Author Topic: DIY resources  (Read 58886 times)
Offline alaricljs
  • I be WOT'ing all day...
DIY resources
« on: Tue, 24 July 2012, 16:27:25 »
I'm just going to stick this here to be nice instead of hiding it in my bookmarks...
proto PCB board services:
OSH Park (purple boards @ $5/sq in for 3 copies)
BatchPCB  (is no more :()
Seeed Fusion (10 copies, 25cm^2 max size for $10, larger for more $)
Production PCB board shops:
PCBWing
Cherry MX datasheet alternate version with more details
Alps switch datasheet (courtesy: Matias)
* FuhuaAlpsSwitchDatasheet.jpg (272.61 kB. 1920x1400 - viewed 8643 times.)
teensy's at pjrc.com
PCB layout software:   KiCAD
Costar stabilizer layout (thanks to bpiphany):
951-1
Electronics parts:
Mouser
DigiKey
Hard goods (screws, metal, tools, ...):
McMaster Carr - Good for hardware and some raw metal
OnLine Metals - Good for raw metal and plastic
Manufacturing:
Big Blue Saw - laser/waterjet sheet cutting
Ponoko - 3d printing
Shapeways - 3d printing
« Last Edit: Sun, 02 June 2013, 17:09:36 by alaricljs »
Filco w/ Imsto thick PBT
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
Re: DIY resources
« Reply #1 on: Wed, 25 July 2012, 04:30:06 »
hey, good idea!
light-duty one-off machining:
http://www.frontpanelexpress.com/
http://www.emachineshop.com/
3d printing:
http://www.shapeways.com/
stuff that would be cool to document here:
detailed technical drawings of popular keyboards and parts
meshes for common keycaps
Offline bpiphany
Re: DIY resources
« Reply #2 on: Tue, 31 July 2012, 08:21:58 »
The link to batchpcb is broken, and I also want to add pcbwing that I have had plenty of good experience with. Very good service, and helpful with sorting out questions on PCB designs.
Offline wcass
Re: DIY resources
« Reply #3 on: Tue, 31 July 2012, 13:03:20 »
you must include McMaster Carr for .... stuff
http://www.mcmaster.com/#
Offline rknize
    • metaruss
Re: DIY resources
« Reply #4 on: Tue, 31 July 2012, 13:12:12 »
Russ
Offline alaricljs
Re: DIY resources
« Reply #5 on: Tue, 31 July 2012, 13:24:35 »
It's a trap!   ExpressPCB is more expensive than OSH if you are doing their Mini Boards.  They are more expensive for production than many other fabs.  Then there's the cost of being locked into their software.
Offline Parak
Re: DIY resources
« Reply #6 on: Wed, 01 August 2012, 11:57:09 »
Fanboy of http://stores.ebay.com/sitopway here as I've probably mentioned a few times in the past :p They seem to have the capability to do pretty much anything I've asked far outside of what they typically claim to offer, including smd assembly with component sourcing. Their prices and regular turnaround times are the best that I've found so far, unless I need something small for which I use OSH. I just recently ordered some rather atypically specced large pcbs for a project, and it took three business days for them to ship. Non-crappy shipping (DHL), although expensive, means it takes around the same time to get to me too.
Offline litster
  • rare caps?! THAT'S A SMILIN
Re: DIY resources
« Reply #7 on: Mon, 27 August 2012, 10:42:39 »
Free 2d cad program: qcad.
Offline bpiphany
Re: DIY resources
« Reply #8 on: Mon, 27 August 2012, 13:10:47 »
When I ran the usual "sudo apt-get install qcad" today I got something called LibreCad instead. I don't know exactly how they are related but it is in some way a derivative from qcad.
Offline __red__
Re: DIY resources
« Reply #9 on: Mon, 27 August 2012, 14:50:39 »
Thanks for that link to librecad.  We just got a laser-cutter so your timing for free cad software was impeccable ;-)
Offline wcass
Re: DIY resources
« Reply #10 on: Mon, 27 August 2012, 15:37:36 »
i was trained on AutoCAD but i actually prefer DeltaCAD. it is also the easiest CAD program i have ever used. a beginner with no experience would have little trouble.
full feature demo is good for 45 days or buy it for $40. PC and Mac supported.
http://www.deltacad.com/
Offline ferociousfingerings
Re: DIY resources
« Reply #11 on: Tue, 09 October 2012, 15:58:03 »
Figured "DIY Resources" might be the right place to ask/suggest:
Cherry-MX-compatible LED specs/reqs?
