Author Topic: O-Rings - various sotfness and thickness [GB leftovers]  (Read 4069 times)
Offline WhiteFireDragon
    • youtube
« on: Sun, 26 February 2012, 00:20:23 »
The O-ring group buy round1 is concluding, and I ordered extras based on price and popularity. If you missed the group buy, here are the leftovers. To be straightforward, I'm tacking on an extra $1 to the leftovers since it's not fair to those that had to pay and wait a couple weeks, and also to myself for fronting the money to order it a month ago.
SHIPPING: is included in the base price for the US. International is an extra dollar. It take 1-3 days to receive it in the US, about a week in Canada, and between 7-14 days for the rest of the world. Depending what time I receive the payment, I ship out same day or the following day.
  • base price is for TKL 90 count pack
  • add $2 to base price for full size 105 count pack
  • add $4 to base price for extras, 120 count pack
  • add $1 to base price for international shipping
[/SIZE]
[strike]pack A: $10
40A, 3/16" ID, 1/16" W[/strike]
[strike]pack B: $14
50A, 3/16" ID, 1/16" W[/strike]
[strike]pack C: $14
40A, 5mm ID, 2mm W[/strike]
[strike]pack D: $13
40A, 5mm ID, 1mm W[/strike]
[strike]pack E: $20
40A, 3/16" ID, 3/32" W[/strike]
[strike]pack F: $5
70A, 3/16" ID, 1/16" W[/strike]
[strike]pack G: $5
70A, 3/16" ID, 3/32" W[/strike]
[strike]pack H: $16
30A, 5mm ID, 1.5mm W[/strike]
payment instructions: If you want to send money via amazon payment, PM me. Otherwise, send to my paypal address whitefiredragon1 @ hotmail.com. Please cover paypal fees (3% + $0.30), unless you send as "gift" payment. Include in the paypal note:
  • forum name
  • which pack (A, B, C, etc.)
  • pack size (90, 105, 120)
  • shipping address
[/SIZE]
« Last Edit: Tue, 17 April 2012, 15:28:07 by WhiteFireDragon »
    • youtube
« Reply #1 on: Sun, 26 February 2012, 00:20:46 »
Here are a few pics I took. O-rings A through H are the ones offered in this group buy. "X" is the 5mm x 1.5mm offered by kaiserreich, I bought a pack from him just to try out and compare. The two gimped ones you see on the left are the very first O-rings I ordered when I was a newb. Epic size mistake lol.
In order by packs
In order by size
Additional pics:
1 2 3 4 5 6
pack A: Silicone or EPDM. The most ordered pack. It has a very small key travel reduction, so you may or may not notice it. It dampens the noise pretty well, and eliminates almost all of the “shock” you feel when the key hits the bottom. If you can’t decide which pack to get, try these ones first. Can’t go wrong with these ones, they’re good all around. I’ll be using pack A as a point of reference when comparing with other packs.
pack B: EPDM. These are nearly the same as pack A. Size is identical, but just a tad harder, which can only be felt if you pay very close attention. Otherwise if you mix and match the whole keyboard randomly with pack A and B, you most likely won’t be able to tell which is A or B. Noise dampening is the same as pack A, only difference is the hardness felt when keys hit the bottom. These should have been the same price as pack A, but only reason why it’s more expensive is because I asked for this option after I already got a quote for pack A. I don’t feel there is a large enough difference to justify this as another option based on price and characteristics, so these will be dropped in the next round. Just get pack A if you want something like this one.
pack C: EPDM. There is a noticeable key travel reduction with these, but that’s what it’s meant to do. Thickness is essentially in between pack A and E, so good if you want something thicker than A, but feel that E is too thick. I personally had a hard time deciding to use pack C or E. Otherwise, shock absorption and noise dampening is the same as pack A.
