Author Topic: Cherry G81-1800LUMUS-0 US$14.99 on eBay  (Read 1056 times)
Offline urbanus
« on: Thu, 24 May 2012, 06:27:25 »
NIB G81-1800, grey colour:
CHERRY NEW PC KEYBOARD G81-1800LUMUS-0 16" USB
Interesting because of the price, and because of the quantity the vendor has in stock (55 left according to the description).
Cherry G81-1800s are described as well-made keyboards, but be warned that most keyboard enthusiasts don't like the Cherry MY FTSC switches.  (Personally I think FTSC is great, but it took me quite a while to get used to them: very different to other mechanical switches.)
Offline cactux
  • Topre Knight
« Reply #1 on: Thu, 24 May 2012, 06:32:22 »
64 usd shipping to AUS no way
Offline urbanus
« Reply #2 on: Thu, 24 May 2012, 06:47:24 »
Yes, but I asked the vendor how much for combined postage for two, and he replied $71.30.  That's two new keyboards for less than what you'd pay for one in Aus at retail prices.  Not bad I think.
Offline cactux
  • Topre Knight
« Reply #3 on: Thu, 24 May 2012, 07:07:58 »
the G81 is not very good compare with the G80 and 40 USD shipping for that board still high
Offline tobr1an
« Reply #4 on: Thu, 24 May 2012, 20:34:03 »
What key switch do they use?
Offline metafour
  • I've made a huge mistake
« Reply #5 on: Thu, 24 May 2012, 20:35:50 »
Quote from: tobr1an;599532
Quote from: urbanus;599042
MY
Offline tobr1an
« Reply #6 on: Thu, 24 May 2012, 21:06:07 »
Quote from: metafour;599533
MY
Lol sorry didn't read the bottom of it, and you know what kinda of key caps they are?
Offline metafour
« Reply #7 on: Thu, 24 May 2012, 21:38:09 »
Quote from: tobr1an;599545
I believe they're lasered ABS because of the LUMUS code but I could be way off.
Offline IvanIvanovich
  • Cherry Overfiend
« Reply #8 on: Thu, 24 May 2012, 21:39:12 »
Lasered PBT, and the stabilized keys are incompatible with MX.
« Last Edit: Thu, 24 May 2012, 21:41:32 by lysol »
Offline Internetlad
« Reply #9 on: Fri, 25 May 2012, 00:38:03 »
so for the 31 bucks a 'murican citizen would be paying, this would be well worth it?
"Beep . . . Beep . . . Beep" -Sputnik I
Offline absyrd
  • Here for the finger-food. Forget the eye-candy.
« Reply #10 on: Fri, 25 May 2012, 11:13:45 »
I have this same keyboard and lysol is dead on. Lasered pbt and the stabilized keys are odd.
However, I did make it into a 25cn "ghetto red" and it is fun to type on. $2 thrift store and nothing for the mod.
custom hyper micro mx kb xxxl mini
Offline metafour
« Reply #11 on: Fri, 25 May 2012, 11:19:13 »
How'd you turn MY switches into "ghetto reds"?
  • Cherry Overfiend
« Reply #12 on: Fri, 25 May 2012, 11:43:24 »
Remove the springs so only the leaf is left. There is a write up on it in the modding section somewhere. It's much lighter than reds, you can actuate by blowing on them practically.
Also I should be more clear and say the stabilized keys are not compatible with Cherry stabilizer, it may be possible to use them on Costar type though I have not tried it.
« Last Edit: Fri, 25 May 2012, 11:46:19 by lysol »
  • Love that PBT
« Reply #13 on: Fri, 25 May 2012, 22:36:11 »
I pulled the spacebar out of my set, and it does appear that the odd stabilizers are costar-compatible. The stem on the spacebar is in the wrong spot, though, so I can't test it for certain. The "bar" on the stabilizer does indeed fit (though tightly) in the costar stabilizer slot. I had to pull the old stabilizer out for obvious reasons, though.
I may mod the stem, as the cherry PBT spacebar is excellent.
Edit: Some sanding may be required, as the cherry MY stabilizer bar seems a bit thicker than the costar. Also, it might not work at all, I wasn't able to test the key travel/action with the stem unmodified.
« Last Edit: Fri, 25 May 2012, 22:39:04 by dorkvader »
My room-mate decided to cancel the internet without telling me.
Limited internet :(
Offline absyrd
« Reply #14 on: Sat, 26 May 2012, 05:23:10 »
Quote from: lysol;599964
It's much lighter than reds, you can actuate by blowing on them practically..
Pretty much! Hah!
Quote from: dorkvader;600359
Yeah. And you could also make the modifiers work by cutting/sanding down the plastic "stabilizers" on the back of the keys and moving stems around. Quite a bit of work.
Like I said, this is a very fun board to do a simple mod on if you can get it very cheap. Even then it is still nice for that price if you like the feel of MYs.
Offline N8N
« Reply #15 on: Sat, 26 May 2012, 16:35:16 »
You can, I have Cherry lasered on a Noppoo right now.  However 1800 format probably means that not all keys are the right size/shape for a std. 104 board anyway.  Otherwise I would be all over this because I like the PBT feel and got my caps off a POS board so some of them are relegendable.
Offline N8N
« Reply #16 on: Sat, 26 May 2012, 16:36:49 »
I just pulled the stabilizers out of the keys and used Costar stabilizers.  bought 'em from WASD.  no probs.  didn't use space bar as needed a different length anyway.  Did mod a MY space bar from a doubleshot POS board to work w/ MX/Costar but that required cutting a lot of stuff off and gluing on the posts from some sacrificial keys
