Author Topic: Post your Korean Keyboard ^_^  (Read 9190730 times)
0 Members and 14 Guests are viewing this topic.
Offline skcheng
    • Tenafly Dentistry
Re: Post your Korean Keyboard ^_^
« Reply #3050 on: Sat, 30 August 2014, 21:39:34 »
LZ-GH with AEG OG Cherry DS Keycaps!!   And a little Gold Bling!!
Those key caps look familiar :)
They cleaned up nicely right??   Gorgeous Set!!   Thanks!!
Offline de_milk
« Reply #3051 on: Sat, 30 August 2014, 22:11:01 »
Brothers united
Nice Keyboard
Offline lotus1109
« Reply #3052 on: Sun, 31 August 2014, 07:39:54 »
one of my endgame boards
glad to have one in the end
I must say I have the same taste with you! Nu gundam and 456GT! I currently have one unassembled Nu too haha
Offline jonathanyu
« Reply #3053 on: Sun, 31 August 2014, 14:14:51 »
I should take a picture of my 456gt with hi nu
Offline shawn24
« Reply #3054 on: Sun, 31 August 2014, 19:00:50 »
go ahead buddy, im quite looking forward to it :thumb:
Offline 3Love
  • Bumpino Supremo
  • I want to become a great collector. Greedy!!!
    • https://geekhack.org/index.php?PHPSESSID=iscd3shj44rpefbd0342tln9c3br535b&topic=63161.0
« Reply #3055 on: Mon, 01 September 2014, 11:49:54 »
I♥Keyboard  I♥Clack  I♥Brobot  I♥Hammer
                          I♥♥♥friends
【WTB/WTTF】https://geekhack.org/index.php?topic=63161.0
KBD Collection: 356CL, 356.2, 356DGE, Koala, 356MINI, 356N, 356N-MK2, 356PAD, 360C, 456GT, FMJ, LZ-MXSE, LZ-RE, KMAC 1.0, KPAD, Duck Orion, Duck Pad, Exo, TEX and etc.
    • Gray Designs
« Reply #3056 on: Mon, 01 September 2014, 13:20:45 »
I need to take some better photos, but I finally decided to do Orange Alps, though I may swap them for something else in the future.  I go so used to a 60% and having a Win key that it's taking a little bit getting used to a tenkeyless and layout again.  I got so used to using the Win key that I'll probably have to remap one of the Alts to Win.  The bottom row downward sloped modifiers are also interesting feeling and take some getting used to.
For the stabilizers, I actually didn't use any from an Alps board, but used one from an Omron board instead.
If you look at the leg on the stabilizers and if you've played with Alps stabilizers before, you can probably tell why I went with them.  They'll be damn near impossible to remove without breaking them or desoldering all the switches and taking apart the whole board.
If you look at this picture, you can see that I didn't install the space bar stabilizer thing (it's a small black tube that the post on the spacebar fits into).  When I took the picture, it was off with some clear acrylic paint on it.  For some reason, they don't fit right on the Kingsaver and I've found you need to put something on the legs in order to keep it in place.
I was playing around with the Apple logo that came off the donor board here.  I'm still deciding if I'll keep the Print Screen and Pause caps the way they are or if I'll use a F-row cap for them instead since they're a different profile.  The Alphas are from the same Omron board that I got the stabilizers from and the modifiers are all from a Wang and I got thanks to Akimbr0.
And without the Apple logo from the donor board:
And you can't tell in the picture, but the Caps Lock uses a 2x3x4mm Pink Water Clear LED.
Damn.. This is so amazing! I really love the orange alps LOOK and you guys say Id probably like the feel. Much excitement.. Cool case and PCB too!
Offline margo baggins
  • Dungeon Dweller
  • Get back to work!
« Reply #3057 on: Tue, 02 September 2014, 10:42:41 »
My new Cheat :) Half plate, browns, glorious. Absolutely love it.
I got boards.
