Author Topic: Repeat of message sent to support@keyboardco.com...  (Read 1084 times)
fossala
  • Guest
« on: Fri, 10 February 2012, 16:19:24 »
I sent this to the company email address as well but thought you may catch it first on here.
I placed an order earlier today and regret doing so because I realised the
keycaps are going to be like the ones on my poker. My order is KC30641. I
still want to order with you and spend more money. If you still have them
in stock can you change my order from the full size realforce (UK) to the
white 86u realforce? I will need to add some extra money, 10gbp plus vat.
If you can do this I will be most grateful, and thekeyboardco gets 10gbp
more :).
Thanks,
Dave (fossala from GH).
Offline Bruce
  • Moderator
    • http://www.keyboardco.com
« Reply #1 on: Mon, 13 February 2012, 05:18:14 »
Hi Dave
I think Hels  got this sorted. Let me know on bruce@ if there's any problem.
Offline Hels
« Reply #2 on: Mon, 13 February 2012, 10:14:08 »
All sorted, goods should be with you tomorrow Dave.
fossala
  • Guest
« Reply #3 on: Mon, 13 February 2012, 10:48:12 »
Awesome thanks. Do you have a tracking number? If so can you pm/email me it?
EDIT: I meant this to be a pm, woops
Offline Hels
« Reply #4 on: Tue, 14 February 2012, 09:51:01 »
Just checked your tracking asnd see that you have received the delivery. Enjoy :-)
fossala
  • Guest
« Reply #5 on: Tue, 14 February 2012, 11:01:22 »
Thanks, just got home and got it. A couple of keys are quite wonky but I will forgive you as it is your last one and you changed my order at the last minute.
