Author Topic: [Orders closed] Aluminum poker case  (Read 11318 times)
Offline oneproduct
« on: Fri, 16 March 2012, 16:44:06 »
[video=youtube;qjjYCRJ-e20]http://www.youtube.com/watch?v=qjjYCRJ-e20[/video][video=youtube;wyIwWf45Dss]http://www.youtube.com/watch?v=wyIwWf45Dss[/video][video=youtube;2YLtQF0Emf0]http://www.youtube.com/watch?v=2YLtQF0Emf0[/video][video=youtube;Me-Zr7lCpwY]http://www.youtube.com/watch?v=Me-Zr7lCpwY[/video][video=youtube;UO4_Eg6_E2s]http://www.youtube.com/watch?v=UO4_Eg6_E2s[/video][video=youtube;47p43RY9rNc]http://www.youtube.com/watch?v=47p43RY9rNc[/video][video=youtube;CNSjdYfjhbk]http://www.youtube.com/watch?v=CNSjdYfjhbk[/video]
Pictures here: http://geekhack.org/showthread.php?28132-Got-an-awesome-price-quote!-See-post-230-Aluminum-poker-cases&p=548042&viewfull=1#post548042
And here: http://geekhack.org/showthread.php?28132-Interest-check-Poker-aluminum-or-stainless-steel-cases&p=540275&viewfull=1#post540275
Quick and updated info
Material: 5052 aluminum
Thickness: 3/16"
Weight with keyboard: 2 pounds, 8 ounces
Weight without keyboard: 1 pound, 14 ounces
Attachment method: the metal insert will be attached to the metal base using glue (not normal crappy white glue but glue meant for this kind of a thing)
Finish: brushed
Color options: blue, red, gold (see here http://geekhack.org/showthread.php?29356-ANODIZING-for-aluminum-poker-cases)
Cost: $82.62 for the case + optional anodizing + actual cost of shipping from me to you. Payable to: stephenpoconnor@gmail.com
Older info below which is still partially relevant
This is the order thread for hand made aluminum Poker cases. This is not made using a milling machine (CNC). So just as a warning, if you are looking for machine perfection, you may be disappointed as there will be minor signs of assembly (welding), so please take that into consideration. On the other hand, you could say that it gives it character! There are plenty of pictures and video footage of what you can expect for the most part. The one illustrated was the prototype however so most notably the USB jack cutout is very ugly looking but it will be cut square on the production versions.
The outside of the case will be glass beaded (similar to sandblasting). This is done to hide signs of scuffing that develop during the manufacturing process as the metal is handled, so it is not really optional. The top edge and inside of the case will not be glass beaded. It is made using 3/16" thick 5052 aluminum and weighs 1 pound, 14 ounces without the keyboard inside of it or 2 pounds, 8 ounces with the keyboard inside it. The body of the case is a single sheet of aluminum folded up to create the walls and the walls are then welded at the corners. The keyboard is mounted onto a separate metal insert that will then be [strike]glued[/strike] tacked (minor welds) to the body.
Price
The actual price I was quoted is $64 per case. This price will not go down if there are more orders as these are made by hand, not machine, so it's no easier to make them in bulk than it is to make just a few.
The effective tax rate in Quebec is 14.975%, so with taxes it comes to $73.584 ~ $73.50. I then need to charge for the price of screws, insulating material and [strike]glue (still looking into the possibility of having it spot welded aka "tacked")[/strike] (tacking confirmed!). I'd like to charge $80 per case then to cover this and it will probably leave me with just a little extra which will allow me to get a case for myself for free, which I think is fair for my part in this. Other than that this is a non-profit project I took up for the benefit of the geekhack community so prices are as close to the actual cost as possible, enjoy!
Rubber feet are not included, so you will have to figure out something of your own if you want to elevate the back end of the case. Ergonomically speaking though, it's better to let your keyboard lie flat! I don't plan to use any feet at all.
Shipping
This price does not include the cost of shipping. You will be charged the actual cost of shipping when it comes time to ship out the cases. Please bear in mind that when packaged this will weigh about 2.5 pounds (heavy in terms of shipping costs!) and will be placed inside a box approximately 3" wider than the Poker in all dimensions to allow for padding. If you are not located in the United States, I highly encourage you to look up the cost of shipping from Pointe-Claire, Quebec, H9R 5L9, Canada to your location using Canada Post (http://www.canadapost.ca/cpotools/apps/far/personal/findARate?execution=e1s1) so that you have an estimate of what shipping will cost you so you know what to expect. If you pay for the case and then realize that you can't afford shipping later I won't be able to refund you, so make sure you know what you're getting into!
If you are located in the United States, I will be shipping all the cases out to someone in the US (probably mkawa) and then he will distribute them from within the US which will be much cheaper. You will then be charged the actual cost of shipping from within the US plus a fraction of the cost of me sending it to the US distributor. For example, if it costs me $100 to send out all the cases to the US distributor and there are 40 cases destined for the US you will pay $2.50 in addition to the local shipping cost.
If anybody is interested in being a distributor for another country to try and save money please talk about it amongst yourselves and let me know.
