Author Topic: KMAC DIY Thread  (Read 8683 times)
Offline litster
  • rare caps?! THAT'S A SMILIN
KMAC DIY Thread
« on: Sun, 29 April 2012, 02:07:09 »
People are receiving KMAC DIY kits.  I think a thread to collect all the info, tips, and tricks would be help to all KMAC DIY folks.  I will start with a few pictures of the PCB.
Top:
2368-0
Bottom:
2370-1
Parts:
- - Cherry MX switches, plate-mount or PCB-mount
diodes:
SMD:
http://www.mouser.com/ProductDetail/Fairchild-Semiconductor/MMSD4148/?qs=GXJjH%252bIVz3O2ghAmZxStYXW3%2fiTmBAG2
Digikey has MMSD4148 and many variants.  They should also work but I have not tried.  I only used the one from mouser.com.  use other diodes at your own risk.
Or through-hole diodes:
Mouser: http://www.mouser.com/ProductDetail/Fairchild-Semiconductor/1N4148/?qs=%2fha2pyFadugGtrAjJwCYGI3HvinoiCRK2mHek8%252bo6Ms%3d
digikey: http://www.digikey.com/product-detail/en/1N4148/1N4148FS-ND/458603
These diodes are the same diodes I used on my Phantoms and MX Mini.  I didn't use these with KMAC.  Links provided here are for reference only.
LED datasheet: * KMAC-LED-SPEC.pdf (201.67 kB - downloaded 115 times.)
I use part number 645-521-9901-802F at mouser.com
March 31st, 2013:
Latest KMAC Keymap program.  This is a standalone version and doesn't require an account or a password:
http://go9.co/iLJ
November 14th, 2012:
New KMAC Keymap Program: http://go9.co/fqx
New KMAC Korean Manual: http://go9.co/fqs
New KMAC video: http://vimeo.com/53505052
[OLD]
New KMAC Keymap tools
Old KMAC Keymap tools, kept for reference
Project KMAC User Manual V1.2 Korean Edition
Soldering instruction, in Korean:
http://www.kbdmania.net/xe/3706757
Program Instruction, in Korean:
http://www.kbdmania.net/xe/3791549
[/OLD]
KMAC PCB manufacturing videos:
It is possible to use SMD diodes on KMAC PCB instead of through-hole diodes.
2372-3
2374-4
Mouser.com has it:
digikey has it as well, but mouser.com is cheaper.
Solder pads for SMD diodes already have solder on them, because they are originally prepped for machine soldering.  To hand solder, I will need to remove solder from one of the solder pads with wick first.
Video of how to hand solder SMD diode to KMAC PCB:
« Last Edit: Sun, 31 March 2013, 21:14:05 by litster »
Online reaper
  • Moderator Emeritus
KMAC DIY Thread
« Reply #1 on: Sun, 29 April 2012, 02:14:47 »
Nice!  Can't wait to see more as you progress.  If I have anything to contribute I'll post it here. =)
Online harrison
KMAC DIY Thread
« Reply #2 on: Sun, 29 April 2012, 13:50:51 »
do the tops and bottoms get removed from the PCB?  the top would appear that it has to be removed to allow for clearance on the usb connector, but that it's cut to  support the bottom of the connector still (a very cool design if that's correct).
[work]ducky tiger dk-9008G2, cherry mx brown|logitech performance mx
[home]filco fkbn87ml/eb, cherry mx black|logitech mx620
Offline litster
KMAC DIY Thread
« Reply #3 on: Sun, 29 April 2012, 14:00:04 »
Yes, I believe the top and bottom need to be removed.
Offline litster
KMAC DIY Thread
« Reply #4 on: Sun, 29 April 2012, 14:03:33 »
« Last Edit: Sat, 18 August 2012, 03:03:49 by litster »
Offline litster
KMAC DIY Thread
« Reply #5 on: Sun, 13 May 2012, 00:27:33 »
So, it is possible to use SMD diodes on KMAC PCB instead of through-hole diodes.
[ Attachment Invalid Or Does Not Exist ] 50126[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 50127[/ATTACH]
Mouser.com has it:
both solder pads for each SMD diodes already have solder on them, because they are originally prepped for machine soldering.  To hand solder, I will need to remove solder from one of the solder pads with wick first.