« Reply #3058 on: Tue, 02 September 2014, 10:44:16 »
browns :(
cheat :)
QFR | MJ2 TKL | "Bulgogiboard" (Keycon 104) | ctrl.alt x GON 60% | TGR Alice | Mira SE #29 | Mira SE #34 | Revo One | z | Keycult No. 1 | AIS65 | First CW87 prototype | Mech27v1 | Camp C225 | Duck Orion V1 | LZ CLS sxh | Geon Frog TKL | Hiney TKL One | Geon Glare TKL
  • Dungeon Dweller
  • Get back to work!
« Reply #3059 on: Tue, 02 September 2014, 11:10:08 »
browns :(
cheat :)
Probably going to swap them to clears once I have done all the jd40's I got to build.
I got boards.
Offline ComradeSniper
  • HHKB Pro
« Reply #3060 on: Tue, 02 September 2014, 13:46:47 »
The idea of a half plate has always seemed really odd to me, but then again I've never tried it.
« Reply #3061 on: Tue, 02 September 2014, 13:53:40 »
I think the idea is that it allows you to have alphas that feel like PCB mounted switches but on a plate mounted board.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #3062 on: Tue, 02 September 2014, 15:58:20 »
Omnomnom!
Black for spacebar?
|||My other keyboards :
x
Offline pmh1410
« Reply #3063 on: Tue, 02 September 2014, 23:14:28 »
Congrats, Cheat B/R/B have very good quality housing with Hard Anodized Top and bottom. If you swap PS2 to USB connector, you can integret number pad, lock Fn ...... by Aikon software ;)
Offline rebluer
« Reply #3064 on: Wed, 03 September 2014, 04:59:17 »
LZ TrikX red & black
BSP blank PBT keycaps with A-profile & Desko Dye-Sub by Imsto
Cherry Dye-Sub
95win  Dye-Sub by Imsto
NCR 3007 with Russian Cyrillic Dye-Sub by Imsto
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #3065 on: Wed, 03 September 2014, 05:16:33 »
All of your boards look incredible, sir.
Offline Jokrik
« Reply #3066 on: Thu, 04 September 2014, 11:13:42 »
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #3067 on: Thu, 04 September 2014, 15:59:38 »
Absolutely gorgeous board jokrik. I wouldn't change a single thing. Spectacular!
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #3068 on: Thu, 04 September 2014, 16:01:33 »
Lightsaver v2 + Caps by hansen_oe, on Flickr
Lightsaver v2 by hansen_oe, on Flickr
Lightsaver v2 Night by hansen_oe, on Flickr
I... I... I think... I'm in love... <3
Offline Sent
  • ¯\_(ツ)_/¯
« Reply #3069 on: Thu, 04 September 2014, 17:46:15 »
One of the boards I've been lusting for.  Fan of the extra splash of color with the yellow.
Offline Jokrik
« Reply #3070 on: Thu, 04 September 2014, 18:26:50 »
In love with me? or with
this?
Lightsaver v2 Night + Caps by hansen_oe, on Flickr
Offline Sent
  • ¯\_(ツ)_/¯
« Reply #3071 on: Thu, 04 September 2014, 21:11:24 »
this?
Why not both?  Vesper's a generous guy.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #3072 on: Sat, 06 September 2014, 04:13:38 »
o man, i never liked full sized board but that looks good as hell  :eek:
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #3073 on: Sat, 06 September 2014, 04:50:15 »
this?
... you, first... board, second... <3
Everything about that keyboard is so beautiful. The caps, the mods, the CC, the LED color choice... hnng... don't know if my heart can contain...
this?
You said it, brother.
Offline 3Love
  • Bumpino Supremo
« Reply #3074 on: Sat, 06 September 2014, 04:55:12 »
Cherry Dye-Sub
惊现台湾豪
                          I♥♥♥friends
« Reply #3075 on: Mon, 15 September 2014, 19:55:34 »
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #3076 on: Mon, 15 September 2014, 20:03:30 »
Thanks for making this keyboard so perfect for me. I'll PM you my address. I love you <3
Offline Eszett
« Reply #3077 on: Mon, 15 September 2014, 20:03:55 »
Sorry, but what’s the reason for printing about 70 Kanji on the caps, when there are 3000+ Kanji?