Ordering
If you want to order, please PM me with the following (address format for US residents, but please use an appropriate format for your country):
Geekhack account name
1x Aluminum case
John Smith
123 Fake Street
City, State 12345
Country
If you accidentally forget to include the "1x Aluminum case" I will assume that you only want one. That line is mostly for people who would want more than one.
You can then send money using Paypal to stephenpoconnor@gmail.com as a payment of goods. You will have to add the 2.9% + $0.30 Paypal fee for a total of $82.62 USD. Please include the same information in the Paypal note as you did in the PM.
(two cases would be $164.94, three cases would be $247.26)
I'll keep this open till about March 29th.
Order List
Total orders = 26 (+1 for myself and +1 for a local friend if I can find him a Poker to use it with. edit: found one for him!)
United States (17)
Autolyze - 1 - paid
Blackhawk19 - 1 - paid
boost - 1 - paid
Changdrew - 1 - paid
dippingriz - 3 - paid
ekw808 - 1 - paid
emptythecache - 1 - paid
Gawkbasher - 1 - paid
kisakuku - 2 - paid
metafour - 1 - paid
mkawa - 2 - paid
WRXChris - 1 - paid
zzspectrez - 1 - paid
Canada (2)
Elrobo - 1 - paid
elton5354 - 1 - paid
United Kingdom (1)
J-P - 1 - paid
Germany (1)
xauser - 1 - paid
Italy (1)
xbb - 1 - paid
Australia (3)
jinzo.pk3 - 1 - paid
jonnybastard - 1 - paid
KyesaRRi - 1 - paid
Thailand (1)
net2522 - 1 - paid
« Last Edit: Mon, 23 April 2012, 12:41:14 by oneproduct »
Poker | Filco Tenkeyless | Realforce Tenkeyless Variable Silent | Truly Ergonomic | Kinesis Contoured Advantage | IBM Model M SSK | Cherry G80-3600LYC | TG3 w/ trackpad
Kensington Slimblade | RollerMouse Free2 | Logitech M570 | Microsoft Trackball Explorer
Colemak
Offline Changdrew
« Reply #1 on: Fri, 16 March 2012, 16:46:37 »
Pm'd, but will not be able to pay for a few days :(
CM Quickfire Rapid | Filco Majestouch 2 | Filco Linear R | Poker
Offline oneproduct
« Reply #2 on: Fri, 16 March 2012, 17:15:30 »
Quote from: Changdrew;548126
That's fine. As long as you can pay sometime within about a week it's no problem.
Colemak
Offline metafour
« Reply #3 on: Fri, 16 March 2012, 17:17:13 »
If we buy two are they going to ship separately?
Offline morgofborg
« Reply #4 on: Fri, 16 March 2012, 17:26:28 »
Pm'ed and payment sent.
Online boost
  • != I.C.E
  • Global Moderator
  • NY Giants!!!
« Reply #5 on: Fri, 16 March 2012, 18:04:18 »
Where would one specify that he doesn't want it glued together because I will have the dip switch hole cut by a friend and Chrome dip it :D
Thanks
Sent from a phone...
A guy walked up and said: "You know washing your car doesn't make it faster, right?"
I popped the hood and replied: "Yeah... But that turbo does."
Offline lightsout714
« Reply #6 on: Fri, 16 March 2012, 18:23:59 »
Can you chrome aluminum?
Offline oneproduct
« Reply #7 on: Fri, 16 March 2012, 19:00:41 »
Quote from: metafour;548152
I'd probably ship them together, but if you want otherwise I could do so.
Quote from: boost;548189
Just mention it in the PM and I'll leave it as two separate pieces for you.
Colemak
Offline metafour
« Reply #8 on: Fri, 16 March 2012, 19:01:39 »
I'm just trying to estimate shipping costs.
Online emptythecache
  • lz fanboy
« Reply #9 on: Fri, 16 March 2012, 19:04:40 »
If we want these powdercoated when we get them, can you do that over the glass beading, or do we need to ask that it not be glass beaded?
Online boost
  • != I.C.E
  • Global Moderator
  • NY Giants!!!
« Reply #10 on: Fri, 16 March 2012, 19:11:18 »
Quote from: lightsout714;548206
I think so, if not ill have him powder coat it.
Also, when are you going to stop taking payment?
Offline Reptile
« Reply #11 on: Fri, 16 March 2012, 19:28:02 »
How much cleaner is the the final product going to be? Small touch ups from the prototype or a major difference?
Home:Realforce 87UB 55g
Work:Leopold FC700R Ergo Clears
Offline Elrobo
« Reply #12 on: Fri, 16 March 2012, 19:34:57 »
Will most likely PM in a day or two, any word on the insert being tacked down rather than glued (I know you mentioned the possibility, just wonder what will end up being "final spec"). Also will the insulating layer be attached to the plate or is it up to us to make sure it lines up/remove it on our own if we want to experiment or what?
