Author Topic: [FS]Viki Bundle, GTX 970, Vintage  (Read 63366 times)
Offline ebacho
  • Trade Count: (0)
« on: Thu, 12 April 2012, 20:42:22 »
All prices DO NOT include shipping or PP fees.  Please contact me and I will quote you the total price.  If you feel my pricing is too high, I will consider all reasonable offers.  Lowballers will just be ignored now due to prior experience.  Preference given to CONUS buyers, please contact me if international.  Unless otherwise specified capsets on most boards are for display only and are not included.
WTB/Trade for:
What I have for trade:
WTS: Keyboards:
Viki Custom + Matching PS/2 Cable - $210 $190
Built with 67g MX Greens, tactile MX Gray on the spacebar.  Sandwich style case using ps2avr PCB.  Custom USB to PS/2 cable included.
NEC Blue Ovals board - APC - $5
Pretty beat up.  Missing some stabs, rust on plate, but the switch is quite unique.  I've already cleaned it a fair amount, but it's not the prettiest board regardless.  Clicky NEC blue ovals, one with broken stem (see pictures).  Tested working using a soarers.  Best used as a part donor.
Generic Vintage Alps Board - $5
Simplified clicky white alps.  If you really want a serial/fcc number I'll tear it down, but its pretty standard as far as these kinds of boards go.  Switch feel is ok but the build quality is questionable at best.  Good as a parts donor.  AT Plug, tested working using a soarer's.
USIT branded Fujitsu Peerless - $5
Fujitsu Peerless switches.  AT plug, tested with Soarer converter.
Edimax KB-5538 - $5
Spring over membrane.  Fairly clicky regardless.  Case is fairly high quality (better than my Model M, I'd say).
Includes original box, inserts, and plastic cover.  AT/XT switchable and tested working via Soarer.
Keycaps/Keysets:
Misc:
EVGA GTX 970 ACX 2.0 - $145
Bought off of EVGA's B-stock site.  Used lightly for about a year.  Never overclocked, very good condition.
Bag of Matias Tactile Alps - $10
Don't even know how many are in here, but probably 80 work.  Mix of new/desoldered alps from my various projects that I've long abandoned.
Verification:
Sold:
Depth Black CC - $275
P1 Purple CC - $225
Self explanatory.
Leading Edge DC-2014 - $130
Blue Alps, clicky.  You probably know what this is if you're considering it.  Very good condition, full texture on all the caps, clean plate.  This is untested but I have no reason to believe it doesn't work.
BSP 102 Thick PBT Keyset - $130
Includes PBT spacebar.  Lightly used with no visible shine with exception of spacebar, which I would conservatively rate as 8/10 (light scuff marks).
Note: This is for Winkeyless boards only, with 1.5x modifiers and a 7x spacebar. If you have questions about whether or not this will work with your board feel free to PM.
B/R/B Cheat - $425 SOLD
60g lubed reds, stickered, etc.  Sleeved USB cable.  Small nick in the upper right hand corner, but very good cosmetic condition otherwise.
Caps not included.
DSA Dolch - $90 $80 SOLD
Got this from SP a while back after getting burned in the original LZ buy.  I think I have the base 87, tsangan, and 16x windowed caps, but check the pictures for what's there.  Box not included.  Pretty much brand new, used once and put back in box.
PBT DSA Blanks -$30 PENDING SOLD
I have no idea where I got these.  I'm pretty sure they're PBT because the upper left magenta caps are dyed, probably with Rit.
There are 42 1x caps in the upper left hand pile; for the rest, what you see is what you get.
Spacebar is 6.25x
Siig Suntouch Jr with Box - $50
Box has water damage, but the keyboard looks and feels brand new.  Funky layout, doubleshot keys.  Complicated white alps.
PULSE SA - $100
SP SA profile - again, what you see is what you get.  Used for about a month, then put the board back into storage, so it's in pretty good condition.
Board not included.
ANSI Blue Realforce Set - $110
Self-explanatory.  Pretty much unused, was put on a HHKB for a week and then thrown back in a box.  Display case not included, don't have the original box since it was proxied for me by a friend.
Alps Infinity - $140 $130
Long story short, this board has caused me more trouble than it's worth and I really hate looking at it.  It actually functions and feels pretty good.  You can probably guess what the story is based on some of the other stuff I'm selling.
Uses Matias quiet click switches, pbt DSA caps.
Missing one cap cause Massdrop swapped one of the DSA caps for a MX one for who knows why.  Didn't completely finish this build till about a week ago so I doubt I can get any sort of coverage for it.
Package includes: Assembled board, caps, 2nd broken PCB (usb port not soldered down correctly, you might be able to fix it if you're good at smd soldering).