Need to know:
1) physical and electrical parameters, for full compatibility with cherry-switch boards
2) types of soldering equipment and any other tools required or recommended for any LED-modding
3) where to get them
And perhaps a "LED mod" guide?
If such a thing already exists, i'm having trouble finding it, and think it should be included in the OP of this thread.
kthxbye!
Logitech G710+
Offline alaricljs
Re: DIY resources
« Reply #12 on: Tue, 09 October 2012, 16:33:51 »
The most compatible leds are going to be 3mm flat top, column (no shoulder) LEDs.  After that is 3mm flat top w/ shoulder (and suggest you cut it off), and lastly 3mm dome of either type with the same suggestions.
As for electrical specs, you'd want to match whatever the design intended.  Most red/yellow/orange LEDs are 2.2-2.4 volts and most blue/green/pink/white/uv are 3.1-3.4 volts so they are usually not interchangeable unless you can also swap out the resistors.  This of course depends on  you being able to determine how the circuit is driven in the first place, some boards do not use 1 resistor for every LED.
For LED modding tools you want whatever tools you are comfortable with for de-soldering and soldering, Weller and Hakko are the common upper end and mid-tier brands, Aoyue is a feature complete brand that is less expensive but doesn't have the pedigree.  You can go with a cheapo Radio Shack manual desoldering iron if you don't plan on doing this sort of thing a lot.  Flush-cut clippers for cutting leads and shoulders.  There are many places to get this stuff, and many brands.
As for where to get LEDs, ebay is pretty good mostly because of the search engine.
Offline esoomenona
  • Gnillort?
« Reply #13 on: Tue, 09 October 2012, 17:28:55 »
« Last Edit: Tue, 08 September 2015, 10:59:22 by esoomenona »
Offline alaricljs
Re: DIY resources
« Reply #14 on: Tue, 09 October 2012, 17:57:54 »
Resistors are not rated in voltage, it's wattage... wattage is amps times volts.
LedCalc is a good resource for figuring out what you're looking for...
Most keyboards I've seen supply the 5v from USB straight to the LED with an appropriate resistor.  I think I recall Deck boards using a couple parallel LEDs per resistor.
You just figure out what the circuit does, and use that to figure out what wattage resistor to use with your particular LED to get good results.
Offline asura
  • not a duck
Re: DIY resources
« Reply #15 on: Wed, 10 October 2012, 10:52:58 »
Any interest in a SketchUp model of Cherry profile key-caps?  May do OEM caps at some point too.  Just external at the moment, though I am going to add thickness and stem details - just thought I'd post progress.
Offline mkawa
Re: DIY resources
« Reply #16 on: Sun, 28 October 2012, 09:13:03 »
3d printing/rapid prototyping resources:
damorgue: high purity titanium (short on machine time?) nil on machine time
treble318: CNC milling of various materials, powdercoating (CURRENTLY DOWN)
shapeways: great option for one-offs
signature plastics: unknown what rapid prototyping/FDM capabilities they have no FDM
i should also add that many people here probably have hackerspaces nearby (especially if you are in the seattle area) but may not know it. these outfits will teach you how to use their fabrication devices for a small donation in time and money.
« Last Edit: Sat, 02 February 2013, 11:45:54 by mkawa »
Offline damorgue
    • Personal portfolio
Re: DIY resources
« Reply #17 on: Sun, 28 October 2012, 09:39:09 »
treble318: CNC milling of various materials (CURRENTLY DOWN)
Prototal and Materialise can both print things in plastic as well in case you need other options than Shapeways.
Offline bavman
Re: DIY resources
« Reply #18 on: Sun, 02 December 2012, 17:52:31 »
Where can I find a predesigned PCB layout for a TKL board?
Offline TheProfosist
  • Custom Layouts Only!
Re: Re: DIY resources
« Reply #19 on: Mon, 03 December 2012, 05:20:15 »
i dont think your going to find one...
Offline SmallFry
« Reply #20 on: Mon, 03 December 2012, 07:31:48 »
You could get the GH60 for a 60% layout. The files are in the thread.
