Author Topic: [IC] Cherry Switch Top Removal Tool  (Read 84436 times)
Offline The_Beast
  • I like wood ಠ_๏
« on: Sat, 20 October 2012, 02:44:31 »
The interest check:
I will be buying some of the switch tools at the same time as the poker plate group buy. This is just a interest gauge NOT an order form. Please keep the "other" option short, simple and to the point. They would come pre-bent and sanded ready to work as soon as you get them.
What it looks like:
Looks dumb but I could take apart 7 switches PER MINUTE:
Interest Check Form
« Last Edit: Sat, 20 October 2012, 12:09:43 by The_Beast »
Offline WhiteFireDragon
    • youtube
Re: [IC] Cherry Switch Tool
« Reply #1 on: Sat, 20 October 2012, 03:38:48 »
Interested, filled out that form. Does it come with finger tape, and those fingers as well?
On a more serious note, I don't think it's required you bend them. In fact, I think it might be better that you don't bend, that way you can hold it at the tip for slightly more leverage and your fingers are closer together.
« Last Edit: Sat, 20 October 2012, 03:40:22 by WhiteFireDragon »
« Reply #2 on: Sat, 20 October 2012, 03:39:54 »
Interested in the tape and fingers as well...my fingers would tend to get chaffed and tired from such an activity.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #3 on: Sat, 20 October 2012, 03:47:19 »
I tried it without the bend, it didn't work
    • youtube
« Reply #4 on: Sat, 20 October 2012, 03:56:48 »
How so? Just by looking at the pics, I wouldn't think that the bend just allows your fingers to hold it at certain angle, but not totally prevent the design from working.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #5 on: Sat, 20 October 2012, 04:07:42 »
Without the bend, you can't actuate the switch top enough to
Offline Glissant
Re: [IC] Cherry Switch Top Removal Tool
« Reply #6 on: Sat, 20 October 2012, 04:15:14 »
Oh yes! This tool looks to be exactly what I would need. I've been starting to have issues with some switches because of the way I've been opening my switches on my Poker tens of times.
GET'ER DONE! ;)
Offline Acanthophis
« Reply #7 on: Sat, 20 October 2012, 04:55:41 »
Filled out form.
Would be cool if we/you could find a way to put them together when not in use. Magnets, easily open string or similar, etc.
But this is just a neat bonus, I totally could live w/o it.
Offline fruktstund
« Reply #8 on: Sat, 20 October 2012, 05:04:44 »
Definitely interested! I'm too bad at bending paperclips, so this is perfect.
Offline i3oilermaker
  • techkeys.us
    • TechKeys
« Reply #9 on: Sat, 20 October 2012, 07:59:03 »
Interested!  Form filled
Offline CKTofu
  • I don't even...
« Reply #10 on: Sat, 20 October 2012, 10:19:20 »
Definitely interested, filled out the form!
Ducky Shine 2 - MX Red with Red LEDs
Offline nntnam
« Reply #11 on: Sat, 20 October 2012, 10:45:04 »
Form filled :D .  I did one myself based on limmy't tutorial but still want one. It looks cool  :cool:
« Last Edit: Sat, 20 October 2012, 10:47:28 by nntnam »
░▒▓ KMAC | FILCO MJ2 | HHKB | PHANTOM ▓▒░
Offline alaricljs
  • I be WOT'ing all day...
« Reply #12 on: Sat, 20 October 2012, 10:49:32 »
Can I recommend a modification?  Punch 2 holes through the tool, one a small distance up from the base of the curve, another a small distance down from the top end.  3/8" seems like a good size.  You could then use elastic cord loops to attach the tools to your fingers instead of tape.
Filco w/ Imsto thick PBT
Offline The_Beast
  • I like wood ಠ_๏
« Reply #13 on: Sat, 20 October 2012, 12:02:47 »
NO RECOMMENDATIONS EVER
yea, we can add some holes ^__^
Edit: Pm'ed some of the people who left comments
Edit 2: They will be coming pre-bend and sanded, added to OP
« Last Edit: Sat, 20 October 2012, 12:10:16 by The_Beast »
Offline Caaaarrrt
« Reply #14 on: Sat, 20 October 2012, 12:33:05 »
looks good to me :)
Metal Grey LZ-GH - 62g Clears | White HHKB Pro2 |KBC Poker - Lubed Reds w/ Plate and Red Imsto case | Duck PokerCM QuickFire Rapid - Blues w/ red case
Offline Acanthophis
« Reply #15 on: Sat, 20 October 2012, 13:40:30 »
Should I have left the comment in the form to get your attention? :/
Offline The_Beast
  • I like wood ಠ_๏
« Reply #16 on: Sat, 20 October 2012, 13:42:38 »
I like the idea of magnets but like alaricljs, bungie cords would help open the switch AND keep them together
Offline yuiop
« Reply #17 on: Sat, 20 October 2012, 13:52:04 »
Form filled, I'm interested.  I'm currently using binder clips.  They work fine but tend to put too much stress on my finger tips.  I was thinking about getting some angled tweezers.
Offline Acanthophis
« Reply #18 on: Sat, 20 October 2012, 13:59:56 »
Ah, ok, had to reread alaricljs' post a few times to understand its content :D
Yeah, that's quite similar to my approach, even better.
I still want credits!
Offline AKIMbO
  • HHKBro
« Reply #19 on: Sat, 20 October 2012, 14:01:22 »
Sounds dope...I'd be down for one set.
| KBD75 (box reds)
Offline TheProfosist
  • Custom Layouts Only!