Hyperfuse DCS - $165 $155
SP DCS profile - what you see is what you get.  Mint condition, I'm the second owner iirc but haven't really used it since I got it.  Has full texture and so on.
Board not included.
Duck Eagle - $390 $365
65g springs, mx clears, red switch stickers.  Mx gray on the spacebar. Krytox GPL 103/205 mix on the sliders/stabs.  Stabs are also clipped. No leds except for the side ones, which are red.
Bottom row is 1.5 1x 1.5x 7x 1.5x 1x 1.5x, with short right shift (1.75x - 1x).
Only board is included, no caps, cables, etc.
Desko Keyboard + PCB Combo - $50$45 $40 $35
MX Blacks all around.  Doesn't feel too used but was pretty grungy when I got it. There was some discussion of this PCB from Ivan's GMK buy being pin compatible with this model of Desko board but I never got around to swapping them.  PCB has no controller, just header pins.  Connector is PS/2
~100 Gateron Blacks - $18
Self explanatory.  From original Shadovved GB. 1 pack sold, one left.
Red Scarf 84 - $190
Purchased from the original Ivan GB.  Built with Gateron Whites.  Short bezel version.  Feet came with screws that didn't fit the holes in the bottom of the casing so I have the feet stuck on with double sided tape.  It's stuck on pretty well so it should be fine unless you're planning to use this as a travel board.
See this thread for more details https://geekhack.org/index.php?topic=69064.0
LZ-FE - $750
Built with 65g MX Clears lubed with 103/205 Krytox mix.  Switch feel is very slightly stiffer than ergo clears. Tactile MX Gray on the spacebar.  Clipped stabs, yellow switch stickers.  Immaculate condition, no scratches, dings, etc.
NCR Cherry G80-0427 - $45
Fun board, only for collectors probably - layout is just impractical for everyday use.  XT connector and tested working over a Soarer.  All LEDs work and the switches feel great.  Vintage MX Blacks.  Overall good condition, with some shine on the alphas.
« Last Edit: Sun, 06 November 2016, 01:16:47 by ebacho »
Offline VesperSAINT
  • vpsert
  • Trade Count: (0)
  • #CustomKorean
Potluck of old keyboards
« Reply #1 on: Thu, 12 April 2012, 20:54:05 »
What are the keycap types on (3)? Majority of the keycaps look perfect for my Steelseries 7G and I'd like to have some backup keycaps. Especially that fat-ass enter and the smaller backspace key and the \| keys.
Offline Dox
  • Trade Count: (0)
« Reply #2 on: Thu, 12 April 2012, 20:54:49 »
PM'd for the Apple M0116!
ErgoDox x2 | DoxKB x2 |   IBM SSK   | HHKB pro2
Offline reaper
  • Trade Count: (0)
« Reply #3 on: Thu, 12 April 2012, 20:56:48 »
Some good prices there.  Good luck with sale. =)
« Last Edit: Thu, 12 April 2012, 21:05:43 by reaper »
Din Eli
Offline technicallyrite
  • Trade Count: (0)
« Reply #4 on: Thu, 12 April 2012, 21:06:04 »
I'll take #3 if they're available.
What\'s your type?
  • Trade Count: (1)
« Reply #5 on: Thu, 12 April 2012, 21:09:51 »
I'll take #1 and #4.
  • Trade Count: (1)
« Reply #6 on: Thu, 12 April 2012, 21:54:28 »
My soldering iron is warming up now... :smile:
Offline ebacho
  • Trade Count: (0)
« Reply #7 on: Fri, 20 April 2012, 00:45:45 »
Weekly bump.
Offline ebacho
  • Trade Count: (0)
« Reply #8 on: Sun, 03 June 2012, 19:11:14 »
Bump for more stuff.
Offline ebacho
  • Trade Count: (0)
Re: FS: Potluck of old keyboards
« Reply #9 on: Sat, 29 September 2012, 18:23:39 »
And bump for a bunch of new stuff.
I haven't been on GH in a few months and it's changed quite a bit - is this thread still ok even if I have less than the required 60 posts?
Offline MissMurd3r84
  • Trade Count: (0)
  • In IRC wondering why Kmiller8 is yelling.
« Reply #10 on: Wed, 10 October 2012, 05:34:09 »
The TG3 BL82 looks cool, sadly I am guessing it would cost an arm and a leg to send to Australia.
KBC Poker - Red switches. Noppoo Choc Mini - Black switches. Leopold FC700R (White) - Blue switches. Ducky YOTD - Brown switches. Razer BW - Blue switches and rusted.