I could just solder through-hole diodes, but I already did that a couple time on Phantom.  So I will give SMD a try next week when my diodes are here.  I hope I won't ruin my KMAC :-)
Offline tsangan
  • Administrator
  • 1000/600
KMAC DIY Thread
« Reply #6 on: Sun, 13 May 2012, 02:44:22 »
You are a brave man litster!
Keyboardless
Offline litster
KMAC DIY Thread
« Reply #7 on: Sun, 13 May 2012, 02:57:09 »
the line between brave and stupid is fine.  We will see which side of the line I am on :-)
Offline alaricljs
  • I be WOT'ing all day...
  • Administrator
KMAC DIY Thread
« Reply #8 on: Sun, 13 May 2012, 07:24:01 »
As far as SMD goes, those are big.  You'll have no trouble at all if you've been soldering anything.  Just need to hold the bugger down so it doesn't float on the solder.
Filco w/ Imsto thick PBT
Offline litster
KMAC DIY Thread
« Reply #9 on: Wed, 16 May 2012, 23:54:28 »
Received my diodes from mouser today.  Did a couple of them.  Wasn't too hard.  The printing on the diodes are too small and too faint to really see.  I used a magnifying glass with a flash light to read it.   Also used a multimeter to confirm the black strip.
Since the diode pads are already prepped, I had to use wick to remove solder from one of the pads before I can solder.  I may do a video later.
[ Attachment Invalid Or Does Not Exist ] 50589[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 50588[/ATTACH]
Offline litster
KMAC DIY Thread
« Reply #10 on: Thu, 17 May 2012, 02:24:33 »
Video of soldering one diode onto KMAC.  1080p available.
In the video, I didn't do a good job removing the solder from the pad.
« Last Edit: Sun, 12 August 2012, 06:37:06 by mkawa »
Offline litster
Re: KMAC DIY Thread
« Reply #11 on: Sun, 12 August 2012, 01:55:02 »
all the links and attachments are broken after forum software migration.  I will have to fix them later.
Online sherryton
    • Originative
Re: KMAC DIY Thread
« Reply #12 on: Sat, 18 August 2012, 01:20:33 »
You should teach people how to clip the cherry stabilizers.  I took nearly 2 hours to figure out how to put the damn thing together.  The pictures didn't help me.
Well, finally, my finished KMAC with Linear 55g!
Offline litster
Re: KMAC DIY Thread
« Reply #13 on: Sat, 18 August 2012, 17:59:34 »
Here is a video on how to clip your Cherry stabilizer to get rid of the mushy feel.  After this mod, my modifiers feel just as good as Costar's.
Offline litster
Re: KMAC DIY Thread
« Reply #14 on: Tue, 21 August 2012, 22:33:40 »
Here are the two KMACs I built:
KMAC winkey Titanium with Dolch double shots + Hashbaz's Dolch Moogle + Hashbaz's Red Cherry font Enter + the mystery keycap I just received.
This is a KMAC winkeless Silver with 2 sets of Cherry dye sub keycaps.  One set is just plain black on beige Cherry dye sub.  The other set RGB dye sub with some special print caps.
Offline sth
  • 2 girls 1 cuprubber
  • don't hate me cause i'm beautiful
    • User:Sth
Re: KMAC DIY Thread
« Reply #15 on: Thu, 30 August 2012, 20:14:44 »
Hey litster - can you tell me the specs for the LEDs you used? i want to make sure to get the right ones.
Offline litster
Re: KMAC DIY Thread
« Reply #16 on: Thu, 30 August 2012, 21:28:06 »
I chose some LEDs that are not very bright.  If you use caps with an LED window, these are good enough.  If you use regular caps, then you will want LEDs brighter that what I picked.  I only soldered LEDs for caps lock and scroll lock.  I didn't install LEDs to the function keys and WASD.
Green: http://www.mouser.com/Search/ProductDetail.aspx?R=WP710A10SGCvirtualkey60400000virtualkey604-WP710A10SGC
Blue: http://www.mouser.com/Search/ProductDetail.aspx?R=VAOL-3LSBY1virtualkey59300000virtualkey593-VAOL-3LSBY1
Red: http://www.mouser.com/Search/ProductDetail.aspx?R=WP710A10ECvirtualkey60400000virtualkey604-WP710A10EC
Orange: http://www.mouser.com/Search/ProductDetail.aspx?R=WP710A10EDvirtualkey60400000virtualkey604-WP710A10ED
Yellow: http://www.mouser.com/Search/ProductDetail.aspx?R=WP710A10YTvirtualkey60400000virtualkey604-WP710A10YT
White: http://www.mouser.com/Search/ProductDetail.aspx?R=521-9901-802Fvirtualkey64500000virtualkey645-521-9901-802F
I bought 10 of each, but I only used white.  The other should work, too.  I just didn't solder them on to any keyboard.
