Author Topic: Loose keycaps from o-ring mod  (Read 295 times)
Offline Amo
« on: Sun, 24 June 2012, 14:34:35 »
I recently got a Noppoo Choc Mini with MX Reds and put some O-rings on the keys. Now the keys are really loose and pop off. They don't pop off during normal use, but if I run my hands across the board several keys pop out. Is there some secret method to putting the keys back on the switches?
Here is an image of the o-ring on one of the keycaps. The o-ring I used was 3/16" thick and covers half of the stem. I get the feeling that the switches aren't fulling seating in the stem and that is making them wobble and pop off.
[ Attachment Invalid Or Does Not Exist ] 53821[/ATTACH]
Offline Djuzuh
« Reply #1 on: Sun, 24 June 2012, 14:39:52 »
The oring is way to big.
Where did you find those?
Offline Amo
« Reply #2 on: Sun, 24 June 2012, 15:17:58 »
It was one of the options on a group buy a couple of months back. I just found it on a website that sells o-rings, McMaster-Carr. I want maximum key travel reduction and these were the thickest. Plus I saw a youtube video of a guy who put them on his poker.
Offline Amo
Re: Loose keycaps from o-ring mod
« Reply #3 on: Sat, 21 July 2012, 10:20:13 »
Update on the issue, I put 1-2 layers of saran wrap between the keycap and the switch and the problem was solved!
