Author Topic: 6KRO or NKRO over USB? Any pros/cons?  (Read 9970 times)
Offline firebt
« on: Tue, 20 November 2012, 06:27:41 »
So, basically what the post says.  The odd thing is, on my Ducky, there is a dipswitch that enables you to switch between 6KRO and NKRO.  I'm assuming it can achieve NKRO since every switch has its own diode (LED) and can isolate all the signals or something? Not sure.
My question is, is there any disadvantage to having full NKRO vs 6KRO over USB? For example, is there any noticeable lag or any issues anyone encountered during gaming/typing?  Thanks again.  I don't think I'll use more than 6KRO for my games (Dota 2, HoN, CS:GO) so yeah.  But just wondering.
Offline IvanIvanovich
  • Klaatu... Verata... N?????
Re: 6KRO or NKRO over USB? Any pros/cons?
« Reply #1 on: Tue, 20 November 2012, 11:35:18 »
It really dosen't matter. NKRO mode con is the keyboard may not work proprly in bios. Really though anything more than 10KRO is essentially unneeded, unless you have extra fingers or like to type with both hands and feet at once.
  • The distant smell
    • Bingecap
« Reply #2 on: Tue, 20 November 2012, 13:42:52 »
Every board I've had with #KRO hacks over USB have acted weird on some systems/OSes.  I really wish they would stop trying to make things more complicated and just push controllers to some new standard.  Anyone know what USB 3.0 can handle with respect to keyboards? lol
Offline Azure Flash
« Reply #3 on: Tue, 20 November 2012, 13:54:54 »
It's a matter of drivers vs hardware interrupts more than it is about bandwidth. As many keyboard manufacturers have shown, USB2 is capable of NKRO with some driver tweaks. I'd expect USB3 to be pretty much the same deal as USB2, that is NKRO with some driver tweaks which will probably bring, as Binge said, problems with some OS.
The only real use for NKRO is for those rare quirky moments like wanting to bash your head on your keyboard to see what it does. Bashing your head on NKRO has a very interesting effect... on 2KRO, not so much. As such, I put #KRO at the very bottom of my list of criteria. There are enough variables in the selection of a keyboard already!
Offline Soarer
« Reply #4 on: Tue, 20 November 2012, 14:08:26 »
You can count on one hand the number of keyboards using full-speed USB, but they are the ones that can do >6KRO just fine, with no downsides. Whether they actually implement it correctly is another matter.
It doesn't matter if it says it's USB 1.1 or USB 2.0 - they can both support full-speed. (USB 2.0 added high-speed).
No driver tweaks are needed for NKRO using full-speed USB; it's all been there in the HID standard right from the beginning.
Dunno what the Ducky does, but if it shows up in device manager as a low-speed device you may as well leave it on 6KRO.
Offline firebt
« Reply #5 on: Tue, 20 November 2012, 14:19:11 »
It says its a HID device and it shouldn't be low speed at all.  It's USB 2.0, so it's pretty quick.  Okay, sounds good, I'll just leave it at 6KRO for now, but we'll see.  Lol on the hands and feet comment and banging your head that was hilarious.
Offline Soarer
« Reply #6 on: Tue, 20 November 2012, 14:29:04 »
Ah, but USB 2.0 devices can still be either low, full or high speed. Many devices are USB 2.0 compliant AND low-speed, including most keyboards.
  • The distant smell
    • Bingecap
« Reply #7 on: Tue, 20 November 2012, 15:03:25 »
Is it not a standard for USB 2.0 across each OS to register 6 keys pressed at a time?  My issue with USB 2.0 is THAT standard.  If a company made drivers for their peripheral for every OS I guess there would be no trouble, but by standard PS/2 was able to do NKRO regardless of the OS so why was that not included the USB standard?
Offline firebt
« Reply #8 on: Tue, 20 November 2012, 15:24:46 »
How do you check?
Offline Soarer
« Reply #9 on: Tue, 20 November 2012, 15:42:54 »
No. The USB standards don't say anything specific at all about keyboards or mice etc., in any version.