Also anyone with a poker have the box handy for us trying to figure out shipping costs? I'm still waiting on mine but will probably be getting one of these to meet it here :)
Offline metafour
« Reply #13 on: Fri, 16 March 2012, 19:37:44 »
Poker box is 13" x 5" x 3.5" (length x depth x height)
Offline oneproduct
« Reply #14 on: Fri, 16 March 2012, 19:58:28 »
Quote from: emptythecache;548244
I have no idea, you'd have to ask whoever plans to organize the powercoating. Just remember that the surface will be scuffed from the work done during assembly, which was why I was getting it glass beaded in the first place. I'm not sure that powdercoating would hide the scuffing if that's something that bothers you.
Quote from: Reptile;548267
For the most part it will be the same. In terms of visual differences the USB cutout will be cleaner and the glass beaded surface won't have the minor scratches that the prototype got from additional adjustments that were made to it.
Quote from: Elrobo;548273
I'm going to try to push to get it tacked, because I like that a bit more. My point of contact was suggesting gluing but I think I might go against him there. Not that gluing is bad if it comes to it. It sounds unprofessional but this wouldn't be like simple glue that you use in preschool, there are sort of industrial strength bonding glues just for metal.
The insulating layer will be cut to have the holes that it needs for the screws and such to go from the pcb into the metal insert but wont me attached to the metal insert, you'll have to just line it up on your own as you screw the two together, which is a piece of cake.
« Last Edit: Fri, 16 March 2012, 20:08:00 by oneproduct »
Colemak
Online boost
  • != I.C.E
  • Global Moderator
  • NY Giants!!!
« Reply #15 on: Fri, 16 March 2012, 20:24:49 »
Last day taking payments?
Offline ekw808
  • I <3 KDM
  • Ewang
« Reply #16 on: Fri, 16 March 2012, 20:34:20 »
Any color options for the case?
[One Keyboard at a time]
  • #1 in da hood, G
« Reply #17 on: Fri, 16 March 2012, 20:41:45 »
nope.
but i think mkawa wants to provide a service to powdercoat the cases
and I'm the dirtiest thing in sight, matter of fact bring out the girls and let's have a mud fight.
  • lz fanboy
« Reply #18 on: Fri, 16 March 2012, 21:06:01 »
pm'd and paid. I hope mkawa shows up soon to talk about powdercoating. Want me some gunmetal.
« Reply #19 on: Fri, 16 March 2012, 21:21:19 »
Quote from: emptythecache;548352
He was here, I think he said he would talk to the company monday.
Offline oneproduct
« Reply #20 on: Fri, 16 March 2012, 22:32:10 »
Quote from: boost;548309
I usually visit every Friday in person so I'd like to be able to submit the order then, so looking to get payments by Thursday next week.
Colemak
Online jonnybastard
« Reply #21 on: Fri, 16 March 2012, 22:32:41 »
Order & payment sent, if anyone else in Australia is getting in on this send me a PM and we may be able to work out something with shipping.
HHKB Type-S    -    Filco Tenkeyless Linear R Limited    -    Poker X    -    KBT Race LE
flickr
Offline KyesaRRi
« Reply #22 on: Fri, 16 March 2012, 23:05:27 »
Payment sent, yay!
jonnybastard how low do you think we can get the Aus shipping down? Its only $44.00~ for the slowest shipping option. Ill send you a PM and wait to see if any other Aussies get in on this.
Noppoo Choc Mini MX
Ducky 1008 MX
KBC Poker MX
SteelSeries 7G MX
Offline ekw808
  • I <3 KDM
  • Ewang
« Reply #23 on: Fri, 16 March 2012, 23:09:55 »
ugh I dont even have a poker but I want this case..
Offline jellowiggler
« Reply #24 on: Fri, 16 March 2012, 23:45:41 »
If this was a cmstorm or filco I'd be sorely tempted.
Mike -jellowiggler-
Filco MJ2 Tenkeyless / Rosewill RK-9000 / IBM Model M 1391401 / Logitech DiNovo Edge / MS Sidewinder X4
Online zzspectrez
« Reply #25 on: Sat, 17 March 2012, 00:29:48 »
pm'd for one! Will send payment early next week
Offline mkawa
  • ssk.ℜ
  • Administrator
  • Klaxon Theorist
« Reply #26 on: Sat, 17 March 2012, 01:34:42 »
i can't talk to the company until tuesday at the earliest; i most likely won't have final shipping quotes, color options etc. until end of next week at the earliest
Offline ekw808
  • I <3 KDM
  • Ewang
« Reply #27 on: Sat, 17 March 2012, 08:45:36 »
So if it is purchased and a powder coating is used, would the ones that are coated all be sent to mkawa instead of the buyers, and once coated it would then be mailed out to the customers from mkawa?
« Reply #28 on: Sat, 17 March 2012, 10:10:41 »
Quote from: ekw808;548756
I'm pretty sure all US orders are going to mkawa.
Online boost
  • != I.C.E
  • Global Moderator
  • NY Giants!!!
« Reply #29 on: Sat, 17 March 2012, 10:13:23 »
Quote from: oneproduct;548446
Do this gb need 50pcs inorder to get them for $65?
