Author Topic: [COMPLETED!] WYSE Moogle Kits!  (Read 28288 times)
Offline Quarzac
  • Oft-Forgotten Moderator
« on: Sun, 26 February 2012, 01:58:59 »
SP screwed up the original order/shipment, and forgot a ton of keys. The rest of them should be with me by the 22nd. You should have your sets by the end of the month, if all goes well.
Alright, so like Hashbaz mentioned in his thread, I'm gonna run a WYSE moogle kit buy. I figured I'd take some of the sorting and planning off Hashbaz's hands, since I have the time, and also wanted a fairly simple GB to start off with, since this will be my first group buy dealing with SP. The buy is now closed to international orders, as I already have a million customs forms to fill out, and no time to do it.
The kits will include the following:
BASE KIT WYSE
2 Control 1.25x
2 Alt 1.25x
2 Win 1.25x
1 Menu 1.25x
1 Right shift 2.75x
1 Capslock 1.75x
1 Spacebar 6.25x
1 ANSI left shift 2.25x
1 ISO left shift 1.25x
1 Enter 2.25x
1 Backspace 2x
1 Backslash (\|) 1.5x
And the second kit would consist of:
WINKEYLESS ADD-ON KIT
2 Control 1.5x
2 Alt 1.5x
2 Win 1x
1 Space 7x
Alright! So Melissa got back to me on pricing:
Basic Kit (15 total keys):
25 sets          $36.65 / set
50 sets          $23.27 / set
75 sets          $18.81 / set
100 sets        $16.58 / set
Addon Kit (7 total keys):
25 sets          $9.26 / set
50 sets          $6.90 / set
75 sets          $6.12 / set
100 sets        $5.72 / set
So now I'm going to start taking orders for these. I don't want this thing to get out of hand, so I'm going to limit this buy to these caps, and in the event that others are needed, I may do another buy in the future. Shipping will be an additional $6 on top of your order cost, $8 if you're international. Thanks, guys!
ORDERING
Shoot me a PM with your order, your address, and your paypal email. Something like this
1x Base Kit
2x Addon Kit
Chris Brown
100 Imaginary Street
Funland, PA 28542
[PaypalEmail@gmail.com]
This buy will close 12:00AM EST March 16th. I'm closing it early in the morning so I have the full day to correspond with SP with a finalized order. I want to wrap this up as quickly as possible before things get really busy for me. No orders will be collected after that. If I receive one, I will mock you for your lack of reading comprehension.
ORDERS
[table=width: 300, class: grid, align: left]
UserPaid?
Rainb1oodYes!
KisakukuYes!
LitsterYes!
OmuerteYes!
AutolyzeYes!
DirgeYes!
BoostYes!
ReaperYes!
KaiserreichYes!
BavmanYes!
RobatYes!
InlikeflynnYes!
KylJoyYes!
DenonicYes!
jpm804Yes!
SoulpyreYes!
eth0sYes!
TranscendingLogicYes!
KorneYes!
ForinYes!
DanGWanGYes!
XbbYes!
Shawn oYes!
DorkvaderYes!
SthYes!
Lan123Yes!
Jinhan108Yes!
PostlapsaetiaYes!
MegninYes!
ChangdrewYes!
LowkeyYes!
jdcarpeYes!
AkimboYes!
biochemYes!
tbagYes!
hazeluffYes!
TranquilliteYes!
MyNameIsFinnYes!
Orders are final and closed.
« Last Edit: Fri, 20 July 2012, 18:40:47 by Quarzac »
Got a smaller board with white ALPS, Montereys, Cherry Blues, Reds, or Clears you'd like to offload?  Shoot me a PM. Looking for a grey Leopold FC700R in particular.
Wyse buy colors were GSY for the dark grey, GBA for the light grey, and BBI for the fonts.
  • #1 in da hood, G
[SHIPPING DELAYED] WYSE Moogle Kits!
« Reply #1 on: Sun, 26 February 2012, 02:04:12 »
off the bat i know i need a backspace, |\, enter, tab, capslock and both shifts.
i got a terminal board so honestly, the only thing that works for me is the alphanumerics and arrow keycaps.
No freedom until we're equal.
Offline kaiserreich
« Reply #2 on: Sun, 26 February 2012, 02:09:18 »
standard 1.25x
Phantom compatible kits
Online Autolyze
« Reply #3 on: Sun, 26 February 2012, 09:00:00 »
I just ordered some WYSE keycaps the other day, so this Group Buy has pretty nice timing.
I'll definitely be in need of: Shifts, 1.25x/1.5x modifiers, and |\.
I *think* my enter and backspace are okay, but it's hard for me to tell without the keycaps here.
I'm not sure if anyone else needs it, but I could use a home cluster.
