Author Topic: Topre red caps and any Cherry MX key caps(do not need full set, need at most 5 or 6)  (Read 469 times)
Offline limmy
UPDATE: No longer needed. Thanks!
I want to buy
1. Topre red Esc key with letters.
If it is like new, I am willing to pay elitekeyboard price of $4.5 plus shipping. (the caps are not in stock in EK)
If you have both non-printed and printed versions and are willing to sell both, I want to buy them both. My first preference is the key cap with letters.
2. Any Cherry MX key caps, preferably ABS
I am going to create my own key cap and I am going to use the inside stem(?) of a key cap. I would prefer ABS because they are easy to bond and easy to work with. Basically, I am looking for crappy key caps to be used as parts. I need only couple of them, at most five or six in case I fail.
Since I am asking for caps that you would rather throw away, I would prefer if you would sell Topre caps.
This is my first time posting here at classified, so I might need some guidance. Thanks!
« Last Edit: Thu, 26 January 2012, 12:29:09 by limmy »
Offline limmy
Still looking for the red Esc key.
I bought some Cherry key caps from wasdkeyboards for $1 each. Bought some colored caps from them too.
Offline limmy
Bought Esc with wasd blanks. Thanks.
