Author Topic: Unicomp Classic or Leopold FC500R Cherry Blue  (Read 930 times)
Offline snupple
« on: Wed, 11 April 2012, 02:51:26 »
Gday,   I want two mechanical keyboards, so that I have the same keyboard at work and at home.
  Narrowed it down to the Unicomp Classic or the Leopold FC500R.
 I prefer the Unicomp as its bigger and heavier,  but I am concerned about the noise it may make,   I'd hate to get two and be told at work that the keyboard is too loud and take it home!
 Any comments would be useful
Offline Solanin
« Reply #1 on: Wed, 11 April 2012, 03:26:09 »
Just get a Leopold FC500 brown or red
Offline Keyboarder
« Reply #2 on: Wed, 11 April 2012, 03:29:09 »
If you have the money why not try topre?
Offline Zamorph
« Reply #3 on: Wed, 11 April 2012, 10:47:19 »
I have not tried the unicomp classic, but Leopold boards are really nice :) and blues are my favorite switch.  Blues are loud as well... so just keep that in mind.  But, it depends on your work place, if the people you work with are cool I wouldn't worry about it.  All mechanical keyboards make a sound that is louder than the standard rubber dome... if you are really worried about sound people put up sound samples of keyboards here.
Offline mich
« Reply #4 on: Wed, 11 April 2012, 13:16:25 »
A friend of mine has a Das with blue cherries. It's sound might be a bit quieter, but is higher-pitched and IMO less pleasant :)
Online iBro
« Reply #5 on: Thu, 12 April 2012, 00:55:06 »
If you are working in close proximity to other people. Then it's almost certain that buckling springs and blues will be out of the question.
Unicomp Space Saver (buckling spring) Silicon Graphics (dampened cream alps) KBC Poker (ghetto reds)
fossala
  • Guest
« Reply #6 on: Thu, 12 April 2012, 02:10:01 »
You could probly pick up a cheapish model M for under $50. Test the water with that if it is too loud when you bring another board in they will think it is an alright comprimise.
Offline ch_123
« Reply #7 on: Thu, 12 April 2012, 06:53:05 »
Quote from: fossala;573565
Of course, older ones are likely to be somewhat louder, due to rivets, and general wear from age.
Online fohat.digs
  • you know what they say about opinions
« Reply #8 on: Thu, 12 April 2012, 09:18:16 »
A rubber pad under the buckling spring keyboard, along with the floss mod, really cuts down on the sound volume, and takes it to a lower register.
The blues may or may not be as "loud" in the absolute decibel sense, but the sharper, higher-pitched sound is almost always considered more "annoying"
Pads or o-rings reduce the sound ever so slightly, but don't expect much relief that way.
I remember, back in the old days ....
Offline sth
  • 2 girls 1 cuprubber
  • don't hate me cause i'm beautiful
    • User:Sth
« Reply #9 on: Thu, 12 April 2012, 12:12:30 »
If you want a clicky tactile keyboard just get the Unicomp.
If you want a clicky tactile keyboard that is relatively easy to customize (read: keycaps) get a Leopold.
Offline keyboardlover
« Reply #10 on: Thu, 12 April 2012, 12:51:44 »
@OP:
If you're planning to use the same keyboard at work, I'd recommend the Leopold. The Unicomp is quite a bit louder.
And welcome to Geekhack!
Online iBro
« Reply #11 on: Thu, 12 April 2012, 13:43:13 »
Quote from: sth;573828
I would actually say that the Unicomp is probably easier (and cheaper) to customize than the Leopold. The new Unicomp website makes it really easy to order an assortment of keys.
Offline urbanus
« Reply #12 on: Sat, 14 April 2012, 00:09:54 »
Quote from: snupple;572793
Both fine keyboards, but with the FC500R you get four choices of switch (blue, brown, black and red) and none of those is like buckling spring.  Not even MX blue: even though it's tactile & clicky -- and so is buckling spring -- the key weight and general feel are very different.  Some people love blues to death; others love buckling spring and hate cherries.
So you're asking about two very different alternatives, and asking us to tell you which you would prefer.  Given that it's such a personal thing I think there are limits to the quality of advice we can give, but here goes...
If you like a keyboard with a very firm, tactile feeling, go for the Unicomp first.  You may love it or hate it, but it's not expensive and at least you've experienced the awesome phenomenon that is buckling spring.
If you prefer a keyboard with a medium to light feel, consider the Leopold with blues or browns.  Lots of people say they like browns best.  Reds are good too: superb for gaming, and very comfortable for typing if you like a light feel and you've got the patience to get used to them (touch typing on reds accurately isn't easy).
The noise issue will be just as bad with MX blue, perhaps worse.  It makes a higher pitched, crispier clicking noise which some people find more irritating than buckling spring.
Online wcass
« Reply #13 on: Sun, 15 April 2012, 21:57:19 »
i'm in a cube farm. my neighbors noticed the sound of buckling springs at first, but after about a week, they completely tuned it out.
Offline Tony
« Reply #14 on: Sun, 15 April 2012, 22:34:13 »
You will get both keyboards in the future, so don't worry about the choice of the first keyboard. You will buy the other in no time anyway.
Keyboard: Filco MJ1 104 brown, Filco MJ2 87 brown, Compaq MX11800, Noppoo Choc Brown, Noppoo Choc Blue, Noppoo Choc Red, IBM Model M 1996, CMStorm Quickfire Rapid Black
Offline HolidaySHRIMP
  • Oh it's holiday season SHRIMPS!
« Reply #15 on: Mon, 16 April 2012, 05:53:53 »
Quote from: Tony;575821
This. LOL
3 months looking at third already -__-
Sent from my Galaxy Nexus using Tapatalk 2
