Author Topic: SHARP X68000 keyboard converter  (Read 30866 times)
Offline hasu
  • @tmk
« on: Sat, 24 March 2012, 05:17:29 »
SHARP X68000 is a hobby computer released in Japan.(1987-93)
http://en.wikipedia.org/wiki/Sharp_X68000
X68000 keyboard
X68000 keyboard has basically ALPS linear switches, for example:
- DSETK0016CE01   (ALPS green linear switch)
- DSETK0022CE02   (ALPS yellow linear switch)
- DSETK0023CE03   (ALPS yellow linear switch)
 I have a DSETK0016CE01 with green one.
Album: http://imgur.com/a/N1yMX
Update
- 2013/06/22  Add LED support
- 2017/05/09  Online Keymap Editor is available for TMK x68k converter now
Hardware
Target MCU is ATMega32u4/u2 but other USB capable AVR also should work.
You can use a PJRC Teensy2.0 for this converter.
Connector
X68000 keyboard has a Mini DIN 7pin connector.
keyboard plug:
converter jack:
Wiring
Code: [Select]
    Mini-DIN            Teensy
    pin1   +5V          VCC
    pin2   MOUSE        -
    pin3   RXD          PD2(RXD)
    pin4   TXD          PD3(TXD)
    pin5   READY        -
    pin6   REMOTE       -
    pin7   GND          GND
Firmware
Source: https://github.com/tmk/tmk_keyboard
Build
Code: [Select]
    $ git clone git://github.com/tmk/tmk_keyboard.git
    $ cd tmk_keyboard/converter/x68k_usb
    $ make
Keymap Editor
You can download firmware binary from online editor without building source code yourself.
http://www.tmk-kbd.com/tmk_keyboard/editor/unimap/?x68k_usb
Program
With TMK x68k converter press the button on PCB to start programming mode, then use flash tool with firmware binary. See wiki page.
https://github.com/tmk/tmk_keyboard/wiki#flash-firmware
If you use Teensy you can load with PJRC Teensy Loader tool.
    http://www.pjrc.com/teensy/loader.html
X68000 Keyboard Protocol
See README.
https://github.com/tmk/tmk_keyboard/tree/master/converter/x68k_usb
You can buy preassembled TMK x68k converter here
« Last Edit: Mon, 08 May 2017, 20:11:00 by hasu »
Offline hasu
  • @tmk
Re: SHARP X68000 keyboard converter
« Reply #1 on: Sat, 22 June 2013, 03:05:43 »
Finally added LED support.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #2 on: Thu, 28 April 2016, 11:24:16 »
Is there a way to turn on all of the LEDs using a single key? I tried looking at the code but I'm not very well versed in it. I think it would be cool to be able to press a key (break for example) and have the LEDs all turn on or off. I also tried using the scancode trick but none of them are high enough to trigger all of the LEDs.
Offline hasu
  • @tmk
« Reply #3 on: Fri, 29 April 2016, 01:50:22 »
I added sample code in keymap.c, see the latest code on github repository. I converted x68k keymap from legacy format to current one and added an action_function to toggle LEDs.
https://github.com/tmk/tmk_keyboard/blob/3c109203c3d0451dd5009acbe3fc5452934b0449/converter/x68k_usb/keymap.c#L75-L92
You can toogle all LEDs with 'BREAK' key now.
To control seven LEDs just send 1-byte command like below. For example to turn only CAPS on you can send 0b11110111 and to turn INS and CAPS on send 0b11100111. Use 'serial_send()' to send the command.
- LED control ON/OFF(0/1)
    bit 7   1(fixed)
    bit 6   全角
    bit 5   ひらがな
    bit 4   INS
    bit 3   CAPS
    bit 2   コード入力
    bit 1   ローマ字
    bit 0   かな
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #4 on: Fri, 29 April 2016, 07:38:06 »
That's amazing Hasu! Thanks for that. I'll rebuild my converter later today when I get time.
Offline alh84001
« Reply #5 on: Thu, 05 January 2017, 18:27:11 »
I just wired up a Pro Micro with a 7-pin mini-DIN port (I connected 5V, GND, RX and TX), and flashed the firmware which I got by issuing make in a pristine repo. Switches get registered with no issues, but I'm having trouble with LEDs. Only CAPS LED is working when the key is pressed (which i think is expected), and pressing BREAK does nothing (no LEDs light-up, including CAPS), which, looking at code, should work.