Offline ebacho
  • Trade Count: (0)
Re: FS: Potluck of old keyboards (Added some caps)
« Reply #11 on: Sat, 10 November 2012, 21:39:03 »
Added caps, dropped prices across the board (no pun intended, hurr).
Offline reaper
  • Trade Count: (0)
« Reply #12 on: Sat, 10 November 2012, 21:46:43 »
lol  Everytime I refresh, price of the first one keeps going up.
« Last Edit: Sun, 11 November 2012, 10:04:59 by reaper »
Din Eli
Offline nntnam
  • Trade Count: (0)
« Reply #13 on: Sat, 10 November 2012, 21:47:48 »
^ LOL, I see that too. I was about to send him a pm on that set =))
░▒▓ KMAC | FILCO MJ2 | HHKB | PHANTOM ▓▒░
Offline ebacho
  • Trade Count: (0)
« Reply #14 on: Sat, 10 November 2012, 21:49:06 »
You caught me, lol.  I saw an auction going on for an R3 Set that's in the $100 range so I didn't want to undercut myself.
I guess I'll sell it for the $35 price, whoever pm's me first gets it.
Offline The_Beast
  • Trade Count: (0)
  • I like wood ಠ_๏
« Reply #15 on: Sat, 10 November 2012, 21:49:42 »
First set = SP Round 3? Is it a full set?
Also, I thought it was 60 posts before posting in the classifieds?
Offline reaper
  • Trade Count: (0)
« Reply #16 on: Sat, 10 November 2012, 21:50:45 »
I pm'd you but don't know if i was first. lol
Din Eli
Offline ebacho
  • Trade Count: (0)
« Reply #17 on: Sat, 10 November 2012, 21:52:43 »
I've had this thread up before the postcount restrictions, hence I just keep editing this one whenever I want to sell something xD
Also, reaper was first, sorry!
Offline reaper
  • Trade Count: (0)
« Reply #18 on: Sat, 10 November 2012, 21:54:11 »
Cool!  First time for me. lol  :)
Din Eli
Offline The_Beast
  • Trade Count: (0)
  • I like wood ಠ_๏
« Reply #19 on: Sat, 10 November 2012, 21:54:53 »
I was just wonderin'
Np about reaper ^___^
Offline tiarnachutch
  • Trade Count: (0)
« Reply #20 on: Sat, 10 November 2012, 22:03:39 »
Do you still have the kb-7001?
Home: IBM Model M (1991)
Work: WASD with Cherry MX Blues, Microsoft Ergonomic 4000, Goldtouch v1
Offline ebacho
  • Trade Count: (0)
« Reply #21 on: Sat, 10 November 2012, 22:05:20 »
Yep, still available.  Everything in the post is up to date as far as availability goes.
Offline Leewei
  • Trade Count: (0)
« Reply #22 on: Sat, 10 November 2012, 22:50:31 »
hihi. how are the keycap conditions? do they have shine? for #1,2,7
Filco Majestouch 2 Beige TKL with MX Reds
Qsenn dt-35
Offline TheQsanity
  • Trade Count: (0)
  • SmallFry Lovin'
« Reply #23 on: Sat, 10 November 2012, 23:40:13 »
Wow some nice looking stuff.
SmallFry! <3
Offline Wildcard
  • Trade Count: (0)
  • When caffeine isn't enough
« Reply #24 on: Sun, 11 November 2012, 00:03:28 »
PM sent on b).
« Last Edit: Sun, 11 November 2012, 00:07:39 by RiffRaff »
Offline ebacho
  • Trade Count: (0)
« Reply #25 on: Sun, 11 November 2012, 00:38:22 »
#1 and 2 are in very good condition - the keys still have the texture, so there's little shine (if at all).
As for the offers on the keys, I'll sit on them and think for a few days; thanks guys.
Offline ebacho
  • Trade Count: (0)
« Reply #26 on: Wed, 21 November 2012, 21:11:33 »
OP updated to reflect recent sales.
If I sold you something, can you confirm that you got what I sent just for my peace of mind?  Thanks all.
Offline sth
  • 2 girls 1 cuprubber
  • Trade Count: (0)
« Reply #27 on: Wed, 21 November 2012, 21:16:14 »
what do you think of the switches on the scorpius boards? i am tempted to harvest them.
Offline ebacho
  • Trade Count: (0)
« Reply #28 on: Wed, 21 November 2012, 21:26:32 »
They feel alright, nice and clicky but from what I've read they're rather fragile.  If you want them, I'm pretty much willing to let them go for shipping at this point.
Offline sth
  • Trade Count: (0)
« Reply #29 on: Wed, 21 November 2012, 21:28:10 »
okay, YGPM :) i would prefer just one but if you have to get rid of both of them together I'll take both.