It's the HID standard that does. The 6-key plus modifiers report structure was only really intended to make life easy for BIOS (so they didn't have to parse report descriptors), but became a de-facto 'standard' for keyboards regardless. However, the HID standard allows for all sorts of different reports, and all major OS support it fully, so there's no need for extra drivers.
The other limitation is that a low-speed USB data packet can only be a maximum of 8 bytes. A report can be larger, but that starts taking a significant amount of time to send. The USB standard only allows a low-speed device to send one packet every 10ms (per endpoint). OS typically nudges that up to 8ms, i.e. 125Hz (without hacks). Taking up to 16ms to get a keypress to the host would be crap! So we've had a phase of makers trying to get more out of low-speed chips than they can really handle, with tricks like multiple endpoints etc. :(
Full-speed USB frees up those limitations. Each packet can be 64 bytes, and can be sent every 1ms (again, per endpoint). This allows the HID standard to be used to its full effect.
Finally, NKRO isn't done just for the sake of it. Doing full NKRO requires only one bit per key, rather than one byte, and doesn't have to treat modifiers as a special case. So a keyboard can send e.g. 104 keys in a mere 13 bytes - using the other scheme 13 bytes would only manage 11KRO (11 keys + modifiers + one reserved byte). Sure, that's still plenty of keys, but it's far less elegant a method (and still 'not-6KRO', so could still be incompatible with dumb hosts).
Offline Soarer
« Reply #10 on: Tue, 20 November 2012, 15:47:29 »
How do you check?
I dunno why it wasn't put in as one of the info fields in Device Manager (on Windows) - it should've been!
Something like USBDeview should be enough, not sure if it is though.
edit: Seems it isn't :(
OK, there's USBview, originally from Microsoft but found via TechRepublic.
With USBview, find your device in the tree and click on it, then in the right hand pane about a dozen lines down there will be a line saying e.g. "Device Bus Speed:   Low".
« Last Edit: Tue, 20 November 2012, 16:06:15 by Soarer »
  • The distant smell
    • Bingecap
« Reply #11 on: Tue, 20 November 2012, 15:59:38 »
Thank you for clarifying that.  I was under the wrong impression from what I've heard, and this makes me want to look into this HID standard.  :)
Offline Soarer
« Reply #12 on: Tue, 20 November 2012, 16:17:12 »
It's very big!! And the 6KRO keyboard part is just one page or so in an Appendix  :))
Online Lu_e
« Reply #13 on: Tue, 20 November 2012, 16:28:40 »
Remember the old thread?
123456123456123456123456123456123456123456123456123456123456123456123456
:p
MX QuickFire Rapid
Offline Soarer
« Reply #14 on: Tue, 20 November 2012, 16:46:47 »
Offline firebt
« Reply #15 on: Wed, 21 November 2012, 01:41:17 »
Lol, I am a noob.   :)  So I got USBview and opened it up.  My computer is currently USB 3.0 capable.  Let me try it some more.  What should it say when it is high or low speed? Sorry lolll
Offline firebt
« Reply #16 on: Wed, 21 November 2012, 01:47:56 »
Damnit, so I just checked.  My keyboard is a low speed USB.  So what does that mean in terms of latency and all that? Better to run in 6KRO or NKRO? Is there even a difference?  Anyone care to shed some more light on this topic?
So I just read your post.  So I get a lag time of atleast 8 ms or 125 Hz.  That's not too terrible, and on NKRO it takes less data to send more keys right?  So in a sense, wouldn't NKRO over USB be faster, since if I only use one or two keys at a time then it's a lot less data.  For example, if I pressed WA+Shift it would be 4 bytes since 2 bytes for keys, 1 for mod and 1 for reserve right?  So in 6KRO mode (8 bytes  6 keys 1 mod 1 reserve bit)...makes sense now...
