Author Topic: infobox  (Read 75677 times)
Offline sth
  • 2 girls 1 cuprubber
infobox
« on: Mon, 30 July 2012, 21:14:13 »
are infoboxes working yet? im not a mediawiki expert so I'm not sure if it's just me having problems.
Offline sth
Re: infobox
« Reply #1 on: Mon, 30 July 2012, 21:20:42 »
Looks like I dont have permissions to import wikipedia infoboxes either.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
Re: infobox
« Reply #2 on: Mon, 30 July 2012, 21:34:03 »
rknize is looking at the former. (we're missing something or other?)
Offline sth
Re: infobox
« Reply #3 on: Mon, 30 July 2012, 21:37:18 »
Hard for me to say, like I said i am not a MW expert so I am just learning as I am creating articles. I thought having an infobox template for group buy sets would be nice, and in addition I can create an infobox template for keyboards and mice (if we're going to add mice) as well.
If you have any recommendations for what should go into each please let me know or post here.
Current GB infobox:
|name               =
|other_names        =
|image              =
|image_alt          =
|caption            =
|Group Buy Operator =
|Source of Keys     =
|Colors used        =
|Base Kit           =
|Extras included in Base Kit            =
|Other available addons =
I plan on adding pages for the addons (page for Tsangan kit, page for ISO addon, page for 10key addon etc) as well as starting a moogle page + category.
Offline mkawa
Re: infobox
« Reply #4 on: Mon, 30 July 2012, 21:42:53 »
key material
printing method
profile(s)
MOQ
final order count
Offline sth
Re: infobox
« Reply #5 on: Mon, 30 July 2012, 22:00:35 »
Good calls all around :) Final order count might be a little harder to get as well as MOQ but i'll try to be proactive about them and I will contact GB runners for info that isnt readily available.
Offline rknize
    • metaruss
Re: infobox
« Reply #6 on: Mon, 30 July 2012, 22:20:31 »
Imported.  Give them a try and lmk.
http://wiki.geekhack.org/index.php?title=InfoboxTest
Russ
fartq
  •  Guest
Re: infobox
« Reply #7 on: Mon, 30 July 2012, 22:24:55 »
looking good!
Offline sth
Re: infobox
« Reply #8 on: Mon, 30 July 2012, 22:53:23 »
Man I'm confused. Am I not able to create new infobox templates? How exactly is this supposed to work?
I've been doing some websearching and it looks like infoboxes are mostly a wikipedia thing and that mediawiki doesn't really support them out of the box in the same way that WP does.
Rknize can you break down what you did to get the template working and maybe a way to duplicate or edit existing templates?
Offline rknize
    • metaruss
Re: infobox
« Reply #9 on: Mon, 30 July 2012, 23:03:51 »
I had to create each and every little, tiny, annoying piece of their template and its dependencies.  I don't know why you can't create them.  Anyway, you should be able to use them now.
Russ
Offline sth
Re: infobox
« Reply #10 on: Mon, 30 July 2012, 23:05:43 »
Maybe I just wasn't doing enough :P I am looking into the infobox that you created and it does look like there is more to it than I thought. Thanks
Offline sth
Re: infobox
« Reply #11 on: Tue, 31 July 2012, 00:26:42 »
rknize - did you follow a tutorial to create that, or did you piece it together from the WP pages on infoboxes?
Offline rknize
    • metaruss
Re: infobox
« Reply #12 on: Tue, 31 July 2012, 00:30:21 »
I followed the WP pages.
Russ
Offline sth
Re: infobox
« Reply #13 on: Tue, 31 July 2012, 22:50:33 »
Cool, it's finally starting to make a little sense to me (or at least, it's working better and I'm not complaining). Expect some group buy set pages to start getting populated soon :)
Offline sth
Re: infobox
« Reply #14 on: Wed, 01 August 2012, 05:09:22 »
Offline mkawa
Re: infobox
« Reply #15 on: Wed, 01 August 2012, 07:34:27 »
lookin gooood
Offline rknize
    • metaruss
Re: infobox
« Reply #16 on: Wed, 01 August 2012, 09:56:36 »
Very nice!
Russ
Offline Zwi
  • hi.
Re: infobox
« Reply #17 on: Wed, 01 August 2012, 11:03:11 »
Looks good maybe put the forum link inside the infobox?
Offline sth
Re: infobox
« Reply #18 on: Wed, 01 August 2012, 11:59:31 »
Yes, good call. I was just playing with different layout options but the bottom text is probably not necessary and can be replaced with a forum link in the same graphical style as the rest of the info.
Offline sth
Re: infobox
« Reply #19 on: Wed, 30 January 2013, 23:58:07 »
Hey Russ I think there might be a problem with the infoboxes?
I reverted a bunch of changes and the the source looks right but the infoboxes are parsed as some copypasta crap...
Offline sth
Re: infobox
« Reply #20 on: Thu, 31 January 2013, 00:16:15 »
OH I think I see what happened.
I am trying to track down all the modifications but during that storm of anon edits a bunch of templates got totally borked. At least the infoboxes are back instead of random garbage but there is a bunch of weirdness with the styles.
update - i think i got them all  :)
« Last Edit: Thu, 31 January 2013, 00:24:02 by sth »
Offline SmallFry
Re: infobox
« Reply #21 on: Thu, 31 January 2013, 00:34:08 »
There isn't any more anon editing is there?
* SmallFry checks his wiki page for Ripster edits.
Offline sth
Re: infobox
« Reply #22 on: Thu, 31 January 2013, 00:35:08 »
No I think the problem was fixed, but not everything was reverted.
Offline SmallFry
Re: infobox
« Reply #23 on: Thu, 31 January 2013, 00:43:16 »
Ah. Perfect. Thanks.
Offline rknize
    • metaruss
Re: infobox
« Reply #24 on: Thu, 31 January 2013, 08:47:22 »
Thanks, sth.
Russ