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #3078 on: Mon, 15 September 2014, 20:04:39 »
« Reply #3079 on: Mon, 15 September 2014, 20:07:43 »
Whoa dude what the hey. This is mine. How many times have you typed on it? That's right, it's mine long before it's yours.  ;)
« Reply #3080 on: Mon, 15 September 2014, 20:11:27 »
You're welcome! However, it seems that Hoffman is trying to outbid you ;)
It's not Kanji, it's hanzi used for typing out Mandarin Chinese. This is the Taiwanese layout where they have the caps printed to support three different input types. Check this out for more information.
« Last Edit: Mon, 15 September 2014, 20:24:58 by CPTBadAss »
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #3081 on: Mon, 15 September 2014, 20:12:16 »
WHAT KIND OF LOGIC IS THAT, EH?! Clearly, you've already typed on it and don't need it anymore. Plus, if it was YOURS you would've just taken it home with you. CLEARLY, he didn't want you to have it. It's being sent to me because I've never tried it before. I look forward to having my Alps cherry popped by CPT *wink wink yoink yoink*
outbid? Do I need to send you some heavily worn soccer short shorts?
« Reply #3082 on: Mon, 15 September 2014, 20:14:06 »
Alps cherry
Wow how noob are you, cherry and alps are different things dood.
I'll let you try it, but you better send it to me when you're done.
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #3083 on: Mon, 15 September 2014, 20:15:28 »
Alps cherry
LOL I SEE WUT U DID THURR. I knew you'd do that too. Sheet, son.
I'll be sure to send it back to you... I- ... I promise...  :rolleyes:
Offline cooldiscretion
  • Convicted guilty of being totally rad.
« Reply #3084 on: Mon, 15 September 2014, 22:46:02 »
Really nice board.  And damn, that windows key is gorgeous. :) :) :)
Offline Eszett
« Reply #3085 on: Mon, 15 September 2014, 23:09:51 »
@CaptainBadAss Thanks for the explanation, I think this writing system is beyond me :-)
Offline Sent
  • ¯\_(ツ)_/¯
« Reply #3086 on: Tue, 16 September 2014, 00:14:03 »
/wipes Hoff and Vesper's drool off Cap's board
Really nice, BadAss.  :thumb:
Learning to type in Mandarin is/was hell. :'(
Offline kaiserreich
  • HHKB Elite
« Reply #3087 on: Tue, 16 September 2014, 05:24:19 »
Or you know, you can use the mainland china method, where everything is spelled out using latin alphabets.
Duck viper grey with Dolch caps.
The grey is slightly blueish. The potato camera plus the lighting is not able to bring out that color
Things I like about this keyboard
Nice HHKB style cutouts.
Great consideration of screw mounts for PCB attachment. Dampens the noise significantly even though i am using 62g clears. On the KMAC, this thing would be noisy as hell. Slightly noisier than an RF silent is how I would put it.
Great case quality. One of the reason i bought this was because of the Duck poker case. I am nit disappointed
Things i do not like about this keyboard
PCB material is awful. I can smell the PCB burning while soldering for the first time. Desoldering for the first time would sometimes cause pads to lift. Consideration should have been made as this is a modder's PCB. It would go through a few soldering/desoldering cycles over its lifetime.
The slope. This keyboard is designed for people who rests their hands on the table while typing. Same height as the leopold fc660c with its feet extended. Might be personal preference but not my preference.
Firmware. Might be that I am an idiot. I cannot figure out how to turn off the layer indicator (caps lock LED) so i desoldered it. Very annoying to have something blinking when you are trying to concentrate.