But I'm assuming the latency 8 ms lag time doesn't change very much right?  Not sure how it affects all that.  Thanks :)
« Last Edit: Wed, 21 November 2012, 01:59:10 by firebt »
Online TotalChaos
  • Indy Game Coder
« Reply #17 on: Wed, 21 November 2012, 05:36:09 »
There is a standard for achieving NKRO without any hacks and it is guaranteed to work on all OSes and all devices.  It is called PS/2.  It comes built in free with all good computers.  Try it, you'll like it.  :)
Offline Soarer
« Reply #18 on: Wed, 21 November 2012, 06:02:00 »
Yeah, the lag time wouldn't change at all, assuming that the Ducky uses multiple endpoints (which would be typical). The lag is actually up to 8ms; it's a regular tick, and data (for all endpoints) is sent at the next tick. It depends on when you press your key as to how much the lag is. To put it into perspective, there's also delays within the keyboard when scanning and debouncing that can be 10s of ms.
HID keyboards always send a complete report, so there's no difference when you only press one or two keys. Even if there was a difference it would be tiny - each data packet is sent in a fraction of a ms.
Essentially, if it works OK with your OS and BIOS when set to NKRO then there isn't really any downside to you using it.
Offline Soarer
« Reply #19 on: Wed, 21 November 2012, 06:51:51 »
'All'  :))
What you mean is - all computers that have a PS/2 port. Which isn't many these days. Hence the qualifier 'good', when what you should honestly say is 'dying breed' :(
Here's a simple ranking for the tl;dr crowd: Full-speed USB  >  PS/2  >  Low-speed USB.
That ranking is true for the NKRO argument and the latency argument.
Offline firebt
« Reply #20 on: Wed, 21 November 2012, 09:40:47 »
Gotcha.  Thanks for the input, I really appreciate it.  There's no way of boosting this device though right? It's just built this way?
Offline zpcrash
« Reply #21 on: Wed, 21 November 2012, 11:03:56 »
Hey, thanks for the discussion regarding USB low speed vs. full speed and the HID spec.  I was wondering how some vendors were able to support NKRO over USB while others could not.
You mentioned there are only a few keyboards using full speed USB.  Can you give us a list of these keyboards or information on where to find such a list?
Do you know how the Ducky Shine II does NKRO over USB?  You mentioned that Ducky might be using multiple endpoints instead of full speed.  Does this apply to the shine II?
Offline jspark
« Reply #22 on: Wed, 21 November 2012, 14:52:28 »
I'm not a keyboard tech expert. Is NKRO really matter? I have two keyboards with MX switches and one IBM model m. I heard that IBM model M is only 2KRO, but I haven't experienced   differences between 2KRO and 6KRO. Maybe, it is because I don't play FPS games.
KBC Poker X Cherry MX Black switch
Filco Majestouch2 Ninja Cherry MX Blue switch
IBM Model M 1391401 in 1988
Offline Soarer
« Reply #23 on: Wed, 21 November 2012, 15:53:40 »
It is what it is. Can't be changed without completely replacing the controller.
Microsoft Sidewinder X4 (yay, rubber dome! and oddball 20+KRO reports)
CoolerMaster CM Storm Pro (but not the Rapid)
errrm... maybe one or two others. I think we'll see a lot more in the next couple of years.
I dunno... probably. Indicators that something has full-speed are claims of NKRO and Mac compatibility, or 1000Hz / 1ms polling. However, some claim things that aren't true, like Filco claiming 1000Hz on some models, and CM claiming 1000Hz on the Rapid (possibly just confusion at CM, since they were introducing the Pro at the same time).
There's no absolute answer to that! For almost any gaming, 2KRO isn't enough. Also for gaming, the less latency the better (or failing that, at least a consistent latency) - that's the real benefit of full-speed, I think, but then the NKRO comes pretty much 'for free', so why not?! :D
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #24 on: Wed, 21 November 2012, 17:14:00 »
CST-104's with the USB hub + Audio passthrough PCB set can go to 1ms polling, as well as current 'base' controllers. The controller can handle it just fine. Catch is that some are defaulted to request 1ms polling and some require it be set at host; don't ask me which keyboard is which. Meka G1 will definitely do 1ms, as will SteelSeries 6GV2.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Ducky DK9008G2 Pro (PBT / Greens), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline Soarer
« Reply #25 on: Wed, 21 November 2012, 18:15:01 »
Maybe, but those are all low-speed devices (the hub might allow high- or full-speed, but the keyboard is low-speed). It doesn't matter if they ask for 1ms or not, they still can't do 1ms without hacks to drivers on the host.
