Author Topic: Cherry font  (Read 13207 times)
Offline IvanIvanovich
  • Mr. Silk Underwear
Cherry font
« on: Wed, 19 September 2012, 21:05:12 »
As many of you know I have been working on some Cherry replica sets. During this time I have been collecting photos and scans of Cherry keycaps so I could build a font file. So far I have collected all the necessary characters from US/RU/DE/IT/SP/FR/GB... If you have sets in other languages that have unique characters, please if you can get some high res macro shots or scans to submit for completeness that would be fantastic. Black on white is preferred as it is easier to work with for me. Of course I will share the file with the community for other projects.
Version 1.0 US ANSI is available as .tif format. I will keep improving and adding other language keys as I go along.
These are not perfect, so do not complain. You are free to improve them where needed and share them back :)
« Last Edit: Sun, 20 April 2014, 21:32:21 by IvanIvanovich »
Offline ZcHuer
Re: Cherry font
« Reply #1 on: Tue, 09 October 2012, 06:16:27 »
No sure if you have had these two keys legends from the G80-5000HAMPO :)
Re: Cherry font
« Reply #2 on: Tue, 09 October 2012, 12:57:55 »
I have Spanish set that has those charachter, but actually the most unique key on Portugese is the one next to the backspace. I don't know if that key appears on any other layout but it's not too hard to double up the < > from pretty much any other set. Thanks for checking in.
Offline Broadmonkey
Re: Cherry font
« Reply #3 on: Fri, 12 October 2012, 17:53:09 »
I have a danish layout if that helps. Any characters you miss from that?
Re: Cherry font
« Reply #4 on: Fri, 12 October 2012, 19:53:11 »
I don't have the nordic Å, Æ or Ø. If you could take some clean straight top down high res shots of those individual keys that would be great.
Thanks.
Re: Cherry font
« Reply #5 on: Wed, 19 December 2012, 21:54:13 »
Now sharing. Feel free to use them for mock ups and your personal projects. All I ask is you say thank you if you choose to use them in new keys by giving me some.
« Last Edit: Wed, 19 December 2012, 22:02:44 by lysol »
Offline SmallFry
Re: Cherry font
« Reply #6 on: Wed, 19 December 2012, 21:58:32 »
We should compile these into a TTF:D
Re: Cherry font
« Reply #7 on: Wed, 19 December 2012, 22:00:33 »
That is what I want to do eventually make it an .otf font, but for now enjoy some .tif :)
Offline SmallFry
Re: Cherry font
« Reply #8 on: Wed, 19 December 2012, 22:10:47 »
OK cool! Thank you Lysol!
Offline Dianoda
Re: Cherry font
« Reply #9 on: Thu, 20 December 2012, 10:00:32 »
Sweet!  Thanks lysol!
Offline absyrd
  • CPT HYPE PADAWAN
Re: Cherry font
« Reply #10 on: Thu, 20 December 2012, 10:05:35 »
Very nice of you to share your collection and hard work. Thanks, lysol!
Offline gameaholic
Re: Cherry font
« Reply #11 on: Thu, 20 December 2012, 21:26:37 »
Besides the keycaps, once this is done will I be able to import it to Microsoft Word?  That would be awesome.
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
Re: Cherry font
« Reply #12 on: Thu, 20 December 2012, 21:59:57 »
Once it is made into a font file you would be able to use it instead of comic sans for sure.
Offline phetto
  • HHKB JP
Cherry font
« Reply #13 on: Thu, 20 December 2012, 23:02:27 »
I will try to get Å, From danish, finish, norweigian and swedish..
Offline morcles
  • sktchrigzpoxlub
Re: Cherry font
« Reply #14 on: Fri, 21 December 2012, 10:04:10 »
A quick first attempt to put lysol's tif images in a ttf  :)
Where to put the F1 .. F12 glyphs ?
Filco FKBN104MC/EB2 - Filco FKBN87MRL/EW2 + HID Liberation Device - Filco FKBN87M/EB2 + HID Liberation Device - KBC Poker X - Cherry G80-1813HFX Dolch PAC-62 - Cherry G80-3000LPCXY-2 - Mionix NAOS 5000
Offline SmallFry
Re: Cherry font
« Reply #15 on: Fri, 21 December 2012, 10:28:47 »
That TTF doesn't work well with my Android device... :(
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
Re: Cherry font
« Reply #16 on: Fri, 21 December 2012, 10:38:58 »
Wow, nice work lysol.  These will be a big help.
Offline morcles
  • sktchrigzpoxlub
Re: Cherry font
« Reply #17 on: Fri, 21 December 2012, 10:47:56 »
Well, it does ... it's a bit like comic sans or wingdings
and there are not enough TIF's to fill up the entire lowercase alphabet.
Lowercase a..t are "Alt", "Backspace", ...
Uppercase A..Z are keycaps A..Z
Numbers 1..0 are keycaps 1..0
~!@#$%^&*()_+:{}|"<>? are keycaps
use a tool like "charmap" to get an overview.
Offline SmallFry
Re: Cherry font
« Reply #18 on: Fri, 21 December 2012, 10:54:40 »
I'll have to see if I can figure out how to make a TTF...
Offline morcles
  • sktchrigzpoxlub
Re: Cherry font
« Reply #19 on: Fri, 21 December 2012, 10:58:50 »
You want lowercase a..z to be the same as uppercase A..Z ?
Offline esoomenona
  • Gnillort?
Re: Cherry font
« Reply #20 on: Fri, 21 December 2012, 11:00:57 »
That would suck. Maybe have lowercase be Roboto. Aren't they both variations on Helvetica? I wonder how they would look together.
Offline morcles
  • sktchrigzpoxlub
Re: Cherry font
« Reply #21 on: Fri, 21 December 2012, 11:09:41 »
Imho, they won't look very good together.
Roboto has square edges, not rounded.
Roboto is bottom-centered, not top-left aligned.
Re: Cherry font
« Reply #22 on: Fri, 21 December 2012, 11:11:19 »
I think it will be hard to find every character in lower case as they simply never used them all I don't think since only mods and stuff had them. Maybe on some more international layouts? I have many other character from Italian, Spanish, Portuguese, German, French, Russian, Nordic... etc... just not have the time to make them all uniform yet. For building it into a font, I think the correct character locations should be followed, I would build it off MS Arial Unicode and put all the glyphs, and modifier shift, pgup etc type stuff in the private use area.
Offline hashbaz
  • Grand Ancient One
Re: Cherry font
« Reply #23 on: Fri, 21 December 2012, 12:09:12 »
I can probably fill in the missing lowercase letters.  I've synthesized a few non-existent letters for new keys already.
Offline phetto
  • HHKB JP
Re: Cherry font
« Reply #24 on: Fri, 21 December 2012, 14:25:18 »
lysol, is this high enough resolution?
Re: Cherry font
« Reply #25 on: Fri, 21 December 2012, 14:33:32 »
I already have all of those character, but thank you.
Offline phetto
  • HHKB JP
Cherry font
« Reply #26 on: Fri, 21 December 2012, 21:43:20 »
I thought u were looking for Å :P
Btw my package arrived yet?
Re: Cherry font
« Reply #27 on: Sun, 23 December 2012, 11:20:53 »
I did need them awhile ago, but got them from someone else. I needed them for my US Intl set, which was completed so I only need to get all the legends in the same locations in the upper left for uniformity. Some other charachter I have still not even traced yet though.
Yes I got the Strg keys just yesterday.