pack D: EPDM. I should rename this to “useless” pack. 1mm thickness is too thin. So although it did nothing to key travel reduction, it also didn’t do anything to noise dampening. The only time I can see this option being useful is if you bought some SP caps with short stems where these will make a difference. I don’t have a full set of SP caps, so I can’t comment on how useful it will be on those caps. However for stock caps and PBT caps from KBC, these had no effect. They will also be dropped in the next round.
pack E: Silicone or EPDM. This one is my personal favorite, but I know it’s not for everyone. It’s the max thickness you can have in an O-ring. It bottoms out just after the key’s registration point. This simulates scissor switches on laptops or thin membrane keyboard, but still retains the “mechanical” feel from MX switches. The main purpose of this pack is to reduce the key travel, but if this is not what you’re looking for, then get pack A.
pack F: Nitrile. Same size has pack A, but noticeable harder. These are only for people that think pack A is too soft or want to retain as much of the bottom out feeling as possible. It will still dampen most of the “clack” noise when the keys hit the bottom, but not as well as pack A. They feel great on PCB mounted switches since there is almost no change in the “natural” feel of bottoming out on the PCB.
pack G: Nitrile. These are the exact opposite from pack A, it’s different in size and softness. It’s essentially pack E, but harder.  They’re for those that want a max key travel reduction crips bottom outs, and some noise reduction.
pack H: Silicone. This pack is the most interesting of all of them. It’s the softest feel of all of them and only comes in silicone because the other materials can’t reach this level of softness. These are a tad thinner than A, B, or F, which is what gives it the unique characteristics. Under normal typing conditions, it will eliminate most noise and shocks. However, because of the exact thickness of it, combined with its extra softness, it will feel like there’s no O-ring at all if you hit the keys very hard. This sort of gives the whole keyboard a dampening “film” effect, where the shock and noise dampening properties are there, but thin enough so there are no key travel reduction.
Offline RColinTaylor
« Reply #2 on: Sun, 26 February 2012, 00:34:06 »
I love the very organized and detailed sale; GLWS!
I like my Browns more than my Blues.
Offline abc123asd
« Reply #3 on: Sun, 26 February 2012, 00:34:50 »
can i get pack A, 1 pack? international postage
Offline sawedust
  • Zealot Chef
« Reply #4 on: Sun, 26 February 2012, 00:42:21 »
Aww man, would've loved to get a Pack E but you're sold out :(
GLWS!
find me on twitter: @sawedust
starcraft 2 related blog: QuanticSawe.851
QuanticGaming.com
Offline LFF
« Reply #5 on: Sun, 26 February 2012, 01:12:49 »
Order placed!
Thanks!!!!
Offline Moistened
« Reply #6 on: Sun, 26 February 2012, 01:56:24 »
Sent order
  • #1 in da hood, G
« Reply #7 on: Sun, 26 February 2012, 02:11:49 »
might want to space out your email so bots dont get to it and start sending you spam
and I'm the dirtiest thing in sight, matter of fact bring out the girls and let's have a mud fight.
Offline dirge
« Reply #8 on: Sun, 26 February 2012, 09:26:35 »
A F and G please, sent payment.
« Last Edit: Sun, 26 February 2012, 09:31:34 by dirge »
Thinking about things isn't the same as doing things. Otherwise everybody would be in jail.
Offline metafour
« Reply #9 on: Sun, 26 February 2012, 10:01:39 »
Sent payment for a pack F
Offline megnin
  • Topre, or not Topre? That is the question.
« Reply #10 on: Sun, 26 February 2012, 10:58:48 »
Payment sent for 3 A's
“The only difference between me and a madman is I'm not mad." -- Salvador Dali
Offline m_enanos
  • The Netherlands - Car lover;
« Reply #11 on: Sun, 26 February 2012, 12:27:47 »
Payment sent for 1 A pack
    • youtube
« Reply #12 on: Sun, 26 February 2012, 14:31:22 »
One pack C just sold, only 1 left. Packs G and H are now out.
