, is the LED on power switch support now or not?
Offline hasu
  • @tmk
« Reply #3 on: Mon, 10 July 2017, 16:11:56 »
Hey, yes, it feels a bit heavier and less tactile comparing to HHKB Pro2 which is snappy. in terms of tactile it is smilar to Realfoce RGB and FC980C currently in my hand, I'm not sure it is proper to compare directly to linear switches but it is heavier and more tactile than alps green.
IIRC, LEDs are not supported at this time.
Do you have the keyboard or source? I'm curious about how did/will you get it.
It would be great if you can share.
Offline Trente
« Reply #4 on: Mon, 10 July 2017, 16:59:16 »
Oh, I saw someone on Reddit (/r/mechmarket) is selling one, but he/she did not test the board, so I am still considering if I should spend few hundred dollar to get as-is keyboard. The layout of 5461 looks fantastic, and the only thing I worried is if the keyboard is still functional
Offline Trente
« Reply #5 on: Mon, 10 July 2017, 18:19:02 »
Also, sorry for my ignorance, I am wondering what is the IIRC?
Offline hasu
  • @tmk
« Reply #6 on: Mon, 10 July 2017, 20:40:03 »
I just mean "if i remember correctly" by IIRC. :D
http://www.urbandictionary.com/define.php?term=iirc
Offline Trente
« Reply #7 on: Mon, 10 July 2017, 22:11:05 »
Offline hasu
  • @tmk
« Reply #8 on: Sun, 16 July 2017, 17:23:35 »
Updated and organized first post.
- Fixed PInout: 5 GND and 9 FG had been reversed wrongly.
- Fix keymap and added README in github: https://github.com/tmk/tmk_keyboard/tree/master/converter/news_usb
Offline hasu
  • @tmk
Offline mohawk1367
  • Typing on: HHKB Pro Hybrid Type-S
« Reply #10 on: Thu, 09 November 2023, 08:10:39 »
ILY hasu  :-*
someone needs to make an aussie keyboard community called QMƎɹ┴⅄. get it? haha :D
Offline gotin
« Reply #11 on: Sat, 25 November 2023, 06:00:00 »
What are SONY news keyboards?
Online Rob27shred
  • Insane in the Membrane! 👻
« Reply #12 on: Sat, 25 November 2023, 07:14:24 »
They are super rare Topre KBs made for a Sony workstation. https://deskthority.net/wiki/Sony_NEWS_NWP-411A