Das MX Brown | Filco Tenkeyless MX Brown | Leopold Tenkeyless MX Blue | Realforce 87UB 45g | Leopold Tenkeyless MX Red | Leopold Tenkeyless MX Clear | IBM SSK Grey Label | KBC Poker X MX Black/Red | Realforce 87UW 55g | Siig MiniTouch White XM | Honeywell Keypad Hall Effect | Ducky 1087 Green XM | KBC Poker X MX Ghetto Green/Blue | Siig MiniTouch Monterey Blue| IBM SSK Grey Label #2 | Cherry G80-2551 MX Black
Offline inlikeflynn
  • give me your 1800's
« Reply #4 on: Sun, 26 February 2012, 09:09:02 »
I got lucky with my set and just need caps lock and then the usual shifts/wins/ctrls/wins/meta key. but mine are the thiner ones for sure made by SP later in life.
On that note, what about doing a full WYSE key set and then these moogle kits can just be addons to that if needed and maybe lower cost. Maybe not though since there are a million other full key set group buys kicking off
  • Love that PBT
« Reply #5 on: Sun, 26 February 2012, 09:36:25 »
Yeah, if you have a terminal from a WYSE 50 or 60, you'll need a lot of keys replaced. Basically, only the Alphanumerics, keypad numbers, and function keys will work. They don't even have a numlock key.  If you have the WYSE PCE modern-looking keyboard, then you can get away with needing much less.
I will get out my WYSE and check what's necessary and update this post later.
My room-mate decided to cancel the internet without telling me.
Limited internet :(
Offline dirge
« Reply #6 on: Sun, 26 February 2012, 09:57:04 »
Count me in on this, although what I actually need yet I'm not sure :)
Thinking about things isn't the same as doing things. Otherwise everybody would be in jail.
Online rainb1ood
« Reply #7 on: Sun, 26 February 2012, 10:56:40 »
I have a WYSE kit that needs:
x1 1.75 Non-stepped Capslock
x2 1.25 Ctrl
x2 1.25 Alt
x2 1.25 OS
x1 1.25 App
x1 Space bar (Filco)
Here is a photo of my WYSE set on a White Filco MJ2 with Grey PBT modifier from SP (thanks to pitashen for the idea), stock Spacebar, hashbaz's RGBY kit, and a Beige/Gray Capslock from Whiskerbox:
Online tsangan
  • * Moderator Supreme
  • 1000/600
« Reply #8 on: Sun, 26 February 2012, 11:08:07 »
BASE KIT WYSE
2 Control 1.25x
2 Alt 1.25x
2 Win 1.25x
1 Menu 1.25x
1 Right shift 2.75x
1 Capslock 1.75x
1 Spacebar 6.25x
1 Enter 2.25x
1 Backspace 2x
No point in making separate kit for those 3 keys, as A. there is no legend fees won't add much to cost, and B. a lot of WYSE sets out there are terminal sets which required those.
For simplicity sake I suggest both shift is included in the base kit or we can have what we did in the RGBY kit where you choose what shift you want.
Not sure how popular a 1.5x set will be but you can do it as a add-on
2 Control 1.5x
2 Alt 1.5x
2 Win 1x
1 Space 7x
« Last Edit: Sun, 26 February 2012, 13:06:44 by tsangan »
Keyboardless
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #9 on: Sun, 26 February 2012, 11:57:00 »
I like the base kit and the 1.5x addon kit.  If you saw my wyse picture before, I put a terminal set and an ANSI set together, use thick caps when I can, and all I need are the front row keys (on a tenkeyless Filco).
Offline 7roi
« Reply #10 on: Sun, 26 February 2012, 12:57:09 »
I like the base kit & add-on kit too.
I wish to add capslock(step) key.
Both version's space key size is the same?
« Last Edit: Sun, 26 February 2012, 13:08:34 by 7roi »
Online tsangan
  • 1000/600
« Reply #11 on: Sun, 26 February 2012, 13:07:01 »
Quote from: 7roi;526909
Whoops forgot the 7x spacebar
Fixed!
Keyboardless
Offline IvanIvanovich
  • Cherry Overfiend
« Reply #12 on: Sun, 26 February 2012, 13:10:21 »
Based on the worst possible Wyse to have gotten, you may need: 8 1.25 modifiers (extra one for caps if use ctrl in caps location), both shift, enter, \, backspace, `, R3 caps lock if not want to use ctrl, all 6 keys for nav cluster, numpad 2unit vertical +, numlock, /, *, -, and spacebar.
That should cover everything. I know not everyone will need all that, but also there are some other boards like the ASCII terminal that have black legend instead of navy, so it wouldn't hurt to have all match either.