    • youtube
« Reply #13 on: Sun, 26 February 2012, 21:21:44 »
Someone just sent me payment for 2 90count pack A. You didn't included your forum name in the paypal notes, and didn't PM me about it, so I have no idea who it is. For record-keeping sake on my spreadsheet, please PM me so I can update it.
Last two pack F are pending payment.
    • youtube
« Reply #14 on: Thu, 01 March 2012, 11:59:28 »
The rest of F and C are gone.
Offline xquisit
« Reply #15 on: Mon, 19 March 2012, 07:15:02 »
Pack A TKL
Payment Sent as Gift
(thanks for PMing me about this WhiteFireDragon)
I\'d rather die like a man than live like a coward - 2pac
Offline dippingriz
« Reply #16 on: Mon, 19 March 2012, 15:57:14 »
Pack A for a Poker/tkl
Payment Sent
« Last Edit: Mon, 19 March 2012, 16:06:58 by dippingriz »
Offline daerid
    • Careers 2.0
« Reply #17 on: Mon, 19 March 2012, 16:33:57 »
Payment sent for one 90 ct Pack A
RF 87UB 55g AE | RF 87UB 55g - StormTrooper | Leopold FC660C | Unicomp Ultra Classic | Matias Tacile Pro 3
DeathAdder 2013 | Taipan | Sensei | G400 | IE 3.0 | RAT 7 | Perf MX | Imperator | DeathAdder | SS Cata | G500
    • youtube
« Reply #18 on: Tue, 20 March 2012, 03:52:53 »
If you sent payment during the weekend or Monday, your O-rings were shipped out yesterday (Monday).
And there was also one person that sent me payment with no notices in this thread or PM. Please PM me so I know who you are. Postal code is SE24 9NA.
Offline BigDov
« Reply #19 on: Tue, 20 March 2012, 16:03:32 »
sent you a PM and paypal for some of the "A" o-ring's......
Offline filphil
« Reply #20 on: Tue, 20 March 2012, 18:21:22 »
Paypal payment sent for 90 TKL Pack A
    • youtube
« Reply #21 on: Wed, 21 March 2012, 17:54:19 »
There was enough orders yesterday to justify another shipment that just went out this morning :)
Offline xquisit
« Reply #22 on: Wed, 21 March 2012, 18:59:38 »
You are the man! :D
Offline filphil
« Reply #23 on: Wed, 21 March 2012, 23:15:31 »
Sounds good
Offline c0rbin
« Reply #24 on: Sat, 24 March 2012, 19:33:14 »
Is there gonna be another group buy? I want some G's...
Filco Majestouch-2 Tenkeyless Cherry MX Brown w/ PBT caps and O-ring mod
Offline xquisit
« Reply #25 on: Sat, 24 March 2012, 19:53:50 »
They arrived two days ago (O-rings from WhiteFireDragon):
[ Attachment Invalid Or Does Not Exist ] 45563[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 45564[/ATTACH]
Thanks for the quick delivery!
EDIT: How do we do our feedback scores?
Online WRXChris
« Reply #26 on: Tue, 27 March 2012, 15:04:22 »
just sent payment for 1 pack of A - 90 count.  Thanks!
Offline Zifle
« Reply #27 on: Tue, 27 March 2012, 16:19:29 »
Is there enough rings of Pack A left, for a 120 set? Could do with a 105 otherwise, but I want to make sure before ordering, considering it says limited in the OP 3:
Filco MJ2 Ninja                          CMStorm QFR     I like cats.
Offline jandd
« Reply #28 on: Wed, 28 March 2012, 00:40:28 »
Payment sent for 120 pack A. Hope there's still some left :)
Offline Zifle
« Reply #29 on: Wed, 28 March 2012, 02:04:55 »
Quote from: jandd;558879
^ Same ^_^ (He did say there were a couple of packs left, so no worries)