Things i hate about stabilzers
PCB mount stabilizers on a plate mount keyboard. If the stabilizer wire somehow dislodged from the stabilizer, it would be very hard to put it back. I had to desolder the whole thing before figuring out this. A kind friend recommended me to add toothpicks behind the stabilizer wires. It helps.
« Last Edit: Tue, 16 September 2014, 05:31:33 by kaiserreich »
    • Gray Designs
« Reply #3088 on: Tue, 16 September 2014, 05:25:05 »
PCB material is awful. I can smell the PCB burning while soldering for the first time. Desoldering for the first time would sometimes cause pads to lift. Consideration should have been made as this is a modder's PCB. It would go through a few soldering/desoldering cycles over the lifetime.
Firmware. Might be that I am an idiot but I cannot figure out how to turn off the layer indicator (caps lock LED) i desoldered it.
Things i hate about korean customs
Duck Viper!!! Ooooo... Very nice case and board man!  :cool:
Offline Sent
  • ¯\_(ツ)_/¯
« Reply #3089 on: Tue, 16 September 2014, 05:27:37 »
Yeah, I do use the mainland method.  The other method was more of a fun experiment that turned into an exercise in futility and frustration last time I was back in Taiwan.  :))
Really nice Viper.  A lot more blue in that gray than I would've thought.
Offline StylinGreymon
  • Keyboard Hipstar
« Reply #3090 on: Tue, 16 September 2014, 05:30:59 »
Super sexy.
If today had been a hippo, then you'd really have to worry about tomorrow.
Offline kaiserreich
  • HHKB Elite
« Reply #3091 on: Tue, 16 September 2014, 05:40:07 »
Native mandarin speaker here. I do not know how to use the Taiwanese keyboard.
Offline feizor
« Reply #3092 on: Sat, 20 September 2014, 01:24:30 »
Are those Originative pbt dyesubs?
Offline jonathanyu
« Reply #3093 on: Sat, 20 September 2014, 01:31:38 »
They are GMK doubleshot
Offline bazh
« Reply #3094 on: Sat, 20 September 2014, 02:04:04 »
HHKB Pro2 white
Newbie again
Offline feizor
« Reply #3095 on: Sat, 20 September 2014, 09:33:59 »
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #3096 on: Wed, 01 October 2014, 19:04:55 »
Can't believe I didn't post here yet. Here is my Duck Orion TKL.
Built by Margon using 'Vintage' Cherry MX Clears from a SkiData. Lubed and stickered with clear switch tops and screw-on Cherry Stabilizers.
Double Clear  :p
GMK keycaps. A combination of SkiData caps and Charred Orange from Originative.
Gotta love the Q @ and M μ legends and the mods without text on Backspace and Tab.
I'll find a use for the relegendable F-row when I start programming it.
Stainless plate + Clear tops = sexy Backglow
I absolutely love your setup. Do you mind saying which keys were actually Skidata and which were the Charred orange? They look so "complete" together!
Offline whentheclouds
« Reply #3097 on: Wed, 01 October 2014, 20:07:28 »
looks to me like the alphas are Skidata, and the mods are Charred Orange
Offline esoomenona
  • Gnillort?
« Reply #3098 on: Wed, 01 October 2014, 21:35:47 »
« Last Edit: Mon, 21 September 2015, 10:34:23 by esoomenona »
Offline Karura
  • SKidata life.
« Reply #3099 on: Thu, 02 October 2014, 01:43:06 »
Looks like this to me as well. Couple indicators: the color difference on the legends, the relegendable F row, the sub legends on some keys like Q and M.
Also, he needs to push that 2 key down some.
I feel it's actually a complete random "I'll pick this, pick that" method, cause I noticed the blackspace, tab are both Skidata as well (lack of letters), so perhaps those are the only 2 Skidata keys for the modifiers.
Also the Skidata has QWERTZ format, so perhaps he is using the charred orange Y, Z too :)
Either way, I think we figured it out... teamwork!