Basically you want T-1 size 3mm, around 3.5V forward voltage.  The white ones I am using now is 1100mcd brightness.  You could use something dimmer if you use windowed caps.  If you use regular caps, you might want something brighter.  Also some people are getting creative with UV LEDs.   :)
Offline sth
    • User:Sth
Re: KMAC DIY Thread
« Reply #17 on: Thu, 30 August 2012, 21:30:34 »
very cool, thank you :)
Offline litster
Re: KMAC DIY Thread
« Reply #18 on: Mon, 15 October 2012, 21:50:22 »
Offline whiskerBox
Re: KMAC DIY Thread
« Reply #19 on: Tue, 16 October 2012, 10:37:49 »
I thought there was an English version of the manual as well?
Pretty sure I had it at some point, might be on my old computer I will look tonight.
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
Offline litster
Re: KMAC DIY Thread
« Reply #20 on: Tue, 16 October 2012, 12:14:53 »
yeah, I think there was an English version, but it was for the older firmware version.  This one is new.  Maybe it will be translated to English later.
Offline whiskerBox
Re: KMAC DIY Thread
« Reply #21 on: Wed, 17 October 2012, 11:35:11 »
Ah ok that makes sense, I guess I will be waiting for that lol
Offline litster
Re: KMAC DIY Thread
« Reply #22 on: Wed, 17 October 2012, 23:18:08 »
First post's link also updated.
Online m00nshake
Re: KMAC DIY Thread
« Reply #23 on: Fri, 19 October 2012, 18:23:51 »
Okay, forgive me for being a complete newb to this but what are the diodes for exactly?
Ducky Shine II w/ Green LEDs | Das Professional | Italian Red Filco Ninja Tenkeyless | Unicomp Wildcats Buckling Spring | My Heatware :)
Offline litster
Re: KMAC DIY Thread
« Reply #24 on: Fri, 19 October 2012, 18:35:41 »
you need diodes if you want 6 or more KRO.  Diodes allows electricity flow only in one direction.  Without diodes in the matrix, either ghost keys maybe registered when more than a couple of keys are pressed at the same time, or only 2 keys are registers when you have 3, 4, or more keys are pressed.
Offline alaricljs
  • Administrator
Re: KMAC DIY Thread
« Reply #25 on: Fri, 19 October 2012, 18:36:06 »
Diodes are one way doors for electricity.  What they do is allow you to detect what switches are closed and know those are the only switches closed.  Otherwise some switch combinations make it seem as tho other switches are closed when they aren't actually.
Offline litster
Re: KMAC DIY Thread
« Reply #26 on: Fri, 19 October 2012, 18:36:57 »
I won!
Offline alaricljs
  • Administrator
Re: KMAC DIY Thread
« Reply #27 on: Fri, 19 October 2012, 18:53:50 »
Get off my lawn!
Online m00nshake
Re: KMAC DIY Thread
« Reply #28 on: Fri, 19 October 2012, 18:55:42 »
Ha! Thanks guys. I've just received a pm that I snagged a KMAC, so I'm sure you can understand my excitement with being able to get this DIY project working. Which means...
...lots of questions...
thankfully you guys are the bees knees... so....
how do you know where on the board to solder these diodes? And how many do you need on the board?
Also... I'm curious as to how to get led lights working on this board. I know you have to buy the lights but how do you get them working on the board.
Now, I'm new to soldering but I'm eager to learn and I want to do this on my own. However, I also don't want to destroy the board. Do any of you guys have any advice for me that would help me along the path to success once I start building this board?
Offline Viz
Re: KMAC DIY Thread
« Reply #29 on: Fri, 19 October 2012, 19:01:21 »
This is kinda OT, but not worth a new topic:
When are the KMAC mini's avaiable? and for what price?
KMAC mini : Model M SSK : HHKB
