Author Topic: A4 & 8.5 x 11" Keycap Checkers (ANSI)  (Read 11313 times)
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« on: Tue, 23 October 2012, 18:57:49 »
A while back, someone asked for a keycap checker that would fit onto an 8.5 x 11" sheet of US paper.  I had some time to put one together for ANSI keyboards, and there was enough room left over to add 1.5-1-1.5 1.5-1-1-1.5 for an alternative spacebar row.
Below are pics of the sheet and a test of the sheet using a set of Rosewill keycaps (that I replaced with a WASD set.)
I will also try to attach a pdf version.
I made this in Visio 2007, and would be happy to provide a source copy to anyone who wanted to make other versions.
Enjoy!
 - Ron | samwisekoi
* ANSI Checksheet 121023b.pdf (34.98 kB - downloaded 419 times.)
« Last Edit: Thu, 25 October 2012, 11:23:46 by samwisekoi »
Offline sth
  • 2 girls 1 cuprubber
Re: 8.5 x 11" Keycap Checker (ANSI)
« Reply #1 on: Tue, 23 October 2012, 19:01:41 »
nice :)
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #2 on: Tue, 23 October 2012, 19:02:54 »
Well done, many have tried to achieve this before.
They tried and died.
Offline jcrouse
« Reply #3 on: Tue, 23 October 2012, 19:18:59 »
I'm curious, why not do 8.5 x 14 and include the Tsangan kit and numpad. It WILL all fit and it's still 8.5 wide so it will run through standard home printers.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #4 on: Tue, 23 October 2012, 19:22:52 »
There is already one of those.  Someone had requested this topology, and I thought it would fit.
It did.
 - Ron | samwisekoi
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #5 on: Tue, 23 October 2012, 19:26:26 »
nice :)
Thanks.
 - Ron | samwisekoi
p.s.  According to Google Translate, "מהר שלל חש בז" means "Booty quickly felt Beige".
Offline hashbaz
  • Grand Ancient One
« Reply #6 on: Tue, 23 October 2012, 19:41:09 »
It's a long, not very interesting story.  Short version: it's a reference to the book of Isaiah and means "he has made haste to the plunder". ;)
http://en.wikipedia.org/wiki/Maher-shalal-hash-baz
Offline SmallFry
« Reply #7 on: Tue, 23 October 2012, 19:51:36 »
Nice! I don't like the angled corners at much, but still mucho useful! Thank you! I like the red better than the other sheet however... :P
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #8 on: Tue, 23 October 2012, 20:18:10 »
Well, I am in the US, and apparently Apple owns the patent on rounded rectangles, so I didn't use them.   :'(
Did you mean you liked the red background on the alternate lower row keys?  I used red to distinguish them from "normal" keys.
I'm happy to make a more colorful version.  It would be good to segregate the numpad keys, etc,. anyhow.
 - Ron | samwisekoi
Offline SmallFry
« Reply #9 on: Tue, 23 October 2012, 20:38:28 »
I lol'd at the patent joke...I do like how you used the red to differentiate. Very useful...
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #10 on: Wed, 24 October 2012, 12:19:00 »
Another version, this time with the keycap groups consolidated better (e.g. numpad all together.)  Also, more color-coding and I've improved the look with pseudo-3D rounded rectangles.
 - Ron | samwisekoi
* ANSI Keycap Checker v2.pdf (51.08 kB - downloaded 386 times.)
« Last Edit: Wed, 24 October 2012, 12:42:17 by samwisekoi »
Offline modulor
« Reply #11 on: Wed, 24 October 2012, 12:38:08 »
Excellent work!
« Reply #12 on: Wed, 24 October 2012, 18:21:16 »
I like this second one, and it just about prints on A4.  The top, say, 10% of the top row is cut off, but the rest fits on, including the accreditation at the bottom right.
Won't get much closer than that on A4 ;)
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #13 on: Wed, 24 October 2012, 18:48:43 »
I am sitting here waiting for a YouTube upload to process. I can do an A4 version, easy.  I've attempted to do a UK keycap set in A4. I cannot really validate it.
(I also did an A4 ANSI version because it was trivially simple.)
Are there any errors?  Does they print to A4?
 - Ron | samwisekoi
* A4-UK Keycap Checker.pdf (53.26 kB - downloaded 349 times.)
* A4-ANSI Keycap Checker v2.pdf (51.93 kB - downloaded 376 times.)
« Last Edit: Wed, 24 October 2012, 19:11:57 by samwisekoi »
« Reply #14 on: Wed, 24 October 2012, 20:08:44 »
you're a wizard harry! ron!
« Reply #15 on: Wed, 24 October 2012, 20:20:14 »
Brilliant!
Works perfectly :)
It is a tight fit.  I have only spare WASD key caps lying around, but these have to be touching each other to fit on the paper.  The previous chart allowed about 1/2mm between each key.  This is not a problem (unless there are key caps with slightly wider than usual bases).
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #16 on: Wed, 24 October 2012, 20:37:29 »
Brilliant!
Works perfectly :)
I'll scoot the keycaps apart by 2mm or so in the (my) morning.
 - Ron | samwisekoi
Offline SmallFry
« Reply #17 on: Wed, 24 October 2012, 20:38:38 »
You keep making it better and better so that I must keep printing more sheets! LoL! Great work. Thank you.
You should add the keys units for the stabilized keys.
« Last Edit: Wed, 24 October 2012, 20:40:40 by SmallFry »
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
Re: A4 & 8.5 x 11" Keycap Checkers (ANSI)
« Reply #18 on: Thu, 25 October 2012, 11:28:49 »
Okay, I scooted the keycaps apart a bit.  It worked fine on the US paper, but I had to sacrifice something for print margins on A4, so some the "extra" modifiers will get clipped a bit, but should still be useable.
Re indicating units; if someone wants to send me a definitive list of key lengths (e.g Tab =1.25U). I'll try and include that on the grid.  Somehow.
Please advise how the A4 turned out when printed.
 - Ron | samwisekoi
* ANSI Keycap Checker v3.pdf (51.71 kB - downloaded 347 times.)
* A4-ANSI Keycap Checker v3.pdf (52.75 kB - downloaded 377 times.)
Offline SmallFry
« Reply #19 on: Thu, 25 October 2012, 12:08:03 »
Just put the units on the keycaps, like the other ones floating arround... *rummage for PDF for you*
« Reply #20 on: Thu, 25 October 2012, 16:20:03 »
The A4 one is fine.  It is still a tight fit horizontally, but vertically there is now a slight gap between each row.
Tight fit = the key caps have to be touching the ones on the left and right, but the few spare ones I have lying around here fit perfectly.