Offline ebacho
  • Trade Count: (0)
Re: ebacho's FS/FT/WTB thread
« Reply #30 on: Sun, 05 May 2013, 20:46:32 »
Not quite yearly bump!
Revamped thread with new stuff.
Offline The_Beast
  • Trade Count: (0)
  • I like wood ಠ_๏
« Reply #31 on: Sun, 05 May 2013, 20:48:07 »
What is the "5k177" cap?
Offline ebacho
  • Trade Count: (0)
« Reply #32 on: Sun, 05 May 2013, 20:50:34 »
I got it from didjamatic's old site, 5k177.com
Edit:Site now defunct.
« Last Edit: Sun, 05 May 2013, 23:03:44 by ebacho »
Offline ebacho
  • Trade Count: (0)
« Reply #33 on: Mon, 06 May 2013, 23:00:09 »
Bump.  Added G81-1800 case and put prices on the IC'd items.
Offline ebacho
  • Trade Count: (0)
« Reply #34 on: Fri, 10 May 2013, 20:27:00 »
Bump.
Edited first post to reflect sales.
Offline missalaire
  • Great Finder of Great Finds
  • Trade Count: (0)
« Reply #35 on: Sun, 12 May 2013, 21:25:07 »
Is the Leopold with MX Clears the FC200R model? And how old/used is it?
Offline VesperSAINT
  • vpsert
  • Trade Count: (0)
  • #CustomKorean
« Reply #36 on: Sun, 12 May 2013, 21:35:01 »
Hmmm those Siig Minitouch (Montereys) is tempting but I'm sure someone will grab it before I can decide anyway :) GLWS
Offline ebacho
  • Trade Count: (0)
« Reply #37 on: Sun, 12 May 2013, 21:42:49 »
Yes, it's the FC200R model.  About 6 months old, ~20 hours of use max.
Yep, Montereys are sold already, just neglected to update first post.  Thanks for interest!
Offline missalaire
  • Trade Count: (0)
« Reply #38 on: Sun, 12 May 2013, 21:51:46 »
Is that the one with the universal space bar?
Offline ebacho
  • Trade Count: (0)
« Reply #39 on: Sun, 12 May 2013, 21:54:32 »
Don't think so, it's the one with the weird space bar spacing for the stabilizers.
  • Trade Count: (1)
« Reply #40 on: Sun, 12 May 2013, 22:30:31 »
missalaire, you can use SP's universal 6-stem spacebar with the Leopold FC200R, but not the FC500R nor the FC700R.
Hope this helps, and GLWS, ebacho.
Also, ebacho, I got the GH SS and 1800 case in the mail the other day. Thanks for a successful sale!
Offline VesperSAINT
  • vpsert
  • Trade Count: (0)
  • #CustomKorean
« Reply #41 on: Mon, 13 May 2013, 18:01:19 »
jdcarpe - 옥 잉어.... LOL! Being Korean, I get it :)) :)) :))
« Last Edit: Mon, 13 May 2013, 18:05:08 by VesperSAINT »
Offline durandalx
  • Trade Count: (0)
« Reply #42 on: Mon, 13 May 2013, 21:17:26 »
Payment sent for the leopold!
  • Trade Count: (1)
« Reply #43 on: Mon, 13 May 2013, 21:20:17 »
Hehe, I'm glad someone picked up on it. :)
Offline esoomenona
  • Gnillort?
  • Trade Count: (0)
« Reply #44 on: Tue, 14 May 2013, 08:57:17 »
I did as well, and sort of copied you...  :-[
Offline VesperSAINT
  • vpsert
  • Trade Count: (0)
  • #CustomKorean
« Reply #45 on: Tue, 14 May 2013, 13:57:27 »
LOL! He moved it into his signature with a bigger font!
Is that what "esoomenona" means???
Offline ebacho
  • Trade Count: (0)
« Reply #46 on: Thu, 23 May 2013, 12:53:03 »
Bump, added NMB board.
Offline ebacho
  • Trade Count: (0)
« Reply #47 on: Fri, 19 July 2013, 02:45:37 »
Barump.  My imagehost is acting up, so if you have particular questions about an item feel free to ask.
Offline ebacho
  • Trade Count: (0)
« Reply #48 on: Tue, 22 October 2013, 01:55:53 »
Added a bunch of stuff for trade, prices lowered across the board.
Offline berserkfan
  • Trade Count: (0)
« Reply #49 on: Tue, 22 October 2013, 03:37:49 »
just a word of support for ebacho
I've bought from him before and he's a real gentleman. And the prices are really, really good!  :cool:
