Author Topic: Golden/metallic keycaps?  (Read 1296 times)
Offline pannkakan
« on: Tue, 24 April 2012, 04:16:25 »
Hello!
Does anyone know where I could buy golden or metallic keycaps? Would be cool to have a metallic esc-key ;)
Offline silat
« Reply #2 on: Tue, 24 April 2012, 04:20:10 »
Feng sells zinc caps. Gold and Silver
Fighting the Christian American Taliban daily with my Deck Legend loaded with Cherry MX Clears //
Deck Legend Ice Clears // Deck Legend Frost Clears // Ducky Shining Purple Browns//QPAD MK85 Browns //
Offline radicalrev
« Reply #3 on: Tue, 24 April 2012, 06:49:18 »
I am actually thinking of buying from Feng as well.
Would the gold/silver coating ever peel off?
I wanted the shiny ones, but sadly has print on it. :(
Offline Djuzuh
« Reply #4 on: Tue, 24 April 2012, 06:50:14 »
Ask on the order thread :P
Offline stuffstuff
« Reply #5 on: Tue, 24 April 2012, 14:01:08 »
The gold and silver won't peel off, its not a sticker, its real gold electroplated on .  The printing, however, is.  But that's not a problem.  The key looks great.
Offline Djuzuh
« Reply #6 on: Tue, 24 April 2012, 14:11:50 »
http://geekhack.org/showthread.php?28652-Order-Thread-Metal-%28Zinc%29-Keycas-Group-Buy-Round-2-!!-Starcraft-kit-Arrow-kit-etc
Congratulation ripster, that's 2$50 less than if you went threw the group buy !
Also, the seller is actually feng x)
Offline pannkakan
« Reply #7 on: Tue, 24 April 2012, 15:24:45 »
Thank you everyone! Just ordered from Feng =)
Although I haven't bought my filco keyboard yet.. still deciding if I should go with our without tenkeyless >.<
Offline Djuzuh
« Reply #8 on: Tue, 24 April 2012, 15:35:28 »
If you don't know, you usually don't need the tenkey on a regular basis. And you can still order a separate numpad for 10 bucks later on.
Offline dmbr
« Reply #9 on: Sat, 12 May 2012, 00:15:29 »
The ones I bought off eBay had the gold wear off almost immediately. Watch out.
Offline pannkakan
« Reply #10 on: Mon, 21 May 2012, 08:40:44 »
ohh.. thanks =)
Just got my button but waiting for my filco TKL :(
Will get it in a day or so I hope..
Offline dmbr
« Reply #11 on: Fri, 25 May 2012, 17:23:17 »
I bought some gold plated zinc keycaps on eBay. Coating started to come off in a matter of days :(
Online dorkvader
  • Love that PBT
« Reply #12 on: Fri, 25 May 2012, 22:25:22 »
Quote from: dmbr;600192
It's electroplated, and likely only a few microns thick. It depends on the metal and your body chemistry, but I believe it. That's why I'd go with silver: If it's not plated, when it wears, it'll still look good.
My room-mate decided to cancel the internet without telling me.
Limited internet :(