Offline bavman
Re: DIY resources
« Reply #21 on: Mon, 03 December 2012, 08:15:03 »
Thats too bad. I thought with the custom boards floating around someone would be sharing their design. I don't know the first thing about designing stuff like this, but I can build it if I have designs :D I guess the next best thing would be to try to get a hold of a pre-made board from someone like costar but I doubt they'd be open to the idea of selling just a pcb.
Yeah I saw that thread and it looks like an awesome community project, but 60% keyboard just don't float my boat. I've tried several before and always missed the extra keys on a tkl.
Offline alaricljs
Re: DIY resources
« Reply #22 on: Mon, 03 December 2012, 08:18:05 »
I tried for just cases from Costar, no go.  Whole boat or nothing.
Offline The_Beast
  • I like wood ಠ_๏
Re: DIY resources
« Reply #23 on: Mon, 03 December 2012, 08:20:36 »
Costar makes boats now?
sweet
Offline kbfreak
  • * Commercial Vendor
Re: DIY resources
« Reply #24 on: Sat, 22 December 2012, 07:02:21 »
this is definitely a good list. thank you!
Offline realex
Re: DIY resources
« Reply #25 on: Sat, 02 February 2013, 11:41:19 »
can someone provide an exact technical drawing (or measurements from 3d profiling) of a filco tkl case?
Offline sordna
Re: DIY resources
« Reply #26 on: Wed, 06 February 2013, 18:32:08 »
Kinesis Advantage parts, including PCB-mount cherry MX switches with integrated diodes: Kinesis
http://www.kinesis-ergo.com/
o-rings (switch dampeners), stabilizers, as well as custom keycaps and cherry MX switches (plate-mount only): WASD Keyboards
http://www.wasdkeyboards.com/
Electronic parts: ABRA Electronics
http://www.abra-electronics.com/
Arcade buttons: Canadian Joysticks
http://www.canadianjoysticks.com/
Programmable devices/buttons: PI Engineering
http://www.piengineering.com/access.php
« Last Edit: Wed, 06 February 2013, 18:44:15 by sordna »
Offline Krogenar
  • The Kontrarian
    • Buried Planet
Re: DIY resources
« Reply #27 on: Thu, 07 February 2013, 14:50:55 »
This will seem like a stupid question, but I cannot find this anywhere on the forum (so far) -- where do you guys keep that keycap printout that I keep seeing people use to display their moogle and tsangan kits, etc.? I'm interested in joining a groupbuy and am trying to figure out what kits I'll need, and I'm hoping this sheet will help me determine what I'll need.
Where can I find this printout?
Quote from: Samuel Adams
Offline rknize
    • metaruss
Re: DIY resources
« Reply #28 on: Thu, 07 February 2013, 15:16:39 »
Russ
Offline mkawa
Re: DIY resources
« Reply #29 on: Thu, 07 February 2013, 17:23:23 »
conveniently still available for purchase here: http://www.techkeys.us/accessories.php
Offline cf1888
Re: DIY resources
« Reply #30 on: Tue, 12 March 2013, 14:31:07 »
Here is another great product: a Bluetooth keyboard adapter that turns a USB/PS2 keyboard into a Bluetooth keyboard. Just got mine. Works like a charm on my Model-M and iPad.
http://handheldsci.com/kb
Offline rknize
    • metaruss
Re: DIY resources
« Reply #31 on: Tue, 12 March 2013, 14:39:08 »
What sort of battery life do you get with a Model M on there?
Russ
Offline calavera
Re: DIY resources
« Reply #32 on: Tue, 12 March 2013, 18:08:46 »
Wow, this thread is exactly what I was looking for. Thanks
Offline 5volts
Re: DIY resources
« Reply #33 on: Thu, 30 May 2013, 15:07:33 »
BatchPCB is no more, Sparkfun killed it off :(
I made my first PCB on BatchPCB, I was sorry to see it go. They (and I) recommend OshPark, especially if you live in the U.S.
Very small boards are very cheap there; for instance, I just ordered 3 boards to fit a single Cherry MX switch and spent $4.10, including shipping.
Anyone else using Eagle for PCB construction?
I've made a very rudimentary library for Cherry MX switches on Eagle, but it needs testing/refinement. Happy to share it though.