And as for SteelSeries... the drivel they wrote in that USB vs PS2 section is just so lame :(
Offline firebt
« Reply #26 on: Wed, 21 November 2012, 19:21:03 »
Wait, I just thought of something.  Since all mechanical switches have a "bounce" when the switch activates, and usually the latency they add for the is about 5 ms so that it doesn't automatically produce a double tap.  In this case, does this add or even have a factor to that? It doesn't matter though right, it's only for double-tapping aka re-engaging the same switch right?
Offline rootwyrm
    • My Website!
« Reply #27 on: Wed, 21 November 2012, 20:07:41 »
False; it's a standard setting and again, requestable by endpoint. So it's up to the manufacturer to set it correctly. (Or provide a driver definition which sets it correctly.) Either way, the simple fact is this:
"These limits apply to both (low-speed) and high speed devices"
"(a) keyboard could report up to three simultaneous keys using an array with three 8-bit fields (Report Size = 8, Report Count = 3)."
http://www.usb.org/developers/devclass_docs/HID1_11.pdf
So those are the limits. Anything else is a hack. Bet you any "6KRO" with a sniffer on the wire is actually 3+3 at 1ms. So speed actually has between zero and less than zero to do with rollover capability. It's just that most controllers that lie about or don't do rollover are low-speed and it was probably cheaper to use a high-speed PSoC for new designs. A low-speed can still do 3KRO/6KRO.
Except not untrue; especially on the third party USB 3 stuff like NEC/Renesas. (When the hell did NEC start SUCKING at silicon anyway?) People may not notice it, but it's anywhere from 10-50 instructions executed every 1ms for any given attached endpoint when idling. More if the drivers suck or you permit devices to go to low power states. Even more if the device is actually doing anything. Plus interrupt load on a lot of 'em. But it's microbenchmarketing - same as the crap where people would whine about 2-4% CPU load when maxing out a NIC.
So yeah, it's a lot of marketing crap, but at least there's a shred of truth to it. Can't say that about, well, anything at all I've seen from Razer regarding their keyboards. And hey, at least SteelSeries didn't spread the ridiculous 'gold plated USB connector is magically better' crap, right?
Offline Soarer
« Reply #28 on: Wed, 21 November 2012, 21:13:06 »
No. That's incorrect on all counts.
As I said earlier, the spec. limits low-speed devices to a minimum interval of 10ms, and most OS nudge that down to 8ms (i.e. 125Hz):
Quote from: Universal Serial Bus Specification Revision 2.0, section 5.7.4, Interrupt Transfer Bus Access Constraints
An endpoint for an interrupt pipe specifies its desired bus access period. A full-speed endpoint can specify
a desired period from 1 ms to 255 ms. Low-speed endpoints are limited to specifying only 10 ms to 255 ms.
"keyboard could report up to three simultaneous keys...". The key word there is 'could'. It could also implement any number of other schemes, including 'boot-mode' 6KRO, or NKRO. Effectively all it has to do is have a report descriptor for it. Just considering the 6KRO that everyone knows:
Quote from: Device Class Definition for Human Interface Devices (HID) Version 1.11, Appendix F: Legacy Keyboard
Implementation
The limit is six non-modifier keys for a Boot Keyboard.
To clarify, that limit only applies to the Legacy Keyboard Implementation, i.e. boot-mode.
Speed has plenty to do with rollover, since a low-speed device can only send 8 bytes in a packet. I've already said how that limits it compared to full-speed.
Offline Soarer
« Reply #29 on: Wed, 21 November 2012, 21:28:57 »
It adds to it - each step of the chain adds some latency. Debouncing is a pretty big one - Cherry say their switches can bounce for up to 5ms, but to debounce that takes longer. A typical implementation will wait until there has been no change for some ms, and that adds onto the (up to) 5ms that the switch bounces for. Often the debounce seems to be overly conservative, say 10ms or more, so it could be more than 15ms before the controller even thinks about putting it in an output buffer.
Seeing as the steps within the keyboard (and also within the host computer) are effectively mostly the same for any communication method, we can compare the comms in isolation.
« Last Edit: Wed, 21 November 2012, 21:39:31 by Soarer »