« Reply #20 on: Sat, 20 October 2012, 14:21:41 »
down for a set as well filled out form
Offline wiredPANDA
« Reply #21 on: Sat, 20 October 2012, 14:24:46 »
Form completed.
| HHKB Pro 2 | Leopold FC660C
| Poker.PANDAclears | ErgoDox (62g Black)
Offline The_Beast
  • I like wood ಠ_๏
« Reply #22 on: Sat, 20 October 2012, 15:05:20 »
uhhhmmmm no?
^___^
Offline DarkShot
  • Professional Procrastinator
« Reply #23 on: Sat, 20 October 2012, 15:40:13 »
Interested as well, fancy form filled out already.
« Reply #24 on: Sat, 20 October 2012, 20:27:34 »
Filled out the form, I'd be interested in these. Should work better than those paper clip things :\
Offline esoomenona
  • Gnillort?
« Reply #25 on: Sat, 20 October 2012, 20:53:15 »
« Last Edit: Mon, 21 September 2015, 14:41:32 by esoomenona »
Offline thegunner100
  • (╯'□')╯︵</3 ノ( '-'ノ)
    • The Emotional Skyscraper
« Reply #26 on: Sat, 20 October 2012, 20:54:12 »
Would definitely be interested in buying!
Input Devices:CM QF Rapidx2 ~ REALFORCE 87uw 45/55g ~ Logitech G5v2 ~ Wacom Bamboo CTH-460
Audio Setup: look me up on head-fi
Check out my blog on touhou/doujin music, audiophile gear, and doujin games!
Offline The_Beast
  • I like wood ಠ_๏
« Reply #27 on: Sat, 20 October 2012, 21:00:49 »
Looks good, I think I'm going to order about 50 sets
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #28 on: Sat, 20 October 2012, 21:06:03 »
Awesome idea Beasty.  Form filled.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #29 on: Sat, 20 October 2012, 23:11:43 »
Elastic bands like in underwear.
SmallFry! <3
Offline Rumudiez
« Reply #30 on: Mon, 22 October 2012, 00:36:01 »
Interesting, think I would be in for a pair.
40% layout, anyone?
Offline modulor
« Reply #31 on: Mon, 22 October 2012, 08:59:33 »
In for one...fancy form filled! ^-^
  • Live long and prosper
« Reply #32 on: Mon, 22 October 2012, 09:05:24 »
Form filled.  Me wants! Will make switch swapping/modding so much easier...
tp thread is tp thread
Offline The_Beast
  • I like wood ಠ_๏
« Reply #33 on: Mon, 22 October 2012, 09:32:33 »
I think I'll be buying 120 tools/60 sets during this GB. I'll be able to ship with the poker plates (I'll just add what it cost onto your shipping invoice) or separately if you didn't order a plate.
Tentative pricing is $5.50 + shipping
Offline modulor
« Reply #34 on: Mon, 22 October 2012, 12:32:56 »
:D
Offline The_Beast
  • I like wood ಠ_๏
« Reply #35 on: Mon, 22 October 2012, 12:35:03 »
Per alaricljs (and DeathAdder) suggestion, 2 holes have been added for magnets or elastic
« Last Edit: Mon, 22 October 2012, 16:03:50 by The_Beast »
Offline justin one
« Reply #36 on: Mon, 22 October 2012, 13:08:41 »
If these are less than $10 I would be in for at least one set.
[ KBC Poker ] [ Ducky DK9087 ]
Offline The_Beast
  • I like wood ಠ_๏
« Reply #37 on: Mon, 22 October 2012, 13:19:59 »
There were a couple $10 and if you want to pay that, I'll accept. But the vast majority were in the $4-$7 range
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #38 on: Mon, 22 October 2012, 13:40:59 »
Nice, forum filled.
-Enzo Ferrari
Offline Acanthophis
« Reply #39 on: Mon, 22 October 2012, 16:01:17 »
Per alaricljs suggestion, 2 holes have been added for magnets or elastic
Awww maaaan :/
Offline The_Beast
  • I like wood ಠ_๏
« Reply #40 on: Mon, 22 October 2012, 16:04:23 »
Check again you big baby ^____^
Offline Acanthophis
« Reply #41 on: Mon, 22 October 2012, 18:40:16 »
Now I can die happy  :-*
Offline rindorbrot
AW: [IC] Cherry Switch Top Removal Tool
« Reply #42 on: Wed, 24 October 2012, 07:05:01 »
Will a order thread be up soon?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #43 on: Wed, 24 October 2012, 07:18:52 »
I'm front the money and buying ~60 sets. You can just buy from me directly. They should be ready ~11/30 since I'll have to sand and bend 120 of them
Offline Acanthophis
« Reply #44 on: Wed, 24 October 2012, 09:31:31 »
If we also buy a Poker plate from you, you do ship them combined, right?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #45 on: Wed, 24 October 2012, 09:44:06 »
Yea, people who have bought plates will have priority since I'm shipping them stuff anyways. If there are any left, then I'll sell to anyone else who wants one
Offline Zehkul
« Reply #46 on: Thu, 25 October 2012, 05:40:23 »
dumb question, this tool doesn’t need the leverage from below the switch, is it possible to change switches without desoldering even on normal plates then?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #47 on: Thu, 25 October 2012, 08:16:23 »
Nope. If you look at a switch is has four legs/hooks that need to be unhooked from the bottom of the switch. On OEM plates there is no cutout to allow the legs to be moved. On the poker/phantom plate, you can see little notches cut out which allow you to remove the top without having to desolder
Offline Paranoid
« Reply #48 on: Thu, 25 October 2012, 09:14:25 »
also interested, filling out the form!
Offline Munzter
« Reply #49 on: Sat, 27 October 2012, 00:46:59 »
Would like to order a pair when available!  Please keep us posted when they do. Thanks!
