Alright, I'm super glad I did a prototype.
Problems:
1. Cherry spacebar stabilizers didn't fit
2. Cherry stabilizers are tight
3. Costar stabilizers fit in the slots but don't work. The legs of the black part of the stabilizing system are deflecting inward not allowing the white insert to freely move.
4. Cannot open switch tops on stabilized keys (except the spacebar)
Solutions
1. alixinhzai said to flip the cherry style mount on the spacebar location when he passed me the design, I forgot, it's upside down. It will be fixed before sending to the cutter
2. I'm going to be adding a few thousandths on the left and right of the cherry stabilizer cutout
3. Nothing, it's due to plate thickness. You'll have to sand need the costar stabilizer cutouts if you want them to work. Sanding around the mounts should stop the deflection.
4. Nothing, I don't feel comfortable taking away anymore support from the switches
Other than that, it's a nice plate. Switches are nice and tight, it makes the poker feel much more solid and adds ~1/3lbs to the total weight.
**waits for alaricljs to comment ^___^
