Author Topic: keycaps and keypuller  (Read 632 times)
Offline malaki
« on: Fri, 15 June 2012, 10:56:24 »
I bought 2 Filcos from The Keyboard company and neither had the red keycaps or a filco keypuller in the package,
is this normal? A friend of mine bought a ducky and even the cheaper ducky had these extras,
I always thought the filcos give you red wasd keys and a keypuller for free as a bonus or am I wrong?
Offline Djuzuh
« Reply #1 on: Fri, 15 June 2012, 10:57:37 »
It was a temporary gift I believe.
They usually don't.
Offline Bruce
  • Moderator
    • http://www.keyboardco.com
« Reply #2 on: Mon, 18 June 2012, 05:06:05 »
Hi Malaki
Yes, Djuzuh is correct on this. Mostly we don't add caps and pullers. Anything that does include them will be marketed as such, so; if it's not in the blurb - it's not in the box.
They were additions with Camo, Ninja and Linear R as far as I remember. Elite Keyboards used to add them to some things even if it was not done at the factory - I think that is the root of the confusion.
Bruce