Offline hasu
  • @tmk
« Reply #6 on: Thu, 05 January 2017, 19:22:44 »
glad you made your converter work.
Converter doesn't handle all LEDs at this time because I have no idea on how to use other LEDs. But I think you can control all LEDs as you want, see source code.
Do you have X68000 computer or know how it handles LEDs on those keys?
Offline alh84001
« Reply #7 on: Fri, 06 January 2017, 05:35:53 »
It turns out that I was stupid and I had a fork of the tmk cloned, which has not been rebased in quite a while, so I didn't have any of the changes related to LEDs. I cloned the original repo, built it, flashed it, and now all LEDs work when pressing BREAK key.
Thanks again, hasu, you're the man!
Offline hasu
  • @tmk
« Reply #8 on: Mon, 08 May 2017, 20:08:23 »
Now Keymap Editor is available for TMK x68k converter(ATMega32u2).
Offline BeautyFool
« Reply #9 on: Sat, 27 January 2018, 05:44:41 »
Awesome job! I have a question: with this converter, can be emulated the led patterns used by some games? (Like Cotton  https://youtu.be/lYhGQzCtSHk;)
Offline hasu
  • @tmk
« Reply #10 on: Sat, 27 January 2018, 19:33:29 »
you can control the LEDs by very simple one byte command, it won't be difficult at all.
Offline michaelbeaver1
« Reply #11 on: Wed, 24 July 2019, 04:41:49 »
Can you please tell me where I can find more about the commands I can use? Thanks!
Mod Edit: Removed spam link, banned account - post left for posterity and below response
« Last Edit: Wed, 27 November 2019, 11:30:00 by HoffmanMyster »
Offline hasu
  • @tmk
« Reply #12 on: Wed, 24 July 2019, 06:20:16 »
You can just send a byte to control LEDs on keyboard.
https://github.com/tmk/tmk_keyboard/blob/3ee5f565ae98cc68b6dff24225b6f8f069f6e20d/converter/x68k_usb/README#L86-L94
Code: [Select]
    bit 7   1(fixed)
    bit 6   全角
    bit 5   ひらがな
    bit 4   INS
    bit 3   CAPS
    bit 2   コード入力
    bit 1   ローマ字
    bit 0   かな
Also refer to this code about how to send the command. By default, the converter uses 'コード入力' LED as numlock indicator and 'CAPS' LED as capslock indicator, for example.
https://github.com/tmk/tmk_keyboard/blob/3ee5f565ae98cc68b6dff24225b6f8f069f6e20d/converter/x68k_usb/led.c#L24-L43
Code: [Select]
void led_set(uint8_t usb_led)
    /* X68000 LED bits 0: on, 1: off
     * bit 7   1(fixed)
     * bit 6   全角
     * bit 5   ひらがな
     * bit 4   INS
     * bit 3   CAPS
     * bit 2   コード入力
     * bit 1   ローマ字
     * bit 0   かな
    uint8_t led = 0xFF;
    if (usb_led&(1<<USB_LED_NUM_LOCK))      led &= ~(1<<2);
    if (usb_led&(1<<USB_LED_CAPS_LOCK))     led &= ~(1<<3);
    if (usb_led&(1<<USB_LED_SCROLL_LOCK))   led &= ~(1<<1);
    if (usb_led&(1<<USB_LED_COMPOSE))       led &= ~(1<<4);
    if (usb_led&(1<<USB_LED_KANA))          led &= ~(1<<0);
    serial_send(led);
Mod Edit: See above; removed spam link in quoted post
« Last Edit: Wed, 27 November 2019, 11:30:38 by HoffmanMyster »
Offline HerbalNekoTea
« Reply #13 on: Sat, 03 August 2019, 14:01:54 »
Hi, do those work with Sharp X1 keyboard or just X68000 ? Thank you.
Offline hasu
  • @tmk
« Reply #14 on: Sun, 04 August 2019, 19:03:24 »
I cannot say anything because I don't know about X1 keyboard.
Post pics of connector and internals of you keyboard.
« Reply #15 on: Sun, 04 August 2019, 20:52:34 »
Thank, will do that next month when it get here.