Offline wcass
Re: DIY resources
« Reply #34 on: Sun, 02 June 2013, 15:40:45 »
any recommendations for custom cut metal plates?
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
Re: DIY resources
« Reply #35 on: Wed, 03 July 2013, 09:06:29 »
Re: DIY resources
« Reply #36 on: Sun, 07 July 2013, 11:52:43 »
Talk to The_Beast for getting them cut/made.
Re: DIY resources
« Reply #37 on: Sun, 07 July 2013, 11:56:19 »
Matt3o is currently running a GB for custom laser cutting on deskthority.
http://deskthority.net/marketplace-f11/laser-cut-prototyping-mini-gb-t6102.html
Offline Melvang
Re: DIY resources
« Reply #38 on: Mon, 08 July 2013, 10:55:26 »
alright so how do i get started with kicad?  The website in the OP on this thread is kind of vague.  If it helps i am running Win8 64 bit.
Offline vivalarevolución
Re: DIY resources
« Reply #39 on: Wed, 21 August 2013, 15:14:10 »
Any chance we can add resources for springs to this thread?
Offline alaricljs
Re: DIY resources
« Reply #40 on: Wed, 21 August 2013, 15:15:25 »
Name them :)
Re: DIY resources
« Reply #41 on: Wed, 21 August 2013, 15:19:46 »
Name them :)
That's why I ask because I don't have a clue and I am feeling lazy right know about searching.
Offline ericball
Re: DIY resources
« Reply #42 on: Fri, 14 March 2014, 15:17:07 »
RC hobby shops often have inexpensive 5.5mm nut drivers for opening IBM/Lexmark/Unicomp keyboards.
I was able to pick one up at Hobby Home in Toronto for C$4 (tax included).
Offline damorgue
Re: DIY resources
« Reply #43 on: Fri, 14 March 2014, 17:45:46 »
In case someone doesn't have them nearby, this one happens to work with IBM boards.
Offline mikew0w
Re: DIY resources
« Reply #44 on: Thu, 15 May 2014, 10:29:36 »
Does anyone know the 'type' of ribbon connector the IBM membranes use?
I bought a IBM actionwriter with a buckling spring keyboard. I couldn't get the female ribbon cable sockets off the main board easily and I was hoping I could just buy the right thing off digikey.
I'd like to try and wire this up to a teensy I had laying around.
Offline wcass
Re: DIY resources
« Reply #45 on: Fri, 16 May 2014, 00:03:01 »
i happen to have a few of those. they are called FFC connectors. the specific ones you want are TRIO-MATE series.
Offline mikew0w
Re: DIY resources
« Reply #46 on: Sat, 31 May 2014, 20:02:06 »
Thanks. Do you happen to know the pitch size of these connectors? My hunch is 0.100" (2.54mm) based on what is available but I don't have anything that measures smaller than a mm.
Offline wcass
Re: DIY resources
« Reply #47 on: Sun, 01 June 2014, 08:56:46 »
yes, that is correct; .1"
Offline dante
Re: DIY resources
« Reply #48 on: Sat, 14 June 2014, 08:43:35 »
Open source tools for quickly creating keyboard layouts?  Not sure if one exists allowing you to change the sizes of some keys? (ie: substituting 1x1 for tab/capslock)
Offline wcass
Re: DIY resources
« Reply #49 on: Sat, 14 June 2014, 21:16:25 »
The two applications that I use are not open source, but are free.
For quick keyboard representations within Windows, I use Keyboard Designer which is part of Qliner Hotkeys. The main application (Hotkeys) is similar to AutoHotkey and the installer places a process in the Run key of your registry (I remove it because i don't use that feature).
You can set height and width of keys and spaces and even do multi-height keys like ISO Enter. You can not change the angle of keys, do a column-staggered layout, or multi-line text on the keys. Also, color and font options are global - you can't make the color of some keys different than others. The user interface looks like this:
68055-0
If you need to do multi-line text, column-staggered layout, angled keys, or truly odd shaped keys, you will need a graphics or CAD program. If you ever want to turn you layout into a real keyboard, you will need CAD. DeltaCad is the easiest, most intuitive CAD application that I have used and the full functional demo is good for 90 days before print/save is disabled (re-install to get another 90 days). The UI looks like this:
68057-1