Online tsangan
  • 1000/600
« Reply #13 on: Sun, 26 February 2012, 13:18:27 »
Quote from: lysol;526919
Dunno how well these will do
Wyse is a lot less popular then Cherry so less is better instead of big kits with many add-on kits
Keyboardless
  • #1 in da hood, G
« Reply #14 on: Sun, 26 February 2012, 13:18:41 »
sadly, i need everything mentioned here.
although i could do without the tenkey part since my boards are tenkeyless.
  • Cherry Overfiend
« Reply #15 on: Sun, 26 February 2012, 13:23:04 »
Sure, just saying which keys are often incompatible with modern layouts from different Wyse boards. Some are near complete, with only the bottom row needed, some need everything but the alpha numerics and f-keys, and some in between. There are about a dozen different Wyse layouts to possibly account for.
Online tsangan
  • 1000/600
« Reply #16 on: Sun, 26 February 2012, 13:23:46 »
BASE KIT WYSE
2 Control 1.25x
2 Alt 1.25x
2 Win 1.25x
1 Menu 1.25x
1 Right shift 2.75x
1 Capslock 1.75x
1 Spacebar 6.25x
1 Enter 2.25x
1 Backspace 2x
2 Control 1.5x
2 Alt 1.5x
2 Win 1x
1 Space 7x
HOME CLUSTER ADD-ON KIT
9 Home cluster keys
TENKEYPAD ADD-ON KIT
1 vertical + 2x
1 numlock 1x
1 / 1x
1* 1x
1- 1x
With all the different WYSE formats out there it's hard to make a base kit, since like Litster and Lysol said, some sets only require the bottom row so it doesn't really make sense to have such a large kit.
BUT if we split everything up into add-on kits, the volume might not be there. Hard to judge ._.
« Last Edit: Sun, 26 February 2012, 22:05:16 by tsangan »
Keyboardless
Offline Quarzac
« Reply #17 on: Sun, 26 February 2012, 14:45:00 »
Because I already sent an email, as of right now it's the base and the addon kit from the first page. We'll see how that goes.
Online tsangan
  • 1000/600
« Reply #18 on: Sun, 26 February 2012, 15:01:39 »
Quote from: Quarzac;527024
You included a 7x space bar right? I had to add that in because I forgot :P
Keyboardless
Offline Quarzac
« Reply #19 on: Sun, 26 February 2012, 15:18:51 »
Yeah, I sent it after your edit. That much is cool.
Offline flags
« Reply #20 on: Sun, 26 February 2012, 16:16:52 »
Could someone explain/link to a wiki that explains what this "moogle" kit is? Been hearing it a lot and I still don't know what it is.
KBC Poker w/ Blue Switches - Razer BlackWidow
« Reply #21 on: Sun, 26 February 2012, 16:28:23 »
Quote from: flags;527147
It is explained in the Deskthority wiki.
« Last Edit: Sun, 26 February 2012, 16:43:00 by Findecanor »
Friends don't coerce their friends to use Facebook.
My daily drivers: Phantom (Cherry MX Clear)
Offline flags
« Reply #22 on: Sun, 26 February 2012, 16:46:58 »
Quote from: Findecanor;527163
Offline KylJoy
« Reply #23 on: Sun, 26 February 2012, 20:25:37 »
I think I need all of the various pieces.  I'm in for:
BASE WYSE
May my bank account forgive me.  :violin:
  • Love that PBT
« Reply #24 on: Sun, 26 February 2012, 21:39:38 »
What about Print screen, scroll lock and pause? Tsangan has most of the needed ones, but I think those are also necessary.
I'd be in for a full++ kit or two. I love my WYSE.
Limited internet :(
Offline KylJoy
« Reply #25 on: Sun, 26 February 2012, 21:41:01 »
I need those too...  missed 'em.
Online tsangan
  • 1000/600
« Reply #26 on: Sun, 26 February 2012, 22:05:00 »
I honestly think its easier to find a set with a good tenkeypad/home cluster then making kits as the interest of them could be real low.
The base kit covers most things.
Oh yes, that home cluster kit should be 9 keys ._.
Keyboardless
  • Love that PBT
« Reply #27 on: Sun, 26 February 2012, 22:59:08 »
Quote from: tsangan;527560
But I only have a WYSE 30, 50 and 60. None of those have a proper keypad. Can we at least get pricing for it, and then see about interest? It may be that there's enough to make it worthwhile.
Limited internet :(
Online tsangan
  • 1000/600
« Reply #28 on: Mon, 27 February 2012, 00:01:41 »
Quote from: dorkvader;527619
Of course, It shouldn't be too bad because no custom legends but you never know from SP
Keyboardless
Offline Quarzac
« Reply #29 on: Mon, 27 February 2012, 17:20:48 »
OP updated with pricing information. Consider this buy open for orders. No kits outside the current two will be explored in this buy, but may be addressed in a future buy. I'm concerned as is for interest in these.
